Truck has three 7mm bolts,,1 behind lock slider,just pry out,1 under armrest/door handle,and 1 on bottom side of door panel(bend down and you`ll see it.remove upper panel(triangle shaped).that model might also have a torx bit under plastic cover needing to be removed,,,lift UP on door panel and it should release. IMPORTANT IF POWER WINDOWS AND LOCKS THE RECTANGULAR PLUG HAS A CLIP YOU PRESS DOWN TO RELEASE SLIDER THAT WILL RAISE (DO NOT PRY) LOOK CAREFULLY SO AS TO NOT BREAK IT once you do that you will figure the rest out on your own. GOOD LUCK
If you need further help, I’m available over the phone at https://www.6ya.com/expert/stephen_fa62cb6d50fe05e8
