Question about Science & Laboratory
Parfocal microscope only 1/2 the field is illuminated when i move the stage the field does not move
Are you able to focus on the specimen? Is the problem the same if you switch to a higher magnification lens?
Could be several things, a slider half way in, a turret not clicked in to the notch, ie condenser, a filter partway in.
Posted on Jan 27, 2009
The stage is not moving when the focussing Knobs are moved. The stage moves freely vertically. It's not attached, I'm sure it needs to be re aligned and a screw need tightening, but which screws?
Hi Faye , we will probably need more info
Does the stage move freely on its own without the course focus knobs
Can you move the stage up and down with either of the course focus knobs
Instrument details / picture would help .
Oct 07, 2015 | Science & Laboratory
What is the function and the purpose of the parts of the microscope ?
Starting at the bottom of the Compound Microscope scope working up: The base of the scope houses the illumination system and the field lens. It also provides weighted stablility.
The field lens is where the light comes out of the base. This lens focuses the light from the bulb directly into the substage condenser.
The arm of the scope supports the rest of the scope.
Directly above the field condenser is the substage condenser. The substage condenser collects the light and condenses it further into a more concentrated beam of light. With the substage condenser you can control the amount of light and to some degree the defraction of light. This is helpful in adjusting the "contrast" in the image.
Working up, you find the "stage" which is a platform to support the specimen. The stage may or may not have a specimen holder and a set of specimen holder control knobs.
The magnifying lenses are called the objectives. They look like barrels pointing down at the stage. These are usually marked 4x, 10x, 40x, and 100x. These magnifications are further multiplied by the power of the eyepieces which are usually 10x. So, when using the 4x you are actually seeing the specimen at 40x and when you are using the 10x objective you are actually seeing the specimen at 100x and so on. The 4x is used to "scan" the specimen so that you can find the most interesting area and then focus in further on that region. It is very hard to find exactly what you want to focus in on starting with the higher magnifications. Always start with the low magnifications, 4x or 10x.
The objective lenses are mounted on a rotating turret for easy selection.
Moving on up the scope is the head. It is comprised of the eye tube and the eyepiece. If you have two eyepieces your scope is referred to as a "Binocular Compound Microscope". If you have only one eyepiece, your scope is a "Monocular Compound Microscope".
Sep 27, 2010 | C And A Scientific IExplore Scope
My stage is no longer moving with the knobs.
With one hand push the stage down, and with the other turn the coarse adjustment down. It's a cog alignment issue. The coarse adjustment cog should be turning in order to catch the stage track.
Feb 19, 2010 | Celestron 44320 Trinocular Microscope
What is parfocal microscope
When you switch between objectives, you don't want to have to refocus every time. By getting a [b]microscope[/b] with objectives that are parfocal, you'll be able to move between <b>objectives<b> without much need for refocusing.
Jul 01, 2009 | National Optical MRP-3000 Binocular...
Only 1/2 the field is illuminated
If you have a rotating perforated diaphragm, that means the hole you want to use is blocking the light partially. Make sure your diaphragm is set correctly.
Also, you might want to check that your objective is set and aligned, that could also cause half the field being dark.
Jan 27, 2009 | Science & Laboratory
Problem with MF-02 binocular microscope stage
I think your problem lies in the way the stage is limited upwards. On top of the stage, right behind it where it slides against the arm, there should be a little screw.  This screw limits the movement of the stage to a certain point upwards.  If the limit exceeds the adjustment gear and its opposing track, then the stage just goes up one notch and then it clunks down.  If you screw it down the stage is limited further down, if you screw it up it's limited a bit higher.  The point of this screw is to prevent objective and slide damage.  Try adjusting this little screw a bit further down and see if it still 'clunks' when you turn it up.  After that we may work on properly adjusting it.  If not, please post again with whatever detail you can provide to aid you with this problem further.
May 28, 2008 | Premiere Microscopes MF-02 Binocular...
Microscopy; Relatively large spots on unknown surface obstructing view
HELLO..
There is five part in microscope
1. Eye piece
2. Binocular tube
3.Objective
4. magnification changer or joom accembaley
5. illumination segment
Try to make it out which part is gives a effect to your vision.
as per my suggesition illumination asembely you just clean it first.
keep in touch
regards
INDRAVIJAY
Dec 30, 2007 | Tasco 750 Monocular Microscope
Science & Laboratory Logo
378 people viewed this question
Top Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
