Question about Horizon Exercise & Fitness
What is error 7 message pop up on treadmill screen
    Top Expert:
  • Horizon Master
  • 12,223 Answers
Plelase see this 2 alternatives error and proceed see the diagram attached. God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
what is error 7 message pop up on treadmill screen - 1_22_2013_6_17_11_pm.png
Posted on Jan 22, 2013
Impulse treadmill
new treadmill , upon turning it on for the first time the console lit up but when pressing start an error message of error 7 came up and nothing would work .
Jan 07, 2014 | Exercise & Fitness
PLO5 error message on Quinton Clubtrack treadmill
Try to clear the error message. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Jan 25, 2013 | Quinton Stairmaster Clubtrack 3.0 GymTough...
Error 29 message coming up on screen
see the error code and fix it. God bless you
Error 29, Excessive AC Input Current, this mean that some elements inside of the treadmills is consuming more AC currente, like transformer, main motor.
see the block diagram attached.
Nov 28, 2012 | Precor 954i Treadmill Refurbished. 115...
My Ion treadmill with LCD screen has an error message
1) adjust the speed sensor, clean it, tight the connector or plugs.see the diagram
2) adjust the Reed switch, clean it, and tight the plug or connector.
tight the ribbon cable inside.se the diagram
3) try to RUN the software calibration for diagnostic, troubleshooting, and fix it.
God bless you
Sep 19, 2012 | Bladez Ion 9.9 Fold-up Treadmill
I have a sports art 1180 treadmill that beeps err 7 how do i fix this thanx
ERR E-7 indicates that the DC incline motor and the variable resistor (VR) are not synchronized. Signal from the VR is not being received properly. Mechanical and/or electrical calibration is needed to reset this error message.
http://www.sportsartamerica.com/SAF/support/technicalsupport/techtips/Treadmills/DC_Incline_Calibration.pdf?utm_source=fixya&utm_medium=cpc&utm_campaign=mendi
Jul 05, 2012 | Exercise & Fitness
Hello. My sportsart give's error 7 ? I don't now what the problem is. Can you discribe the problem en the solution for this? Thanks Gert Jonker
When I turn on the machine it beeps and reads Error 7 on the screen. Do you have a support phone number for Australia
Feb 12, 2011 | Sportsart 6300 Treadmill
E 7 error code is displayed on my SportsArt 1210 treadmill. When keep it turned off for a long time, then the machine works fine but if I switch if off and back on again, E 7 is displayed and nothing...
i have the same treadmill with an error 10 message. i have the booklet that came with it and it says that an error 7 message indicates(too much to write). I can fax the error message page and the wiring schematic to you. my email is srt8ght1999@yaho.com. not posting my number here.
Jan 05, 2011 | Exercise & Fitness
Machine not running belt and giving error message1
connection error check all your connections from machine to screen, that usually is just a communication error depends what treadmill
Feb 26, 2010 | Exercise & Fitness
MESSAGE "ERROR SPEED STALL" KEEPS COMING UP
returned the machine and got our money back, thanks.
Jun 20, 2009 | Bowflex Treadmill Series 7
Exercise & Fitness Logo
148 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
