Question about RCA B27TF680 27 in. TV/VCR/DVD Combo
Hi does the RCA F32649 Have Digatil Tuner?
This says is oct 2001 model is there a way to know, I see nothing on set with digital imput, and nothng in manual.thanks
  • 57 Answers
Unfortunately no, I checked your manual as well and your RCA F34649 does not have a digital tuner.
I hope this solution is helpful. Please take a moment to rate this solution.
Posted on Feb 11, 2009
Model # F32649- TV has static, no picture no
RESOLDER LOOSE CONNECTION IN THE TUNER OR YOU NEED TO REPLACE THE TUNER
Aug 23, 2009 | Televison & Video
Imput analog audio to Vista laptop via HP ExpressCard TV Tuner
Perhaps this device at creative.com (The link provided for you) or something similiar will do the trick for you.
http://us.creative.com/products/product.asp?category=209&subcategory=668&product=16186&nav=1
It connects to a USB port. You have 2 on the right side of your laptop. The device has two RCA ports which should provide the connections you seek.
A device like this one or similiar should give you the best "Quality" audio transfer.
But if cost is more of an issue, you can find "Patch cables" at you local electronics store to go from RCA jacks to stereo headphone jack this will allow you to port the information in through your Microphone jack.
Hopefully this helped you,
Dave
Nov 23, 2008 | HP Expresscard TV Tuner For Windows Vista...
Does my tv have a digital tuner (RCA Model E13320, 2/2001)?
The digital tuner has nothing to do with the new signal you will be receiving in February of next year. The new video signal is a digital signal. The old video signal is analog. Your television receives the analog signal and converts it to what you see on television. You need a converter box to convert the new digital signal back to an analog signal your television can convert.
Jerry
Nov 07, 2008 | Televison & Video
Perfect sound, no picture - RCA F32649
if you know how to solder ,re solder your tv, but before doing that replace or used other RCA cord
Aug 09, 2008 | RCA F32649 32" TV
Rca tv
1) Buy RCA remote part # 240895 original about $25.00
2) Enter channel 00 for video sometimes works
3) Channel down 4-3-2-Vid 1, Vid 2, etc. sometimes works
4) Try Auto-Program Channels selection ( can be accessed on
front of set buttons or remote
Let me know ...........................................T.
Nov 04, 2007 | RCA F32649 32" TV
No picture channel 2-3-4-5-6-7
bad tuner or gemstar module
Dec 08, 2006 | RCA F32649 32" TV
RCA F32649 32# TV Troubleshooting Forum
this is an old case and Im sure you have a new TV by now. The problem is the tuner. The grounds are cold and need to be re-heated. The tuner is the little box your cable plugs into. Open the back and you will see where it is soldered to the main board. Heat them back up with a little solder should be three points. while you are in there look around and see if you find more. if that doesnt work then you may have to take the case of the tuner off and look inside for more cold solder joints
Nov 25, 2006 | RCA F32649 32" TV
Bad Cable Input
Try using your RCA imput to see how the picture looks compared to the tuner picture,is possible your tuner imput is bad,make sure the conector is not loose,the overall picture should look different but not fuzzy all over,using a dvd picture thru the aux (rca)imput should show you the difference.If the conector is loose only it could be repaired but if it is solid the tuner might be bad and it will need to be replaced along with any board it might be mounted to.Let us know how it goes or if you need more information.
Oct 17, 2006 | Polaroid FLM-2632 Television
RCA F32649 sound but no picture
This usually a problem on/near the horizontal section of the TV board caused by solder that losses its contact thats why you need to bump it sometimes for the picture to come out. To remedy this just try to resolder any parts that you suspect seems to loose especially in the part where the components tends to get hot when operating, this usually are the horizontal section or the power supply section which is very common.
Apr 10, 2006 | RCA F32649 32" TV
RCA F32649 - Won't Recognize Ch 3
what do you mean??? it doesent reconize channel three?? does it skip over the channel three or can you take a remote and manually put it on channel three and theres all snow when you put the set on channel three There is no magic wand to fix a set unless I get a few more magic words(HE HE) please indicate what you mean dosent reconize channel three??? and if im not mistaken there is a video input on ythis set and I used a set for my satallite for overr 5 years so far and the set was given to me as it has a bad tuner so I simply ran my sat. through a video input and have a great set get bacj to me please
Apr 02, 2006 | RCA F32649 32" TV
RCA B27TF680 27 in. TV/VCR/DVD Combo Logo
81 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
