Question about Sharp MX-3501N All-In-One Printer
Cannot change paper type to "plain", stays on "Extra"
I cannot get to the "bypass Tray Type/size setting" screen when I want to change the bypass tray to plain. We have had this machine a number of years, we have always been able to change it, all of a sudden we can't
  • Sharp Expert
  • 255 Answers
Change the tray button key or switch on the panel. It wears out with time and cannot be detected even if pressed.
Posted on Jan 31, 2013
5 Suggested Answers
  • 990 Answers
SOURCE: "P" is blinking. There is no paper jam. Paper is not feeding from the paper tray.
Hello sir; there is paper pick up roller dirty or worm, need to clean or replace.
Posted on Apr 28, 2009
  • 120 Answers
SOURCE: Misfeed in tray one with no misfed paper. The
Pull out your paper tray (instructions below) and make sure there's not paper behind the tray blocking the motors from operating.
Else, worn rollers or broken lift motor.
First go to the service sim mode with the key combo # * C *
Type 22 - Start 9 - Start
If your tray 1 counter is above 100,000 your 3 rollers need to be changed. This is easily done by taking out the tray (you must tilt to the left and lift up at the end), unclipping and removing the paper guide, and unclipping and removing the 3 paper tires.
If your counter is under 100K try washing your rollers with soap and water, rubber cleaner and alcohol if you have it, but not Windex or 409. Your matched set of feed/sep tires should have some rough tread on them, if they are baby **** smooth its' replacement time.
If it pulls paper from a fresh stack and then stops pulling after a few sheets, the motor that continunally lifts the paper stack to meet the rollers has broken down, and can be replaced from the back of the machine.
Posted on Feb 24, 2011
reyjoshua07
  • 1157 Answers
SOURCE: We continually get a paper
Hi browngrand,
If the misfeed light does not go out, please look for any torn pieces of paper inside the machine leading from the bypass tray and remove them.
Please follow the steps below to correct the problem.
1.
2.
3.
4.
5.
6.
7.
Hope it helps.
Thank you for using FixYa.
Posted on Sep 15, 2011
SOURCE: AR-M207 default paper tray for fax
tamashebi http://chemitamashebi.do.am/
Posted on Feb 09, 2012
Sharp mx3110n printer won't use bypass tray? Trying to print on glossy paper using that tray and it won't, it automatically switches to tray 1. Or can I just put glossy paper in tray 1?
Hello Laura,
Here is the pdf that explains how to set up th bypass tray; http://support.appstate.edu/sites/support.appstate.edu/files/MX3110%20USE%20SPECIAL%20PAPER%20IN%20THE%20BYPASS.pdf
The text of it is as follows;
TO USE SPECIAL PAPER IN THE BYPASS
? Press either the picture of the copier or press
paper select
? Load paper in the bypass
? Make sure the correct size shows up under
bypass tray
? If paper is not just plain paper press type and
size
? Choose paper type
? If you are printing to the bypass from your
computer you must also tell the print driver
under the paper tab what type of paper is in
the bypass if its not just plain paper
? The copier and the PC must match paper
types
? Press the X button to Accept
Good Luck!
Rich Lilja
Feb 21, 2015 | Sharp Office Equipment & Supplies
How do i print on cardboard (heavy paper card)
The mx2300n only supports up to 209gsm heavy card. You must make sure that your heavy card is not over this rating.
Set the bypass tray as 'Heavy' by clicking on the trays on the main copy mode screen, select type & size for bypass. Select heavy, and Auto AB as this will allow the tray guides to detect the size of your paper. Load the tray with up to 20 sheets of Heavy paper.
Open your document, select Print, then properties. Under the 'paper' tab, select paper source as bypass tray, and paper type as heavy (if you miss one of these steps, the ,machine will ask to load paper due to size or type mismatch).
That's pretty much it.
Oct 16, 2013 | Sharp MX-2300N Color Copier
We have a 4250. When printing from our software we get a message that reads "manually feed tray 1" or "click the check mark to print from tray 2". No matter what settings i change i...
This is often caused by software asking for paper that is not loaded in the printer. You can use the paper path test function in the diagnostics menu to ensure that tray 2 is working properly. Also check your driver settings to make sure that the paper size shown in the driver matches what is actually loaded. You need to also check and make sure that the paper type for tray 2 is set for plain paper, otherwise the printer will only print to that tray if you ask for the paper type that is set.
Jul 12, 2011 | HP LaserJet 4250n Printer
Lexmark T632 has 2 (ea) 500 sheet drawers, but once the paper runs out in Drawer 1 it will not automatically pull from Drawer 2. Please advise how to fix this problem.
go to Menu, reports, and print out the top report.
This will show you what the printer sees as the default tray, and what paper size and type are set for each tray.
If you have plain paper in each tray, make sure that the setting page also shows that each tray is set to letter, plain.
This printer sets the tray type automatically, based on the way the tray is set. There are little tabs on the side of the tray that change as you change the size of the paper with the paper guides.
If the paper guide is set even one click off, this can cause the printer to read the paper size incorrectly, and thus will not change to the next tray. ( if it thinks that tray 2 is A4 paper, but you are printing letter, it will not change to tray 2).
if the trays ARE set correctly, but the printer is still reading it wrong, then there could be something wrong with the sensor ( metal fingers and switch ) inside the printer.
Feb 15, 2011 | Lexmark T632 Laser Printer
Lexmark e352dn-load manual plain letter message
In most cases if the printer is asking for an unexpected manual feed it is because the paper tray is not set to the right paper size or type. To set the paper size to the most common size and type (letter size plain paper) use the following instructions.
1. Press the Menu button.
2. Press the right arrow key until Paper Menu then press Check Mark.
3. Press the right arrow key until Size/Type then press Check Mark.
4. Press the right arrow key until Tray 1 then press Check Mark.
5. Press the right or left arrow key until Letter then press Check Mark.
6. Press the right or left arrow key until Plain then press Check Mark.
7. Press the back button until Ready is displayed.
This will set up your printer tray for plain letter paper and should relieve the manual feed error unless yourcomputer is sending other paper size/type settings.
Aug 20, 2010 | Lexmark E352dn Laser Printer
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
Printing envelopes
1. Load the envelope paper into the bypass tray.
2. From the Copy Screen on the operation panel, select Paper.
3. Select the bypass tray.
4. Select Change Tray settings.
5. Select Normal for the paper type (do not select Envelope for paper type).
6. Select Custom size.
7. Enter the envelope size.
8. Select OK three times to return to the copy screen.
Jun 29, 2009 | Minolta bizhub 200 All-In-One Printer
Hp laserjet must manually push button to print
Please print a configuration page from the control panel of the printer
- Menu > Information menu > print configuration.
- Check for paper handling details.
Following setting should reflect.
Tray 1: Any size / Any Type
Tray 2: A4 size / Plain Type
If the above settings are not reflecting in the configuration page, please change accordingly by browsing on the control panel of the printer to:
Paper Handling Menu >
Tray 1 Size: Any
Tray 1 Type: Any
Tray 2 Size: A4
Tray 2 Type: Plain
Let me know if that helps to solve the issue.
Regards,
Nikhil.
Jun 14, 2009 | HP LaserJet 2420 Printer
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
Sharp MX-3501N All-In-One Printer Logo
52 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
