Question about Epson Stylus CX6600 All-In-One InkJet Printer
Epson cx8400 wont print black
My epson stylus cx8400 won't print in black, just the other 3 colors. I've tried replacing the cart, doing 3 nozzle cleaning cycles, and physically cleaning the cartridge and where it meets up with the nozzle (just what is accessable when you take out the cartridge). Is there any way to clean any more or any other reason why the printer won't print black?
  • adiamondgeez
    adiamondgeez Jan 22, 2013
    This is the 2nd ink cartridge I've tried, both oem Epson carts
  • DENNIS MITCHELL Jan 22, 2013
    the carraige were the inkcartridge fits in seems to be bad not recognizing new cart next step would be replacing this assembly if available.
    Genius:
  • 1,003 Answers
Sounds like a bad ink carriage.
Posted on Jan 21, 2013
SOURCE: My Epson RX620 black cart absolutely will not print
Problem Solved!!!!
I bought the special cleaning cartridge as suggested and it worked very well. My RX620 is working like new!
Thanks!
Posted on Jul 11, 2008
issy2
  • 460 Answers
SOURCE: Color light will not go out
remove the cartridge close the printer, then again turn on printer and put the cartridge back effectively..
Posted on Sep 09, 2008
SOURCE: Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
Posted on Mar 12, 2009
tigertail
  • 163 Answers
SOURCE: epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Posted on Apr 03, 2009
  • 2666 Answers
SOURCE: printer will not print in black ink. Epson stylus color 400
Try cleaning the print heads.
Posted on Jun 19, 2009
How to turn off color ink in Epson Stylus R300
There is a place in the printer driver (epson part) that hays checkboxes for "color" and "Black & White". If you are trying to do this becasue you are out of one or more of the color inks, and can't print- you still won't be able to until you replace the empty ink(s), even though you told it black & White
Aug 30, 2012 | Epson Office Equipment & Supplies
Epson stylus cx8400 will not print black, how do I fix
From the Epson web site:
Q:
Can the printer still print if an ink cartridge is expended or not installed? A: No. The printer will not operate if any cartridge is expended or removed. It's best to always have extra cartridges on hand.
I do this for fun not $$$.
Jim
Oct 16, 2011 | Epson Stylus CX8400 Series
My epson stylus cx6000 has stopped printing black. I've cleaned the print head, changed the cartridge and it still won't print black. What else can I do?
Be sure you are using genuine epson ink. Epson printers are "smart" and will not allow generic ink to work properly. Even after you replace a generic with a genuine it may take several print outs and alignments to get it to print again.
May 05, 2011 | Epson Stylus CX6000 All-In-One InkJet...
I have an epson cx8400 and i replaced the black ink cartridge but theres an error message saying that i need to replace other ink coartridges. I just want to print in black, how do i bypass the error...
hello
i have this link below that gives you allinformation about your Epson printer. specifically the manual , required for review to address the issue with the ink cartridge error.
Run a Printer Check A printer check will help you determine if the Epson Stylus CX8400 Series is operating properly. 1. Turn off the Epson Stylus CX8400 Series and your computer, if connected. 2. Disconnect any connected USB cables. 3. Load plain paper in the sheet feeder. 4. Press Setup. 5. Select Maintenance and press OK. 6. Select Nozzle Check and press OK. 7. Press cx7400_cx8400_ug.1.109.1.jpg Start. 8. The Epson Stylus CX8400 Series begins printing the nozzle check pattern. • If the page prints, your Epson Stylus CX8400 Series is operating. Your problem may be caused by your computer, cable, software, or setting selections. Check for additional solutions or re-install your software. If the pattern on the page has gaps, clean or align the print head. • If the page does not print, the Epson Stylus CX8400 Series may have a problem. Check for additional solutions. If they don't work, contact Epson.
general= http://www.epson.ca/cgi-bin/ceStore/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342
manual = http://files.support.epson.com/htmldocs/cx84__/cx84__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Nov 13, 2010 | Epson CX8400 All-In-One InkJet Printer
My printer wont print black and white only
My Epson Stylus cx8400 uses ink so fast. I would like to turn this into a black and white printer only. The problem is, I am out of one of the color ink cartridges and it won't let me proceed until I replace it. Is there a way, in the mode it's in now, to get this to print with the black and white only? I am nearly out of ink on all color cartridges now and do not want to purchase more at the high cost they are.
Thank you!
Oct 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Ok I have a cx8400 all-in-one Epson printer. I was out of black ink so I started using composite black. Also ran out of color ink so I bought the black cartridge and installed it. Now the printer says i...
If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement. You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expendedI have come across this issue many times and unforunately you have to replace the colour carts in order to continue to use the printer.
Sep 12, 2009 | Epson CX8400 All-In-One InkJet Printer
All four new ink out in printer still wont print black ink epson stylus cx8400
Your Printhead for the black cartridge is blocked. You might need to have the printhead replaced.
Aug 05, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus Photo R200 - print with black ink only
Nope.....
Epson will not print unless all carts have ink in them to some degree. If the light is on for any reason, printing will be halted.
For future reference, once the color carts have been replaced, you can set the printing defaults to print in either gray scale or BW only. Keep in mind that Epson printers tend to mess up if you don't use the ink at least once a week.
Aug 01, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
205 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
