Question about Science & Laboratory
Only 1/2 the field is illuminated - Science & Laboratory
  • 45 Answers
If you have a rotating perforated diaphragm, that means the hole you want to use is blocking the light partially. Make sure your diaphragm is set correctly.
Also, you might want to check that your objective is set and aligned, that could also cause half the field being dark.
Posted on Jan 30, 2009
Zeiss humphrey system startup state 19
I believe "state 19" is a weak main illumination bulb. Not sure if it's the same on your 740, but that's what the problem was with our 750i. Even though the bulb appears to be working, they dim over time and won't pass the start up calibration checks. On ours, there is a round access panel on top of the unit to service this bulb. Just be careful removing the bulb and don't bump any of the clear optical wheels. Part # 2660021106082 (for 750i. not sure about 740) Call Zeiss to confirm. Realize this is an old post so info is for future readers.
Mar 27, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
The headlights are too high. The low beams appear to be illuminating more of a field than the brights should. Oncoming traffic constantly flashes their lights at me when I'm on low beam, and the...
Hi
Your headlight alignment is completely out.
Its could be the bulb last change was, is not sitting in the correct position.
Alternatively you will need to get the headlight alignment adjusted.
in UK its about 5 pounds.
you need the machine.
Nov 25, 2017 | Toyota Tacoma Cars & Trucks
I dont know how to change the time on my decathlon geonaute watch
I nearly went crazy pushing buttons, but finally got the right combination. From the normal Time Display (as you would normally use the watch, no need to push any buttons) Push and Hold for a few seconds the Lap/Reset Button. The "Set" Mode will become active. Release the Lap/Reset button when Set appears in the Display. Notice in the Display a small Arrow that points to a button, either the ST/STP or Mode Button. (Initially it will be the ST/STP Button). When you depress the button to which the arrow points, the Field Flashing in the display will be set (For ST/STP) or Changed to the next Field (When the Arrow Points to the Mode Button). Simply toggle through the fields (using the Mode Button) and set (using the ST/STP Button) as needed. You will also be offered the ability to set the Month, Date, Day, 12/24 HR, and a M-D (It stands for Month - Date, in Europe it's more common to display as Date - Month). I did not change this field since by default on my watch it displayed M - D first. The setting cycle will be finished off when you have set the various fields by again pushing the Lap/Reset Button. Not related to setting the watch, but possibly useful, the Watch will completely reset if all the buttons are pushed at the same time, including pushing the Display Light (or in the case of this watch, the illumination used for the Display Characters). Hope this helps, it worked for me.
Nov 01, 2011 | Watches
The Holmes Comfort Temp ceramic heater works fine on Low setting, but once it is set to High temperature the illuminated digital display fades out and the unit turns itself off. Unplugging and letting the...
These heaters were not designed to be serviced in the field. If it's not over a year old, it may still be in warranty. Contact Holmes through there website www.holmesproducts.com for more info.
Jan 19, 2011 | Holmes Products HCH4953-U Ceramic Compact...
I have a 1989 jeep yj. 6 cyl 5 speed 4x4. the batterie and alternator wouldnt charge so i replaced them both and it didnt make a difference. the jeep runs until the batterie dies. help
Have you checked to see whether the battery lamp illuminates with the key on only. If not then the fuse to is blown or that wiring to the field circuit is faulty.
Did you replace the parts with new ones?? You did not state.
No battery warning lamp no charge simple.
Dec 06, 2010 | 1989 Jeep Wrangler
I need a printable image of fuse block / 97 ford windstar
your owner manual sould have fuse chart. Some fuses/ekays in enine compartment. Some in car on left side of instrument panel
in car
Fuse Amps Circuits Protected 1 10 Power Mirrors, Anti-Theft Warning Light, Diagnostic Connector 2 5 Generic Electronic Module, Start Interrupt Relay Coil 3 5 Radio Illumination, Remote Radio Illumination, Electronic Instrument Cluster, Electronic Instrument Cluster PRNDL Illumination, Electronic Instrument Cluster Switch Module, Analog Cluster Illumination, Instrument Illumination 4 — Not Used 5 — Not Used 6 15 Rear Quarter Windows (LH and RH) 7 15 High Mounted Stoplamp, Brake Shift Interlock 8 25 Subwoofer, JBL Amplifier 9 10 Park and Turn Lamps, Side Marker Lamps, License Lamps, Stop Lamps 10 2 High Beam Indicator Electronic Cluster 11 15 Park Lamps 12 10 Remote Radio, Auxiliary Warning Lamp Module, Remote Keyless Entry (RKE) Module, Anti-Theft Controller Module, Radio Illumination 13 15 Radio, CD Disc Changer 14 5 Electronic Chromatic Mirror, Analog Cluster Indicator Lamps, Air Bag Module 15 — Not Used 16 15 Horns, Horn Relay Coil 17 15 Fog Lamps 18 25 Front Wiper Motor, Front Washer Pump, Wiper/Washer Relays 19 10 Generic Electronic Module (Pin 57), Electronic Instrument Cluster 20 25 Integrated Relay Control Module, Ignition Coil 21 10 Air Bag Module, Rear Window Defrost Relay, A/C Clutch, Temp Blend Door Actuator, Brake Shift Interlock 22 20 Rear Cigar Lighter, Power Plug 23 15 Multi-Function Switch 24 20 Rear Wiper Motor, Rear Washer Pump 25 10 Turn Signal Lamps, Instrument Cluster Turn Indicator 26 15 LH Aero Headlamp, Left and Right Trailer Stop/Turn/Hazard 27 15 Hazard Warning Lamps, Instrument Cluster Turn Indicator 28 15 Instrument Panel Cigar Lighter 29 15 Battery Saver Relay, Interior Lamp Control Relay, Interior Lamps, RH and LH Keyhole Lamps 30 25 Backup Lamps, Electronic Cluster 31 10 Rear Air Suspension 32 15 RH Aero Headlamp, Trailer Park Lamps 33 15 Anti-Lock Brake (ABS) Relay, Anti-Lock Brake (ABS) Module, Daytime Running Lamp (DRL) Module 34 30 One Touch Relay, LH Window Motor 35 15 Anti-Theft Controller Module 36 30 A/C Mode Switch 37 20 Door Lock Actuators, Memory Door Lock Relay 38 15 Heated Mirrors (LH and RH) 39 30 Auxiliary Blower Motor, Ref. Valve Solenoid 40 30 Window Motor (RH) 41 5 Autolamp Relay Coils, Autolamp Sensor 42 — — 43 — — 44 — —
Mar 15, 2009 | 1997 Ford Windstar
Parfocal microscope
Are you able to focus on the specimen? Is the problem the same if you switch to a higher magnification lens?
Could be several things, a slider half way in, a turret not clicked in to the notch, ie condenser, a filter partway in.
Jan 27, 2009 | Science & Laboratory
Detection Range of GS-7
It depends on the lighting conditions in the environment you're using them in. If you're in a field out in the country with no full moon, and only stars for ambient lighting... A Generation-2 set of goggles aren't going to see very far. But in the same spot with a full moon directly overhead you could theoretically see in excess of 800 yards.
That particular model has 3 different range settings for the Infrared Illuminator. Close, Medium, and Far. Although there doesn't seem to be any set value for the longest you can see, set by the manufacturer.
May 16, 2008 | Gsci GS7 Goggles
Microscopy; Relatively large spots on unknown surface obstructing view
HELLO..
There is five part in microscope
1. Eye piece
2. Binocular tube
3.Objective
4. magnification changer or joom accembaley
5. illumination segment
Try to make it out which part is gives a effect to your vision.
as per my suggesition illumination asembely you just clean it first.
keep in touch
regards
INDRAVIJAY
Dec 30, 2007 | Tasco 750 Monocular Microscope
SUBWOOFER
Sounds like the power supply in the subwoooooooofer box is dying.
Replace the whole thing . It's going to be the best way out.
Oct 25, 2007 | Sony STR-DE345 Receiver
Science & Laboratory Logo
213 people viewed this question
Top Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
