Question about Sylvania Televison & Video
Keeps turning off after 2-3 seconds of being turned on
  • DENNIS MITCHELL Jan 22, 2013
    go to shopjimmy.com if you just want to replace the power supply and be done
    Genius:
  • 1,003 Answers
Replace power supply board or look for a blown capacitor in the power supply circuit.
Posted on Jan 21, 2013
  • papilover200
    papilover200 Jan 22, 2013
    thank you I will try that
Vtech mobigo 2 the screen keeps flashing it wont even turn off will not respond to nothing
try this: take the cartridge from both compartments. take out the cartridge. press the on button for 30 seconds. place the batteries back into the toy. try turning it on.
May 09, 2014 | Vtech MobiGo 2 Touch Learning System -...
My printer won't turn on. when trying to print it gives error message 300 which says to check all connections. I've checked all connections and it still won't turn on.
You may want to check to make sure the cables all are good with a good connection, and if that does not work try to reset the printer. Here are 2 possible solutions I have found to reset the printer.
canon_pixma_mp520_buttons_03.gif Procedure:
a) Switch the printer OFF
b) Press buttons 1 + 2 + 3 and 4 (simultaneously using four fingers)
c) Keep pressing this four buttons for 10 seconds
d) Release the On/Off button (number 4) (Keeping pressing the others)
e) After a few seconds (when the printer go ON) you can release buttons 1, 2, 3
Here is another reset proceedure I have found as well if the first one did not work:
1) Turn the printer ON
2) Press and hold "Cancel" (No. 2) button for 5-20 seconds
or
2) Press and hold "OK" (No. 3) button for 5-20 seconds
Mar 08, 2011 | Canon MP520 All-In-One InkJet Photo...
Car starts and cuts out after 2 to 3 seconds. fuel
When the ignition switch is turned on the pcm turns on the fuel pump by energizing the fuel pump relay. The PCM keeps the fuel pump on as long as the engine is cranking over or running.It does this by recieving pulses from the ignition module. If there are no referance pulses the PCM will turn the fuel pump relay off in 2 seconds with the ingnition on.
Most models also include a secondary control path through the oil presure switch witch will turn the fuel pump on after it detects oil presure.cranking time will be longer if the fuel pump doesn't recieve current until oil presure switch contact is closed.
Jan 28, 2010 | 1998 Chevrolet K2500
New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
Suzuki vl 1500 wount turn over been getting more and more harder to turn over. replaced battery starter motor selonod think it is a compreshon problem as i can bump start it no problemm any one had this...
I had the same problem on my VL1500. I THINK it gets "flooded" with fuel and then the cylinder is full and will NOT turn. I have used jumper-cables to start the bike when it will not turn over.
I now start my bike with this procedure:
1. Do NOT touch the throttle.
2. Switch on the power.
3. Do NOT touch the throttle.
4. Press the "Start" button and crank the engine a little (1 - 2 seconds)
5. Do NOT touch the throttle.
6. Keep cranking the engine (another 1 - 2 seconds)
7. Open the throttle a VERY LITTLE (approx. 1/10 turn of throttle). keep the throttle slightly open while the engine cranks.
8. Keep cranking the engine and wait for engine to start (another 1 - 10 seconds).
It is still not a perfect start, but at least the engine cranks over now.
Remember that the VL1500 has a "decompression" system that opens the outlet valve for 2 cranks of the engine.
I suggest you FIRST make sure the engine cranks over (NO throttle), and THEN concentrate on starting the big V Twin.
Apr 24, 2009 | 2003 Suzuki VL 1500 Intruder LC
Stops while driving
this is usually due to a dirty throttle body. just beware if you do try to clean it you will need to preform the idle relearn procedure. this does work, ive done it personally.
A. Accelerator Pedal Release Position Learning Procedure.
1. Make sure that the accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds (how would you know if you get it right?)
B. Throttle Valve Closed Position Learning
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch is “ON”.
3. Turn ignition switch is “OFF” wait at least 10 seconds.
Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound (i never get this right because i never heard anything)
C. Idle Air Volume Learning (Throttle Position Learning)
It's best to time with a watch/clock.
1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Conform that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops
blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11 Wait 20 seconds
12Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications. (this is fine because SES light lets you know if you did it right the way it blinks)
Oct 25, 2008 | 2005 Infiniti G35
Service interval indicator
1. insert the ignition key and turn to it to position 2,imediately press 0on the instrument panel twice within one second.
2.turn the ignitio key back to position 1.
3. press and hold 0 button ,then turn ignition key to position 2(keeping the button pressed). the display will show the current remaining distance or time ,after 10 seconds an acoustic signal will sound. the startig distance or time will appear for about 10 seconds on the display
4. relaese button 0
Jul 09, 2008 | 2000 Mercedes-Benz C-Class
Televison & Video Logo
221 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
