Question about Home Security
White-rodgers dial thermometer/hygrmeter-f 15years old quit/working
Must not sense cold
    Problem Solver:
  • 7 Answers
Hi. This is Aaron Moratalla from White Rodgers. We can help you with this. Please provide the model/type number. If you can't find it on or inside the unit then call our Tech Support at 800-284-2925. Thank you for choosing White Rodgers.
Posted on Jan 22, 2013
3 Suggested Answers
liteswink
  • 99 Answers
SOURCE: No Heat with new White Rodgers 1f85rf-275 Thermostat
The only way to resolve this problem and to distingush if its a thermostat issue on the system is to by pass the thermostat by putting a jumper between the hotwire and the heating wire if the system did run which happen most of the time. Call the HVAC technician to check your heating unit. Or call the White- Rodgers technical line at 18887259797 choose contrator division.
Posted on Oct 20, 2009
liteswink
  • 99 Answers
SOURCE: need the wiring manual for a White Rodger
Please call the hometechline at 18002842925 to ask for a copy to be send to you, be ready with a valid emial address.
Posted on Jun 26, 2010
Just replaced the circuit board after a technician told me that was the problem. White Rodgers 50A56-956. Getting the same result as the old board: clicks on, shuts off
White Rodgers relay clicks shuts off Surveillance Cameras ...
www.fixya.com > ... > Tags > relay clicks shuts off > Surveillance Cameras
White Rodgers surveillance cameras relay clicks shuts off related questions and answers. Ask your White Rodgers questions. Get free help from surveillance ...
White Rodgers car will start up but shuts off Surveillance ...
www.fixya.com > ... > car will start up but shuts off > Surveillance Cameras
White Rodgers surveillance cameras car will start up but shuts off related ...Thermostat works, clicks when turn on heat, shows Stage 1 on display (hooked up .
relay clicks shuts off Surveillance Cameras Questions ...
www.fixya.com > Forum > Tags > relay clicks shuts off
Surveillance Cameras relay clicks shuts off questions and answers. Ask your relayclicks shuts ... I have a white-Rodgers 1F86-244 thermostat. When I ... a new ...
Jan 16, 2016 | White Rodgers Home Security
Does white Rogers thermostat 1f56n-444 have a reset button
White Rodgers 1F56N-444 User's Manual - ManualAgent
www.manualagent.com > White Rodgers Manuals > 1F56N-444
White Rodgers 1F56N-444 PDF User's Manual Download & Online Preview. ... Download Air Conditioners User's Manual of White Rodgers 1F56N-444 for free. .....Set anticipator to match the setting of your old thermostat you noted in Step 3, ..
Aug 04, 2015 | Home Security
What cold setting should my fridge be on?
Put both dials on cold and wait 48 hours then adjust from there.
Aug 27, 2012 | Frigidaire Refrigerators
White rodgers customer service phone number
we are not white rodgers /emerson --the following links can assist you but if the trooble shooting doesnt fix problem just replace the stat
White Rodgers White Rodgers White Rodgers Thermostats Thermostat AC Wholesalers How to Troubleshoot White Rodgers Thermostat eHow
May 30, 2017 | Heating & Cooling
I own a White-Rodgers manual thermostat...Type 1F56N-444 (horizontal version). I own a 1-Heat 1-Cool single stage Carrier Electric Heat HVAC system. Pls answer two questions regarding the thermostat: 1)...
No that is an heat anticipator setting that should be set to the same amperage as the gas valve o your furnace.....do not adjust unless you can tell this or you coulld ruin the thermostat...
Jan 04, 2011 | Heating & Cooling
Too warm
First of all check to see if the compressor is running. If it's not running and you have no leakage of refrigerant. it is probably the start relay at fault, or the thermostat control is faulty. Check with a multimeter on ohms and check between common & start see what ohms it reads then check between common and run. see what that reads. then check between start and run, this should read what the other two read added together. if you have no readings then the compressor may be burnt out.
May 17, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
My name is Tim Burke from White-Rodgers. If you hear the "click" the thermostat is calling. It would appear that their is a wiring issue to the funace. Please contact our customer service toll free hot line and they will be happy to walk you thru it and assist you. 877-978-7828
Regards,
Tim
tim.burke@emerson.com
Tim
Oct 19, 2009 | White Rodgers White-Rodgers 1F85RF-275...
Home Security Logo
27 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
