Question about Dewalt Dw938 18v Reciprocating Saw Sawzall Recip 18 Xrp
There are two (2) broken blade hilts in my DeWalt DW938 and I can't get them out. Help!
Have tried needle-nose pliers, WD 40 and wedging out with nails and the like. Nothing works. Do I need to take the carriage apart?
  • jldubs
    jldubs Jan 23, 2013
    Accidentally put new blade in while old fragment was there. 2nd blade broke , now both fragments are in the slot and won't come out.
rowdy45176
  • 2176 Answers
SOURCE: Is there any way to
I am assuming that a nail got jammed? If so unplug air to tool, remove the rest of nails and turn it over. try to find a flat piece of steel smaller than the nose where nail goes and gently tap the driver back up and remove jammed nail. If the driver is broken that is a different fix. Hope this helps
Posted on Dec 09, 2008
  • 1388 Answers
SOURCE: DeWalt d51822 framing nailer, shoots 2 nails at once 1 in 5 times
I worked at at tool rental center while attending college and learned from the old tool masters about nails and nailers. Rental stores have many different brands of nailers to rent and customers would bring their own nails of all brands. You will notice on the case/box that your nails will /should work on many other brands however the degree or angle of the nails is not always exacly as stated on the box. You should check with protractor the exact angle of your nails and also check the exact angle of the nailer. Use straight edge on travel path of the piston and another on guide rails to check angle of the gun. You will discover that all is not as stated as in a perfect world. If the angle is off slightly, the head of the second nail will get into the path of the driver. This happens mostly with clip head because the nail heads are so close together. The full round head is spaced further apart with less jamming. If angle is off slightly, take a look at other brands of nails with protractor in hand, the angle will be different slightly or choose a slightly thicker nail. Look for the nails to fit with bottom of nail hitting the barrel first. This will move the head of the nail slightly away from the center line. Finally do not release pusher with force as this will jamb nails closer together. Good Luck!?
Posted on Jun 18, 2009
rcalorisian
  • 313 Answers
SOURCE: carraige in dewalt nailer
just goto:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
download the support manual. You should be on your way
Posted on Sep 08, 2009
SOURCE: nail gun leaking air through the nose.
Lets assume you have oiled the gun. Before you run out and buy an o-ring kit for this, take the gun apart and look for anything that may be jammed inside the gun. This could be dirt, grit or an unfired nail. The gun is very simple inside so don't be afraid to do this yourself. Undo the 4 hex screws holding on the cap at the back of the gun. Put the nose of the gun in a vise or get a friend to hold the gun for you. Grab hold of the cylinder inside the gun and pull it out. Wiggle it around and pull at the same time, it will be tight but it will come out. Totally disassemble the cylinder. If the seals look good take a very close look at the "Bulkhead". It is made of plastic and is prone to get very small hairline cracks in it and this will leak air. Look inside the cylinder and make sure the walls are smooth and not scored. This is all very easy to do. Don't just buy an o-ring kit assuming it will fix the problem. Look for the simple stuff first, it may save you some time and money. AGAIN IF THE O-RINGS LOOK GOOD TAKE A VERY CLOSE LOOK AT THE BULKHEAD AND LOOK FOR CRACKS, IF AIR IS LEAKING FROM THE NOSE THIS SHOULD BE THE FIRST PLACE TO LOOK AND COSTS ABOUT $7.00 TO REPLACE..........
Posted on Jan 15, 2010
  • 1388 Answers
SOURCE: My Dewalt D51844 nail gun
Dewalt uses two vinyl orings against the cylinder spacer seal. Most likely one or both have have failed. These orings are included in the repair kit available thru dewalt service center near you or on the web. If you have a source for orings, like a bearing retailer, you could replace with generic viton orings. Take cylinder and cylinder spacer with you so that you can fit them in. The orings should allow cylinder spacer to fit snuggly and allow the spacer to have about a 1/4 in travel without jamming. If a kit is not available, then only option is to convert to generic orings. Good holidays
Posted on Dec 14, 2010
A piece of a broken blade is stuck here the blade fits into the saw (Dewalt DW 303m). How do I get it out?
Craig, a drop of penetrate oil and you will just have to work at it with ice pick.small screwdriver, or needle nose pliers if you can, make sure you have blade release depressed while trying to pry blade shank out. Once you get it moving it will fall out. Clean and blow out blade port before inserting another blade.
How to Remove Stuck Blade on Sawzall Hatchet eHow
Troubleshooting Your Malfunctioning Reciprocating Saw DoItYourself com
May 26, 2016 | Dewalt Saws
Extracting broken blade not sticking out of blade holder
Spray with WD 40 and insert Needle nosed pliers to grab and pull it.
Nov 30, 2013 | Ryobi Js550l Jig Saws
I have a sears reciprocating saw with a broken blade.I can't remove the busted blade.Is there any way of removing it?
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Aug 19, 2010 | Craftsman Saws
Reciprocating saw problems cannot get broken blade out of chuck
heatman101
Aug 15, 2010 | Dewalt Saws
Blade stuck in keyless chuck on sawzall. pin or spring must be broken. Any suggestions on how to get the blade out
heatman101
Jul 14, 2010 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
Blade not releasing
heatman101
Jul 05, 2010 | Dewalt DC385B 18v. Cordless Bare...
Cannot get the blade out of the porter cable reciprocating saw
heatman101
May 27, 2010 | Porter Cable Variable Speed Quik Change...
Can not replace blade on Dewalt 303 6.5amp
heatman101
May 23, 2010 | Dewalt DW303 Heavy Duty 65 Amp...
Broken bulb
From what others have said, it will come out, but you have to use some strong good needle nose pliers to turn the base in the socket.
Jan 12, 2008 | Whirlpool MH2155XP Microwave Oven
Dewalt Dw938 18v Reciprocating Saw Sawzall Recip 18 Xrp Logo
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
