Printer saying there is a printerhead carriage jam. There doesn't appear to be any obstruction and ink cartridges do not need replacing. Any ideas?
Manually checked for any obstruction, printerhead does not appear to be jammed. Also checked ink cartridges - which do not need replacing.
    Genius:
  • 1,003 Answers
Could be a bit of ink on the encoder strip or wheel
Posted on Jan 21, 2013
SOURCE: Printer shows Carriage Jam, but I can't find it.
Push cartri9age to left about a 1/4", with finger pressure. Un-jammed my printer.
Posted on Apr 06, 2008
JULIANFIX
  • 975 Answers
SOURCE: psc 2355
check if there is a back door where you can access from there the rollers and check for any paper stuck , turn on printer and go to DEFAULT setting on the menu . hope it works
Posted on Apr 19, 2008
  • 111 Answers
SOURCE: Printer keeps saying carriage jam
I hate to state the obvious, but maybe your printer has a carriage jam. Fortunately, HP.com publishes a web page that can tell you how to clear the problem:
Carriage Jam Document
Good luck.
Posted on Oct 10, 2008
  • 24 Answers
SOURCE: Printer keeps saying ''carriage jam error''...
Friends,
The encoder strip may also be dirty, this causes the printer to believe that the carriage moves less than it actually does and tries to compensate by moving the carriage even further - slamming into the left side of the printer as a result.
Carefully leaning the encoder strip with a lint-free cloth wetted with luke warm water (it should not drip!) can fix this problem.
If the carriage stays in the middle of the printer and doesn't move, the carriage drive belt may be broken. Usually this is not replaced so the printer unfortunately has to be scrapped. But contact your local HP support for further advice.
//Al
Posted on Mar 08, 2009
  • 61 Answers
SOURCE: Carriage Jam - HP Officejet J3680 All-in-One
the silver bar the carrige slides on has lost all its lubrication. Try putting some chapstick on the silver bar
Posted on Oct 06, 2009
Testimonial: "You are a brilliant god-like person!! THANK YOU SO MUCH!!!!"
Ink cartridge jam
Try cleaning the carriage bar. This is a shiny rod that the ink carriage slides back and forth on. Wipe it off with a clean rag and put a drop or two of light oil on the rod. The carriage should move easily back and forth.
May 01, 2017 | HP Photosmart C5280 InkJet Printer
Hello. My Epson Stylus CX 4200 now flashes the letter E and all the lights flash, including "error." How do I get it working again?
here's what you can do:-disconnect the printer from the computer-turn off the printer-inspect for anything foreign inside like jammed paper-turn the power back on-remove the ink cartridge-check the chip connnector at ink tank and at head carriage. If its dirty clean it with soft moist cloth. -check the status monitor. which ink tank not recognized. -press ink light (1-4 times) depends on number ink tank not recognized, press 1 time again, carriage will move co replacement position, unplug and plug again all ink tank, press ink light 1 more.
if that doesn't work, replace ink cartridge ONLY if you have a spare. DO NOT BUY new ink as the printer is bound for repair.
Nov 13, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I just install a new v313 printer and the printer says that there is an obstruction with the printerhead. It makes a loud cracking noise. I have taken the ink cartridge out with its base and it then its...
Sounds as if there is a small bit of paper jamming it. Also, if it is just out of the box, make sure you haven't missed any of the packaging tape that is used to secure everything.
Mar 19, 2011 | Dell V313w AllInOne InkJet Printer
Alarm message says "cartridge jammed". Does that
What you see moving is the print carriage. The carriage moves the cartridge, adjacent to the printhead, back and forth.
Although the carriage is moving, the ink cartridge can not dispense ink because an obstruction is
blocking the path of the ink.
Remove the ink cartridges, inspect the cartridges as well as the cartridge holders for any foreign debris and reinstall.
If the alarm message continues, I suggest changing the ink cartridges.
Feb 17, 2011 | Canon MultiPASS F50 All-In-One InkJet...
It is telling me cartridge error What does that mean
Did you just replace a cartridge. Sounds like you used the wrong one.
Oct 01, 2009 | HP Officejet 4215v All-in-One Printer
I have a carrier jam on my dell 944 printer
Printers have small paper flags (plastic levers) that tell the printer where the paper is, also if the motor that drives the inks up and down the metal bar inside cannot turn (due to an obstruction) you will get carriage jam. Open the lid and check the ink carriage moves up and down freely (maybe the ink cartridge has popped out slightly).
Also see if you cand see these little flags and make sure they move up and down ok. Sometimes they work on a tiny spring that pops out.
If there is no obstruction and you can move the carriage by hand (with the power off of course) and it still says carriage jam then i always have a lot of luck by lubricating the carriage bar (shiny steel bar) with some WD40 or other oil.
Hope this help.
Cheers!!!!!
Jul 23, 2009 | Dell 924 All-in-One InkJet Printer
Changing Cartridges does not move into view so I change it
try the on/off button with the lid open. it should move the cartridges.
Jun 21, 2009 | Epson Stylus C86 InkJet Printer
Remove ink cartridge
I found that the proper way to do it only worked when the ink light was flashing red. Then when I pressed the stop button it moved across and stopped beneath the marker to show which cartridge needed changing. The I pressed the stop button again and it moved to a place where I could change it.
This happened despite the fact that the pictures I was printing blatently showed that I needed to replace my ink, it wasn't until I had printed the liney pictures a few times that the printer decided the ink level was low enough to turn the flashing light on and let me change it.
Jan 23, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Carriage jam on HP Officejet J5780 All-in-One
We have several of these in our company and the most common "Carriage Jam" cause is a glob of black ink in the bay on the right side. Once glob is removed, and "Carriage Jam" message appears again, press OK, and it prints fine from then on. Today the black ink glob was flat on top. Watch out for leaky cartridges, as the design of the particular HP device provides a nice catch pan for the tri-color ink cartridge, but not for the black one, so a leaky cartridge, besides being expensive and wasteful, can goop up the bay causing the carriage jam error message to try to get you to take a closer look.
Jan 09, 2009 | HP Officejet J5780 All-In-One InkJet...
51 people viewed this question
jasbo
jasbo
