Question about Home Security
I have a 139.53663SRT2 Craftsman garage door opener that had both remotes stop working. They're visor remotes. I replaced the batteries (verified good with DVM), no luck and can't program ei
  • 244 Answers
SOURCE: keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Posted on Jan 28, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: garage door opener doesn't work with key pad or remotes
It sounds like for some reason the receiver has lost the stored codes for your remote transmitters. The wired button goes right to the opener so it continues to work.
On the back of the opener you'll see a small pushbutton. Press it and the indicator light nearby will come on. While this light is on, press the button on your remote. The light will go out and the code is stored. Repeat this for each remote. The process is the same for the keypad, except that you need to enter your desired 4-digit code.
If this programming doesn't work you'll need to replace the receiver board. Like any other piece of computerized equipment, it can fail or be damaged by power line problems. But try reprogramming first, as that's the most likely solution.
If this has helped you, please take a moment to rate the solution. Thanks for asking here!
Posted on Feb 18, 2009
  • 3197 Answers
SOURCE: Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: I have a Craftsman garage door opener 1/3hp chain ...
Sounds like your logic board is going bad. The part number you listed is the logic board.
Posted on May 20, 2010
blanchettohd
  • 143 Answers
SOURCE: Craftsman garage door opener remote failure
You may be receiving interference. Take all the batteries out of the remotes and try them one by one. You will not have to reprogram them. If you find one shortening the range of the others then get rid of it. Or it may be an outside source. Worst case is you will have to replace the logic board. Thanks BB
Posted on Sep 03, 2010
  • 3197 Answers
SOURCE: I recently bought a house which has a craftsman
If you didn't, try programming the remote this way.
Press and hold the button on the remote and then press and immediately release the smart/learn button on the motor unit. If this doesn't work you need to make sure you have the correct remote for the model opener you have. Your model number doesn't bring any results from Sears Parts.com.
Posted on Nov 10, 2010
I have to "Access master" remote controls to open
Depends on the model. Some have a small screw on the back, some have a small 'door' that slides open and some have a small slot on the bottom that you use a screwdriver or the sun visor clip to insert and twist. Yes they do have a battery.
Nov 09, 2011 | Sears Craftsman LiftMaster Chamberlain...
Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
Sep 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 3/4 screw garage opener all remote stopped working
The radio receiver which is part of the logic board is bad. Check your warranty quick and call Sears.
Jun 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote keypad
open case with visor clip and ut in battery, observing polarity.
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad garage door opener will not operate
Dec 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Security Garage Door
your car remote should work even from inside the garage... if not, just take it off the visor and go outside the front door and point it at your garage to open it. This is only a quick fix. You probably need to replace the batteries in your keypad or reprogram it.
Jul 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
251 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
