Question about Cisco Linksys Wireless N Home Router WRT120N Wireless router (745883589319)
My linksys WRT120N routers default ip is 192.168.0.1 when most peoples routers are 192.168.1.1 when they have the same router, what does this mean?
I need the answer because im trying to access web based setup, but i tried tons of combinations for the password/user. the people with routers just like mine type in: 192.168.1.1, when my default gateway is 192.168.0.1, i wondered if this had anything to do with it?
  • 560 Answers
Yes the default gateway is your IP address of your router. You may try once to check it out. You can change your IP address and gateway on the same segment.(Its Logical, Agreed)
If the same problem is still occurring, contact me here http://www.vtechsquad.com/linksys-router-support/
Posted on Jan 23, 2013
  • 826 Answers
If you are able to access router settings then whats your problem..IP can vary ..that not an issue..are you getting any problem??
Posted on Jan 22, 2013
  • Thomas Carroll Jan 22, 2013
    the password and username you told me dont work, ive tried MANY combinations i looked up on the internet, but none work, this is why i asked if this ip made it different or something
Benimur
  • 6966 Answers
SOURCE: router cannot get IP with cisco 675 modem
The issue may be due to the existence of two (2) DHCP servers; 1 in the Cisco 675 and the 2nd in the DLink DI-524. You need to disable the Cisco's DHCP server function and assign static IP add & config to the DLink WAN config. This way it will only be the DLink handing out IP adds to the network.
The workaround. Install your original configuration/setting without the DLink DI-524 - PC direct to the Cisco 675 (I am assuming through Ethernet ports). Verify that indeed you are connected to the Internet and can surf the net, check e-mails, etc. Check your Networking Connection Status. Log down your PC's IP Add, Subnet Mask, Default Gateway, DNS. For purposes of discussion, let's call this "N1".
After your Internet connection has been verified with your PC directly connected to the Cisco, remove the direct connection and connect the DLink DI-524 in between the Cisco router and your PC.
Log in to the DLink and modify WAN parameters using the "N1" configurations/settings.
It might be of help to disable any security (WEP WPA, MAC etc) at least while configuring.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Feb 01, 2008
  • 121 Answers
SOURCE: Client can not surf or ping specific web address - Cisco router
Sounds very much like a local routing issue on the local router. Are you sure there are no spurious routes in place for the target subnet, or a larger subnet including that one?
I would also look to the fact that you cant even resolve the hostname from the router; that suggests DNS failure, again internal to your client. Does the router refer DNS queries to an internal server, perhaps with a stale record for that host? If a different site at the same ISP is resolving and tracing succesfully, again, that suggests underlying DNS issues at the original client location.
Posted on Feb 20, 2010
SOURCE: we use cisco 1811 as router and firewall when try
Is this problem solved or you are still eperiencing this issue?
Posted on Sep 09, 2010
  • 10406 Answers
SOURCE: I have tried connecting Cisco linksys router but
Use an Ethernet cable to connect from the network-port on your computer to one of the LAN ports on the router.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
You should see output like:
IP Address. . . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
if the router has self-configured, and is ready for "wired" usage.
Then, start Internet Explorer.
Type http://192.168.1.1
Press Enter
Login to the web-server "inside" the router
Click to run the "Wireless Networking Setup Wizard" to configure it for "wireless" usage.
Posted on Feb 21, 2011
melvinlpeter
  • 30 Answers
SOURCE: Hi i have 1841 router what is the default user
  • Follow these steps in order to recover your password:
    1. Attach a terminal or PC with terminal emulation to the console port of the router.
      Use these terminal settings:
      • 9600 baud rate
      • No parity
      • 8 data bits
      • 1 stop bit
      • No flow control
    2. If you can access the router, type show version at the prompt, and record the configuration register setting.
      Note: The configuration register is usually set to 0x2102 or 0x102. If you can no longer access the router (because of a lost login or TACACS password), you can safely assume that your configuration register is set to 0x2102.
    3. Use the power switch in order to turn off the router, and then turn the router back on.
      Important Notes:
      • In order to simulate this step on a Cisco 6400, pull out and then plug in the Node Route Processor (NRP) or Node Switch Processor (NSP) card.
      • In order to simulate this step on a Cisco 6x00 with NI-2, pull out and then plug in the NI-2 card.
    4. Press Break on the terminal keyboard within 60 seconds of power up in order to put the router into ROMMON.
      If the break sequence does not work, refer to Standard Break Key Sequence Combinations During Password Recovery for other key combinations.
    5. Type confreg 0x2142 at the rommon 1> prompt in order to boot from Flash.
      This step bypasses the startup configuration where the passwords are stored.
    6. Type reset at the rommon 2> prompt.
      The router reboots, but ignores the saved configuration.
    7. Type no after each setup question, or press Ctrl-C in order to skip the initial setup procedure.
    8. Type enable at the Router> prompt.
      You are in enable mode and should see the Router# prompt.
    9. Type configure memory or copy startup-config running-config in order to copy the nonvolatile RAM (NVRAM) into memory.
      Important: Do not type copy running-config startup-config or write. These commands erase your startup configuration.
    10. Type show running-config.
      The show running-config command shows the configuration of the router. In this configuration, the shutdown command appears under all interfaces, which indicates all interfaces are currently shut down. In addition, the passwords (enable password, enable secret, vty, console passwords) are in either an encrypted or unencrypted format. You can reuse unencrypted passwords. You must change encrypted passwords to a new password.
    11. Type configure terminal.
      The hostname(config)# prompt appears.
    12. Type enable secret password> in order to change the enable secret password. For example:
      hostname(config)#enable secret cisco
    13. Issue the no shutdown command on every interface that you use.
      If you issue a show ip interface brief command in privilege EXEC mode, every interface that you want to use should display up up. For example:
      Router#show ip interface brief
    14. Type config-register configuration_register_setting>. Where configuration_register_setting is either the value you recorded in step 2 or0x2102 . For example:
      hostname(config)#config-register 0x2102
    15. Press Ctrl-z or end in order to leave the configuration mode.
      The hostname# prompt appears.
    16. Type write memory or copy running-config startup-config in order to commit the changes.
Posted on Mar 01, 2011
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Jan 13, 2012 | D-Link 802.11g Wireless Router WBR-1310...
Factory pasword for wrt120n
Are you speaking about default password of Linksys router?
The default password is admin, leave the user name blank.
If the default password is not accepted then you can try to reset the router.
Remember if you reset the router, it will come back to factory default settings and you will need to reconfigure it.
Dec 07, 2011 | Linksys WRT120N Router
I am trying to connect My Nokia x7 to my routers wifi at home, but i need to enter an 8+ digit password, and We forget our router password. It is a Linksys wrt120n router.
first go to linksys website .Find your model and find your routers ip address or Reset router by pressing reset switch on back or bottom for about 10 seconds.Once reset is done use ADMIN in log in page with no password.then set a new password.First find your routers IP address
Sep 22, 2011 | Linksys WRT120N Router
I'm using TP-LINK TD-W8101G ADSL Modem Router to connect internet, I'm trying to connect it with Linksys WRT120N Router Wirelessly. I want to use WRT120N as access point to extend TP-LINK...
Unfortunately, you can't use two routers together in that manner. You must have a device in between them such as a switch or bridge or you'll have to disable the DHCP server settings in the second router. The second router then pretty much becomes a switch you may then use all the ports on the second router with the exception of the WAN port it must remain unoccupied. However, if you need wireless connectivity in another location far away from your main router then your only solution would be to indeed purchase an actual access point/bridge device
Sep 06, 2011 | Linksys WRT120N Router
I want to change my id user name & password for WRT120N. But I also can't find the program in my computer. Please assit me. Thanks,
In order to access your WRT120N control panel UNDER FACTORY SETTINGS, you must navigate to http://192.168.1.1 in your web browser.
According to Cisco's support site, the default username for the WRT120N will be NULL (left blank) and the password will be "admin".
Once you reach the control panel, navigate to the 'Administration' section, where you should be able to change your username and password.
NOTE: If this does not work, you may want to look into performing a factory reset of your device.
Jun 07, 2011 | Linksys WRT120N Router
Cant connect to the routers ip address with the password
The default password is admin.
To reset to factory defaults, follow these instructions:
Make sure the router is powered ON. Then Press+Hold the Reset button of your router for 30secs first. (Reset is found on the back panle of your router, you have to use a pen or a paper clip to press the button) For the LED's if the power blinking that indicates that the router is being reseted and then powercycle the router for only 30secs.
If the Power LED won't blink Press+Hold the Reset Button for 1min and then Powercycle the router for another 1min. Then check the IP address of your PC then try accessing your router's UI(192.168.1.1) and use admin as your password.
Mar 19, 2011 | Linksys WRT120N Router
How do i bring my wrt120n linksys router back to blank factory settings?
according to the user's guide I found HERE:
http://www.linksysbycisco.com/APAC/en/products/WRT120N
you can either use the red reset button between the ethernet ports and the power jack, or restore the
defaults from the Administration > Factory Defaults screen of the Router's browser-based utility.
Dec 24, 2010 | Linksys WRT120N Wireless Router
Cant access my linksys router WRT120N.Forgot my password.Please help.
Are you looking for the wireless password or the password of the router?
If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password
Click here for more information about the routers and wireless network.
Sep 23, 2010 | Linksys WRT120N Router
Password for wrt120n
Default factory settings for this router:
IP address: 192.168.1.1
username: (left blank)
password: admin
If this username and password doesn't work because it was changed, press and hold the reset button on the rear of the router for 30 seconds. This will reset the router to factory defaults.
Apr 06, 2010 | Linksys WRT120N Router
Cisco Linksys Wireless N Home Router WRT120N Wireless router (745883589319) Logo
131 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
