Question about LG LDS4821BB 24 in Builtin Dishwasher
Lg dishwasher IE error
I need to locate a service manual. The s/v for inlet water is not passing water but there is good pressure to the valve. I do not have a meter to check resistance or voltage at the coil.
    New Friend:
  • 169 Answers
If you had a way of applying power to the s/v you cold determine if it was working or not. If it is then you could look elsewhere for the problem.
Posted on Jan 22, 2013
  • Duane Dorsey Jan 23, 2013
    Found broken wires to s/v. Repaire and now working fine. I would still be interested in a service manual if someone has a pdf .
  • Vince Pilgreen Jan 24, 2013
    Glad you got it repaired.
SOURCE: IE error message
Hi, had the same problem on a LG LD 12aw5. (No water entering). Check the inlet solonoid. There should be 220V over the solonoid. I replaced the solonoid, at first, just to have the same problem. The problem was a bit more serious, the Triac driving the solonoid burnt out, and the solder on the mainboard keeping the transformer were shot to. I replaced the Triac, soldered the Transformer - and wolla - working. If water enters - but you sill get the IE error it could be the float(checks the water level). This device tells the machine when there is enough water. If this is stuck, the machine will think no water is entering. conrad_dot_dewet@gmail.com - replace "_dot_" with "." to email me.
Posted on May 06, 2007
  • 110 Answers
SOURCE: E1 error on LG dishwasher
As per my email reply chazmano5, the problem is likely to be the water pump/motor assy.
They have a very common fault of the impeller breaking on the motor shaft. The motor still spins, but the impeller doesn't, so there is no water being pumped.
The machine senses there is no water pressure and shuts down, displaying E1 (eg: it thinks no water pressure means there must be a water leak) Unfortunately the motor/impeller is only available as a complete assembly.
Posted on Dec 11, 2008
SOURCE: LG Dishwasher LDS5811ST 1E error code
I had a LG certified repairman come out and fix. The electrical wires within the door were melted into the "tar" (sound deafening spray) and one wire actualy sheered. Apparently the drying cycle heats the tar and the wires become embeded and melt into the tar. This is what was causing the error code. After the wire was tested and spliced everything worked great. Long term...The door/electrical harness was replaced by LG.
Posted on Apr 06, 2009
MNTECH
  • 1543 Answers
SOURCE: i have an lg dishwasher mod#LDF7811ST, get error codeIE, changed the inlet valve, machine worked once then got IE error code again. Any suggestions?
If you are getting a IE or similar error on your LG dishwasher and have not been able to solve the problem using information based on that code, check the serial number of the dishwasher. If the first three numbers are between 501 and 702 you may have this problem:
The black mastic sound insulation material inside the dishwasher door can soften from the heat inside the dishwasher, allowing the wires inside the door to become embedded in it. If this has happened, the insulation on the wires can soften and begin to dissolve, resulting in shorted or broken wires. This may cause various error codes which may send you on a wild goose chase.
Take the screws out of the door and inspect the black insulation and the wires. If any wires are embedded in the black mastic, you may cut them and bypass them with a new section of wire, then make sure to add an insulating material to separate the wires from contacting the black mastic. In severe cases, the inner door panel must be replaced (they no longer use that type of mastic) and the wiring harness for the dishwasher would also be replaced. (a set of all the wires and plugs).
Posted on Apr 29, 2009
Krazytech
  • 725 Answers
SOURCE: ie error code
The Water Supply Tap is closed. The Water Supply is shut off. The Inlet Hose is kinked. The Water Pressure is very low. (below 10 psi) Inlet Valve is OK? The filter of Inlet Valve is clogged by impure water. The Hall sensor is OK? The Impeller of Air Guide is bound
Measure the electric resistance of Inlet Valve. (950-1300 ) Clean the filter of Inlet Valve. Check the frequency of Inlet Water by the Test Mode. Replace the Air Braker.
Posted on Sep 27, 2009
HOW DO I STARTS MY WASHING MACHINE AGAIN CAUSE IT ALWAYS `IE` ERROR EVEN I ALREADY CLEAN THE FILTER,CHECK HOSE,THIS ERROR HAPPENS WHEN SOMEONE USE IT MANUAL WHEN NO WATER IN SERVICE,I MEAN HE MANUALLY
The IE or E1 error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve
If you are trying to use the machine manually, there needs to be enough water in the machine to tell the level sensor when to switch off the water inlet solenoid valve. Failing this, the machine will only show IE (Inlet Error) and refuse to work.
Feb 15, 2015 | LG WD-1070QDP 7 Kg Direct Drive Washer
Tip
I get error IE on my LG dishwasher.
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Cut power by tripping circuit breaker or unplugging power cable for ten minutes.
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
on Jan 31, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
LG LD2131SH Dishwasher displays a ie error
Hi santjiesfras,
The error code your receiving is an "Inlet Error" message. This means that no water is going into the Dishwasher. Please check the following:
1) Is the tap open.
2) Is the inlet hose kinked?
3) Is your water pressure fine? Because anything less than 0.3kgf/cm(bar) is not going to work
If all of the above is fine, then take off the inlet hose of the dishwasher, and clean the filter which is between the hose and machine (small circular filter). If still not working, then you will need to replace the inlet valve. I would suggest getting a L.G service agent to do so.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively. A 4 four thumbs up will do nicely too :-)
Apr 13, 2011 | Dishwashers
Hi I have an LG LD - 14AW23 dishwasher. It shows an IE error (no water) but it fills, stops and then gives the error message. What's thye problem? Many thanks, John
Hi
Error code IE on LG dishwasher means Inlet error. This error comes up when the Water Supply Tap is closed or Water Supply is shut off. If water supply is turned on then make sure that the Inlet Hose is not kinked and water Pressure is not low (should be above 10 psi). Next thing to check for is Water Inlet Valve, measure the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of Inlet Valve is not clogged.
Hope this helps... Please post back for further assistance.
Daniel
Mar 26, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
Ie error code
Sep 20, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
My LG LDS5811ST has error code of IE Where do I
1-Check if the water Inlet Hose is kinked.
2-The Water Pressure is very low.
(below 10 psi)?
3-Inlet Valve is OK?
by water filter?.
Jul 03, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
IE problem
Possible cause:
Remedy:
Dec 23, 2008 | LG LDF8812 Stainless Steel Built-in...
LG Dishwasher ie error code problem
Possible cause:
Remedy:
Oct 31, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
IE Error - stressed motor
Possible cause:
Remedy:
Jul 27, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Error code IE
a pressure sensitive dome is common on some units. as pressure builds, an air switch is activated.
otherwise there has to be a water contact switch.
the air switch dome can be located near the pump under the unit.
good luck
mark
Nov 11, 2007 | LG 24 in. LDS 5811 Built-in Dishwasher
Open Questions:
LG LDS4821BB 24 in Builtin Dishwasher Logo
50 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
