Question about Whirlpool ED5VHGXM Side by Side Refrigerator
I have a Whirlpool side-by-side refrigerator and I can't get the icemaker front panel off to install a new icemaker kit in order to fix the frosting around the icemaker chute. How does the icemaker front panel release?
  • 410 Answers
According to the model number that you listed in the heading it just shows a cover door that slides out and down and is attached to the top freezer shelf. is this correct? If so pull one side of the slide and it will release the cover.  Now if your talking about removing the dispenser cover on the fron of the freezer door there are 2 slots on the bottom of the cover that you insert a flat tip screw driver and carefully pry the cover off. hope that helps Peyton
Posted on Jan 27, 2009
Flap to close ice dispenser has fallen down and there is frost building on the outside of the ice cube bin. How do I put it back in? Or how do I take the front part of the ice/water dispenser off to fix...
You would need to install whats called an Ice Door Kit made for whirlpool refrigerators. I am making an assumption that yours is a Whirlpool made Kenmore, your model number starts with 106. This is not an easy repair, you have to modify the door to install the kit, you might want to call Sears to fix it. If you want to take a chance and fix it yourself I can get you the part number.
Mar 24, 2013 | Kenmore Side by Side Refrigerator
Icemaker 106 626133 in 1987 Whirlpool ED22MMXRW sid-by-side
Happy to report that I now have a working icemaker. I had to replace the control module--just replacing the gear was not sufficient. The wiring was slightly different for the new module because it had a side connector instead of one coming out of the lower left corner, but I was able to use front metal plate plus its attachments (motors and switches) of the new to replace the similar parts on the old.
Jul 16, 2012 | Whirlpool Refrigerators
ICE MAKER MAKES ICE BUT WILL NOT LET THE ICE ROLLOUT INTO THE TRAY.
You will need to replace the module. It is accessed by removing the white, plastic cover from the front of the icemaker. Once off, remove the three brass colored screws and disconnect the wire arm on the RH side of the icemaker. The new module will install in reverse order. The module is available at the link below.
Module $48.50
Kelly
May 25, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Kenmore fridge106.56546400, icemaker shute leaks
Most likely the chute is not closing all the way. Warm air enters and melts some ice and drips. You'll eventually get a frost buildup there if not already. Order a ice door kit. Get a flashlight and look at the chute door real good for a partial closure for verification.
Oct 12, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Kenmore side by side refrigerator model 106.5686*601 is leaking water from the ice maker inside the freezer.
Icemaker leaks are common and cannot always be solved. May need a new Icemaker. Ofter you can obtain a kit from Lowes (use a Whirlpool kit.)
Aug 23, 2009 | Kenmore Refrigerators
Problems with Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing...? How do I remove the front panel in order to get access to the icemaker parts?
Use a screw driver to pry up at the two notches at the bottom of the panel. I thought that might work, but had been afraid if I did I would break the panel.
Dec 03, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Icemaker Swith has ** light
the kit number is 4389102 it has both the emitter and reciever as one part, change both in the kit
Mar 10, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice shute does not seal
There is a plastic clip that has broken off of the icemaker chute door spring latch on the refrigerator door. This is a common problem and a replacement kit is available from whirlpool to correct this problem. If you contact whirlpool directly they will help you out with a part number for the kit.
Mar 12, 2007 | KitchenAid KSBS25FK Side by Side...
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
121 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
