Question about Cameras
My finepix s1730 keeps saying to turn off and on again, but every time I do it says it again.. and because of this won't work.. can anyone help?
It worked fine until one day this popped up, I can't do anything with it.. including view pictures or take pictures it just tells me to turn off and on again.
    Genius:
  • Cameras Master
  • 1,019 Answers
Hello Beth, The camera is trying to tell you that it has an internal malfunction, What this really means is the camera needs to be serviced / repaired.
Best Regards, Russell
Posted on Jan 25, 2013
  • 15 Answers
SOURCE: Powershot A460, LCD picture is black but display options appear
Have you tried pressing the Display button on the back?
Posted on Jan 17, 2009
  • 3 Answers
SOURCE: when turning camera on, lens opens and closes , then it says turn the power off and on again
The problem is that the lens is jammed.
Here's what I did: I smacked the side of the camera on a tile floor a few times, until the lens started trying to open. Then I used a knife to pry up the lens a little. Believe it or not, it is now taking pictures. You can't imagine how excited I was to get it working.
If this sounds like a joke (it did to me), I got the idea from these forums:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscm1_question.html?qid=2900
http://www.camerahacker.com/Forums/DisplayComments.php?file=Digital%20Camera/Sony/dsc-w50_acess.turn_off_on_again.html
Posted on Apr 22, 2009
  • 21 Answers
SOURCE: 'frame no. full' error on screen. how do i get rid
In the menu there is frame no renew option please check it
it will solve the issue
Posted on Jul 24, 2010
SOURCE: DSC-W150 SteadyShot says turn power on & off & lens pops in/out
I had the same problem with my Sony DSC-W150 camera. It turned out to have an easy fix. At the same time, press the power button and depress the shutter button halfway (the one you snap to take pics) as if you were trying to engage the autofocus without pressing the button down entirely. The lens will attempt to autofucus, which in my case was enough extra power to dislodge whatever debris/sand had clogged the lens. Hope this works for you!
Posted on Sep 07, 2010
  • 11967 Answers
SOURCE: Hi, I dropped my fujifilm
Try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 08, 2010
My laptop won't allowed me to login II don't what wrong with it..in the screen it says configuring updates then goes off and back again to configuring updates but just keep doing it again and
you can login to safe mode using F8 key on boot or just waite for fully updates instalation it can take some time and can reboot many times if it's installed many updates
Nov 14, 2012 | Toshiba Satellite M300-ST3403 Notebook
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
My NavmanMy50T won't turn on when hot
I haven't experienced it myself, but it's well known that all electronics are VERY sensitive to heat (why computers have fans). Since you know what's causing it, you might want to consider some way to keep the Navman cool, like a chemical-ice pack that neither leaks water and can be thrown into the freezer again and again. THAT would keep it cool enough, although kinda bulky, to continue to operate. Besides some kind of external cooling, I know of absolutely nothing that could solve that problem.
Sep 19, 2012 | Navman GPS
Won't stay on
Sound like a stuck lens problem; check here about fixing-lens-error-on-digital-camera.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Sep 03, 2012 | Fuji FinePix A330 Digital Camera
Can i get a free download for the Fuji finepix S1730 manual
can I get a free adobe reader and successfully installed in my laptop?. Thanks
Aug 27, 2011 | Adobe Computers & Internet
My finepix s1730 WONT CONNECT TO MY PC
Please re install your finepix driver on computer and pairing them using firewire.
Regards, Jay
Feb 21, 2011 | Cameras
Error message on the fuji finepix s1730 says 'turn off the camera and turn on again' - what does it mean, it keeps doing this
I have several cameras and had left my 1730 in an old house for a year. It had been in a bag with the lens cap on and no batteries, but the house left without heating over winter. When I put fully chaged batteries in it, I got a little motor noise but no lens movement. I thought this was the end of it but did #6 above, switching it on while banging the right (grip) side of the camera against my palm. After many times I saw that the lens was starting to move out and after about 10 more times it came out and started to operate. It then failed when I went to macro but it got better as I used it. Now it seems to be back to normal.
Oct 31, 2010 | Fuji FinePix S7000 Digital Camera
Cameras Logo
71 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
