Service code: FK1
What is code: FK1, FK2 and TK1
  • Sasa Jan 21, 2013
    I don't know why but this question went to satellite radios instead of Printers
    Genius:
  • 1,669 Answers
Since you neglected to state the type of device, make or model, I am assuming everything and sending you what I guess!
http://search.aol.com/aol/search?&s_qt=sb&q=service+codes+fk1%2Cfk2%2Ctk1&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Posted on Jan 21, 2013
What is sub code of fk1
FK1 refers to the maintenance life counter for the fuser unit.
The fuser rollers have a fixed life count & when that count is reached FK1 is displayed. If the rollers are worn they should be replaced but if they are ok you can reset the fuser maintenance counter in SIM 24-4 FUSER UNIT
Aug 08, 2014 | Sharp MX-2300N Color Copier
Code required to enter after car battery reconnected
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
May 21, 2013 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Error E225
imageCLASS MF4320d with error code E225 is the CONTACT IMAGE SENSOR UNIT need to replace. Part Number is FK2-2869-000
Apr 26, 2013 | Cannon Office Equipment & Supplies
When i photocopy the paper prints with a blank section through the middle of the page, why would it do this
The scanner bar (FK2-1377-000 contact image sensor) may be defective.
This part is located under the glass, so it may be difficult to install, but it's not too expensive.
Whit
800-367-4836
http://www.iteminconline.com/itemdesc.asp?ic=FK2-1377-000&eq=&Tp=
Sep 12, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
Code:fk1 sharp 2301 N
That is a maintanence code. Usually says that the fuser rolls are at a certain copy count.
Here is what to do.
Press in order on the consol. # * C * That will enter the machine into what is called SIM mode.
Then enter the number 24 then 4 for that code, then press execute. You may want to just do the clear all maintenance code too.
Apr 26, 2011 | Sharp MX-2300N Color Copier
Can you tell me what code FK1 means?
Your fuser has gone past 200,000 sheets of usage and it's time for a rebuild. You could reset the counter with sim code 24 but eventually it will clog up with waste toner and your rollers will tear up. Sharp has rebuild kits for your or you could just buy a new one.
Jan 07, 2011 | Sharp MX-3501N All-In-One Printer
Error 001, error 808
the e001 code is something is going with the fixing assembly. one of the thermistors could be going bad.
E808 is a Zero Cross error. We most commonly see power supplies or bad wall voltage cause this code.
The following information is coppied from the IR2016 Service Manual.
E808-0000 DRIVE CIRCUIT FAILURE
A zero crossing signal cannot be detected.
A fixing drive motor failure has been detected.
E808 0000 Fixing drive circuit failure
  • The heater does not turn on.
  • A fixing drive motor failure was detected.
  • Check the connector of the fixing film unit.
  • Replace the fixing film unit.
  • Replace the fixing drive motor.
  • Replace the DC controller PCB.
  • Replace the power supply PCB.
M201 - Fixing Drive Motor - FK2-1067 - J202 on the DC controller PCB - E007, E808
Power Supply - FK2-1074
Jun 14, 2010 | Canon iR 2016i Black and White Copier
Code E00024-0001 canon IR 3530means?????
E024-0001 Error Code:
Toner gets in the developing assembly toner sensor (TS1) and may be shorting out the sensor. Blow out any toner in the sensor wiring and check to see if measure resolved the symptom. The toner level sensor has an open-circuit, replace the toner sensor.
Toner Sensor FK2-0358
Mar 08, 2010 | Canon Office Equipment & Supplies
I have a sharp copier MX2700N with an error code of FK1. What do I need to do to fix it?
fuser count has reached 200,000 copies. hit P*C* then 24, start, then 4 start. select Fuser Unit and Fuser Acum Day then execute at bottom then yes. Hit CA button. copier should reboot and clear code.
Apr 17, 2009 | Sharp MX-2700N Color Copier
160 people viewed this question
 Grubhead
Grubhead
