Question about Bushnell Medalist Rangefinder
Battery door replacement - Bushnell Medalist Rangefinder
Total power failure after replacing battery door on Canonsx10is
Battery doors are notorius for being difficult to replace unless you have circuitry skills, at least for the ones with more than just a detent switch. Many have wires connected internal to the hinge. You may have inadvertantly severed the door wiring. Not having access to a technical manual, you would never know without calling Canon.
Jul 26, 2014 | Canon Powershot SX10IS 10MP Digital Camera...
Kodak CX6200 Battery Door Replacement
Link to purchase of battery door with instructions
Dec 05, 2007 | Kodak EasyShare CX6200 Digital Camera
Need to replace battery door.
i have not replaced the battery door but have disassembled an S5000 following the service manual
it looks like once you complete the first step 'Removing the R CABINET ASSY' you can withdraw the hinge pin and replace the battery cover without any more disassembly [see attached image]
Nov 29, 2011 | Fuji FinePix S5000 Digital Camera
Hi, I have a Sony DSC T70. The battery door for the camera doesnt close now as the latch just came sliding out and I am not able to fix it.... Do i have to replace the whole battery door for it and if...
Hi, With a battery door like that you can tape it shut, while not the most visually appeasing fix it is the cheapest. Your other option is to order a battery door for the camera, http://www.ownta.com/sony-dsc-t70-camera-repairing-battery-door-battery-cover-replacement.html has it for $45, or you can contact Sony and order one directly from him. The only thing I'll caution you about with replacing the battery door is that you do have to disassemble the entire camera to install it.
May 12, 2011 | Cameras
Require replacement battery door for Canon EOS 40D
well if it doesn't work just with the battery doors - you can always get a battery grip. battery time will increase and you will not see that the battery door is damaged.
Jun 15, 2010 | Canon EOS 400D Digital Camera
How to replace battery on toshiba m45-s169
  • Shut down the computer. Disconnect any cords connected to the computer.
  • Turn the computer over.
  • Locate the access door latch.
  • Push down to release the latch, this sets it in the open position, and remove the access door that covers the battery.
  • To replace the access door:
  • Line the access door up with the bottom case and the tabs in the battery bay.
  • Lower battery access door into place.
  • Make sure the toshiba laptop battery is level with the bottom case of your MacBook.
  • Press the latch into place, so it is in the closed position.
  • May 14, 2010 | Toshiba Satellite M45-S169 Notebook
    Battery Door
    Contact Canon at their website. Battery doors are a common replacement item and they're relatively inexpensive and easy to replace.
    Oct 23, 2009 | Canon Photography
    Battery Door
    remove two small phillips head screws next to battery compartment,,this will allow you to raise the camera case enough to insert the tabs from the new battery door cover,replace the screws,,,i just replaced mine not to difficult
    Jul 15, 2008 | Kodak EasyShare CX4200 Digital Camera
    Battery door doesn't close tight
    Usually part of the plastic battery door breaks off so the sliding latch (when you push the battery door in toward the camera after replacing batteries) can't latch. If this is the problem you can buy a new battery door that will come with a new latch that isn't broken.
    Jul 10, 2008 | Cameras
    Need to replace battery comparment door
    I have a c143 and my battery compartment door is broken . I tried duct tape but that didn't hold.
    May 29, 2008 | Kodak EasyShare C315 Digital Camera
    Bushnell Medalist Rangefinder Logo
    73 people viewed this question
    Top Bushnell Optics Experts
    Joe Lalumia aka...
    Joe Lalumia aka...
    Mark Campeau
    Level 1 Expert
    Are you a Bushnell Optic Expert? Answer questions, earn points and help others
