Question about Samsung DV422EWHDWR 7.2 Cu. Ft. Top Load Electric Dryer
Need drying rack
Is drying rack included
FILLS, DOES NOT WASH, THEN DRIES
GE GLDT690TBB Fully Integrated Dishwasher with 7 Wash Cycles Including SaniWash and SpeedWash, Nylon Racks, Stainless Steel Interior, Countdown Display and QuietPower 56 Quiet PackaBlack- Recent Questions, Troubleshooting & Support
Oct 07, 2015 | GE GLDT690TWW Fully Integrated Dishwasher...
I have a whirlpool duet dryer.. I need to know how to put in the rack for the tennis shoes.. HELP
Hi dear.Here is some help from the user manual.I hope that helps.Thanks. DryingRack
To use the drying rack
Do not remove the lint screen.
1. Open dryer door.
2.
Place drying rack inside dryer drum, positioning the back wire
on the ledge of the inner dryer back panel. Push down on
front edge of drying rack to secure over the lint screen.
3.
Put the wet items on top of the rack. Leave space between
the items so air can reach all the surfaces.
NOTE: Do not allow items to hang over the edge of the rack.
4.
Close the door.
5. Select a timed drying cycle and temperature, or an air cycle
(see following chart). Items containing foam, rubber, or plastic
must be dried on a clothesline or by using the Air Only
temperature setting.
6. You must select a time by pressing MORE TIME or LESS
TIME. Reset time as needed to complete drying. Refer to the
following table.
7. Press (and hold) HOLD TO START button (about 1 second).
NOTE: You must remove rack for normal tumbling. Do not use
automatic cycles with the drying rack.
This chart shows examples of items that can be rack dried and
the suggested cycle, temperature setting and drying time. Actual
Rack Dry Setting Temp. Time*
Wool Sweaters
Block to shape and lay flat onthe rack.TimedDryLow 60
Stuffed toys or pillows
Cotton or polyester fiber filledTimedDryLow 60
Foam rubber filled
N/A Air Only(noheat)90
Sneakers or canvas shoes N/A Air Only(noheat)90
drying time will depend on the amount of moisture items hold.
Aug 30, 2010 | Whirlpool Duet Front Loading Dryer Rack...
How do i install the shoe rack in the dryer
It is a trapezoid, the wide end goes toward the door and lines up with the lint trap. You cannot support two boots, or heavy shoes. It just balances in the rim of the door frame. The handle shaped things face down. You kind of have to pinch it into place, and it just rests there, too much weight and it will topple in. Good luck if you have big feet.
Sep 27, 2009 | Kenmore Dryers
How do I install the drying rack. i have never used it and can't find my manual
i dont have your model # , but on most models you take out lint filter and pu the rack inside the dryer drum.the one end of the rack that looks like it goes into something goes into the filter housing. hope that helped you ....
Sep 13, 2009 | Dryers
Items not drying like they should. I replace bottom heating element already. What's my next move? Is it the electronic control unit?
the control unit is not letting the element stay on as long as it needs to in order to dry the top rack.
May 02, 2009 | Dishwashers
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Can't figure how to use drying rack in dryer of whirlpool duet dryer
insert the drying rack into the dryer with the wire end resting aginst the rear wall of the dryer and the frount of the rack over top of the lint filter
Apr 29, 2008 | Dryers
Install shoe drying rack gas dryer
I am in dire need of the Fisher & Paykel Dryer rack Model # DEGX1. I now have a two year old who loves Mud puddles and I would love to be able to buy the Dryer rack. If you know where I could find one. could you please contact me @ heatherys@yahoo.com
Mar 22, 2008 | Dryers
Dryer Rack
On mine, nothing "clamps down". There are 3 positions in the plastic rack into which you can insert the wire rest - "F", "H", and "A". God knows what they mean (I think the one rack is intended to be used in various dryers, of different depths), but if I use the rearmost position = "A", the back end of the wire rest rests on the non-moving rear of the drum, and the front of the rack rests on the lint screen holder. Seems to work, but the instructions leave a lot to be desired.
Dec 09, 2007 | Kenmore Elite HE4 Electric Dryer
Samsung DV422EWHDWR 7.2 Cu. Ft. Top Load Electric Dryer Logo
29 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
