Question about Panasonic TX32LXD70 32 HDTVReady LCD TV
Hdmi panel signal - Panasonic TX32LXD70 32 HDTVReady LCD TV
    Genius:
  • 1,003 Answers
Replace the mainboard!
Posted on Jan 21, 2013
When I connect my Sony DVP-CX995V via HDMI it the TV says there's no signal.
there is interface problem between hdmi port actually signal are not reached in system ic these signaled are dropped between hdmi port & hdmi switching ic so please go to your nearest Sony service center & repair main board because this problem is in main board
Feb 02, 2016 | Sony Televison & Video
T V turns on, can't get the HDMI to appear on the screen for the signal.
HDMI is the High Definition Media Interface PORT on the back of a modern Flat Panel TV or Monitor.
The remote control should allow a selection menu to appear on the screen so you can choose an alternate signal input from another device or set top box.
Perhaps the TV senses that there is no signal on that HDMI cable plugged into the back port, so therefore it won't show it on the screen menu.
Turn on the device attached to the other end of the HDMI cable.
Mar 02, 2015 | Televison & Video
When I switch from one HDMI input to another I get a no signal & spinning LG box. after several minutes it gets a signal
Try a different HDMI cable, then try the other HDMI inputs on the TV, then try to connect another HDMI device to the TV. If all are still bad main board needs replaced
Oct 19, 2014 | LG 55LK530 55 inch 1080p LCD HDTV, with...
Why is tv saying no signal?
Connect a known working DVD player by using a new HDMI cable to HDMI INPUT 1 and check for signal.
If you have a DISH or CABLE system box, connect that also with a new HDMI cable to HDMI input 2 or 3 and recheck for signal. Your T V remote will have an input selector to change between the different inputs on your
T V.
Sep 08, 2014 | Proview HX303 30 in. HD-Ready LCD...
Why cant i get hdmi output
HDMI output from what? The TV??
TV's don't have HDMI outputs. They are HDMI inputs. They are a "signal goes in here" socket and not a "signal comes out here" socket
Sep 07, 2014 | Televison & Video
No signal from HDMI mode when I switch on the TV
HDMI is an input to the TV not an output. You select the appropriate input e.g hdmi 1, hdmi 2 on the remote. There can be a return signal the other way but the cable has to support that. Try a different hdmi cable.
May 14, 2014 | LG 42LE5500 42 in. TV
No hdmi signal
hi good day
if you can not use your hdmi port first try to use with other hdmi cable just to know if the problem is with in the tv unit at the same time you need to use other source like dvd player. if still can not have signal.their is a problem with the hdmi input board check and re soldered the terminal port of the hdmi then check defective signal diode going the hdmi terminal. hope this will help thanks for consulting through fixya.
Sep 04, 2011 | Televison & Video
Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Apr 22, 2009 | Yamaha RX-V663 Receiver
Panasonic TX32LXD70 32 HDTVReady LCD TV Logo
26 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
