AIR FILTER FOR MODEL #ARUF182416CA
Air filter for Goodman heatpump Model #ARIF182416CA SERIAL #1201162219
  • 121 Answers
SOURCE: Wiring diagam for goodman heatpump
On your t-stat you have Y, W1, W2, R, O, G, B or C or X. Y is your cooling circuit and will be the same in the air handler and heat pump unit, use the yellow wire for this circuit. W1 and W2 are your back up elec. or gas heat. Depending on how many kws or heat strips you have and t-stat wires you will put the white wire to W1 in both the t-stat and air handler. W2 is for your second stage back up heat if air handler calls for it, this will be a tan or brown or black t-stat wire and goes to W2 on t-stat and air handler. R is half of your 24v control power from the transformer and is the red wire and goes to the t-stat, air handler, and heat pump. O is for the reversing valve in the heat pump that switches it from heating and cooling. You guessed it the orange wire connect to t-stat and heat pump. G is for the blower and is the green wire to the t-stat and air handler. B or C or X is known as the common which is the other half of control circuit from 24v transform it is the blue wire and goes to the t-stat, air handler, and heat pump.
Posted on Oct 09, 2008
  • 34 Answers
SOURCE: Dometic Air conditioner model 57915-531 blows hot air
Have freon and compressor checked out, could also be bad capacitor
Posted on Aug 11, 2009
heatman101
  • 43501 Answers
SOURCE: My AC unit comes on, but the fan doesn't work or blow air
The condenser fan motor has gone bad... this is a very common problem. Find the specs. on the side of the motor and then get a replacement from Goodman or from a company like www.grainger.com
The fan motor is rather easy to replace, the worst part is getting the fan blades off of the shaft of the old motor. Use WD-40 and be patient...
heatman101
Posted on Apr 07, 2010
  • 53 Answers
SOURCE: goodman air conditioner tag model is CK36-18,
sir you have a 3 ton unit
Posted on May 17, 2010
  • 82 Answers
SOURCE: Goodman Air Handler with the model #ar36-1 ,
This unit had a 5 year parts warranty. The serial number provided shows a manufacture date of May, 2002.
Posted on May 18, 2010
Trying to find out how to change the filter for Goodman AC model # ARUF36C14BB
The filter compartment is at the front bottom of your indoor section of the air conditioner.
There should be an access plate located there and may have a 5/16" screw on each side you need to remove to get the access cover off.
An air filter should be visible, and you should slide the filter out toward you for removal.
Mar 27, 2014 | Goodman Heating & Cooling
Blower will not blow air with cover on unit when i take cover off air blows through vents on package heatpump
Sounds like return air supply clogged, check filter and duct work also some units have a filter at air handler at bottom some time the installer leaves them in
Jan 03, 2011 | Goodman CLQ36AR49 Air Conditioner
I have model # CAPF36426BA, serial #0710063621. I can't find anywhere where a filter should be in order to change it. Is it possible it doesn't have one?
The filter should be in the incoming side of the air handler..
and yes there are many installers that do not do their job correctly...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 29, 2010 | Goodman Heating & Cooling
Where is the filter on my Goodman model capf3636c6ba ?
The main places that filters are located are:
Return Air Vent or Vents
Inside Coil Box
Underneath Furnace (Will have a small access door)
Filter Box Attached to Return Air System
A lot of people still look for their filters inside the coil box, but more recently installed units will have them in the return grills inside the house. Follow your return air from the vent inside the house back to the unit and it will be somewhere in between there. Hope this helps!
Aug 05, 2010 | Goodman CKL36AR36 Air Conditioner
What type of thermostat do I get for my goodman model GPG13420901AA? Can i use a honeywell digital one?
yes you can use a honeywell,certain types work...is it a heatpump or straight air unit...
Jun 09, 2010 | Goodman GPC1342H21A Air Conditioner
When your compressor on heatpump burns out how do you clean the system before installing new compressor
Flush the system with Nitrogen. Then R-11. Then install low side and high side filter driers. Then replace the low side filter drier after 2 weeks running time.
May 19, 2009 | Goodman CLQ36AR49 Air Conditioner
Compressor noise
I the compressor is bad it will draw high amps. If the amps are ok then i would look at the valve.
Jan 18, 2009 | Goodman CLQ36AR49 Air Conditioner
My goodman seer 13 package heatpump stopped blowing cool air. Fan still works, there is power to the unit.
Is the outside unit starting and fan blade spinning? Have you inspected you air filter recently?
Sep 15, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
284 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
