Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Hp 7500a "The following ink cartridges appear to be missing or damaged"
I'm having a problem with my printer continually coming up with this error. There seems to be no rhyme or reason to it, it's just whenever it feels like it. When it prints everything is fine then it comes up with this error out of the blue.
  • Alen Jan 22, 2013
    I tried that a dozen times and still get the error.
  • DENNIS MITCHELL Jan 22, 2013
    u may have to replace the carriage assy to correct this
    Problem Solver:
  • 10 Answers
I figured out the problem with my printer. If none of your ink cartridges are detected (missing) then follow the install steps below.
1. Turn on printer
2. After printer declares cartridges missing open the printer and remove the cartridges (advise putting a piece of paper under the cartridges to catch any ink that spills).
3. Turn off the printer (keep the top of the printer open)
4. Turn on the printer (still with the top of the printer open)
5. After the printer declares the cartridges missing again install the cartridges (while the printer is powered on). Close the top of the printer.
6. The printer should begin to cycle the ink into the printer and back out to the ink reservoirs.
7. After the ink cycle the printer should display genuine ink cartridges are installed
8. Make sure paper is in the tray so the printer can perform an alignment.
9. Everything should be ok after that.
Chad
Posted on Oct 09, 2014
    Genius:
  • 1,003 Answers
Clean the gold contacts where the ink cartridges seat with alchol and microfiber towel replace ink cartridges.
Posted on Jan 21, 2013
  • Alen Jan 22, 2013
    I tried that a dozen times and it still doesn't work.
  • 73 Answers
SOURCE: Receiving the message
The message you are getting may be due to the following reasons :
1) Cause : One or more ink cartridges missing.
Solution : Remove and reinsert the ink cartriges and verify that they are fully inserted and locked in place.
2) Cause : One or more of the ink cartriges are not installed or are installed incorrectly.
Solution : Remove and reinsert the ink cartriges and verify that they are fully inserted and locked in place. If the problem persists, clean the copper-colored contacts of the ink cartriges.
Posted on Nov 24, 2009
SOURCE: HP psc 1350 HP 57 print cartridge
Same problem with me.
So:
I openede the whole box ( 4 screws ) in the corners. Then I presed the tiny belt on the left side to its socket, cleaned the contacts of the cartridges (56,57) with water and made them dry.
Then I reched the position of the small door which is ment to be opened once you wnat to replace the cartridge.
After this the printer works again.
Posted on Jun 25, 2008
  • 30 Answers
SOURCE: Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Posted on Aug 19, 2008
professor_sc
  • 180 Answers
SOURCE: ink cartridge problem! The following ink cartridges appear to be missing or damaged.
Solution :
1. clean the ink cartridge contacts both in the printer and the cartridge with a lint free cloth or a cotton swab. and try inserting the ink cartridges again. if it wont work proceed to step 2.
2. unplug the power cord at the back of the printer
3. press and hold # and 3 keys at the same time and plug the power cord back in. Do not release the two keys. wait until the printer would say "partial nvram reset" or anything that says "reset". if this still would not resolve the problem
4. do the same process as 2 & 3 but instead of # and 3 try # and 6. instead of saying "partial nvram reset" it should say "semi-full nvram reset". and if it would not work better go to an onsite technician. but if your printer if brand new return it to the retailer and exchange it. but before you do that try calling HP technician they would instruct you to the things i have given you. Just tell them what you have had done and asked them to replace the ink cartridges. This are the informations the agent would ask you about the ink cartridge
part number and also the expiration date.
try to ask for a replacement first if it would not resolve it. then go to a technician. I could not assure you that a technician could fix it because i have troubleshoot this kind of problems and there are alot of printer parts that needs to be fixed. Usually i suggest my clients to buy a new printer instead
Posted on Mar 07, 2009
SOURCE: HP L7680 the following ink cartidge(s) is missing or damaged
I have the same problem, but only with an original HP OEM cartridge that replaces the generic (which worked fine but is empty- if I put it in the error goes away- but can
t print because it is empty)
Posted on Dec 26, 2009
How do I stop the message of 'Missing or damaged cartridge
Delete and reinstall a printer driver and then go into the protery of the new driver and search for update go to inksell.com they will give you the latest driver
Jun 03, 2017 | HP Officejet Pro L7680 All-In-One Printer
Screen says "the following ink
I am having the SAME problem!! The cyan color for some reason!!! All of these are BRAND new HP ink cartridges!! Have you figured out how to fix this??
Feb 21, 2011 | HP Photosmart D7560 InkJet Printer
I just replaced all ink cartridges and I continue having this message: The following ink cartridges appear to be missing or damaged. (All) I also cleaned inside and reset the computer and continue to...
Hi
Please click on the following to resolve the issue
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01611422&cc=us&lc=en&dlc=en&product=3560280&tmp_track_link=ot_search
If the issue still doesn't gets resolved follow the step below and it would reset your printer to the factory settings
Hold Print Photos & Red Eye Removal then
Red Eye Removal then Print Photos then Red Eye Removal
Press the right arrow key twice to go to the reset menu.
Press ok on reset menu and press the right arrow key to go to the semiful reset
All the best!!
Regards
Oct 28, 2010 | HP Photosmart C6380 All-In-One InkJet...
I have an HP Photosmart C5180.ink appears to be missing or damage
Hi there
Most times it just need a good clean ,take out and clean the brass conextions.
All the best Pineworks
Apr 27, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ink cartridge problem( s) appear to be missing or damaged
hi there,
Ink cartridge Problem
Cause : The indicated ink cartridge(s) are missing or are damaged.
Solution : Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-one, the ink cartridge contacts might need to be cleaned.
IF there is no ink cartridge missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge. Replace the ink cartridge.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Nov 26, 2009 | HP Photosmart C6280 Printer
HP Photosmart 3110 All in One says ink cartdriges missing
Follow the instructions in this link.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00409514&prodTypeId=18972&prodSeriesId=3380537
May 18, 2009 | HP OfficeJet J4580 All-In-One Laser...
Ink cartridge problem! The following ink cartridges appear to be missing or damaged.
hi!!!!
try to clean the nozzle of your cartridge with the alcohol
or solvent used cotton
or replace the cartridge
try to email me ronaldsuboc@gmail.com
Sep 18, 2008 | HP Photosmart C7280 Printer
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
619 people viewed this question
Seeker5211
Seeker5211
