DVD/VCR recorder/player is stuck on progressive mode. Have tried to correct problem through Sony but to no avail. Please help as this machine is sitting idle. Thank you.
Comments:
Aug 10, 2007
- Thank you for your suggestion. I read the instructions in the book that came with the VCR and it states the same thing you suggest. However,, the book says to push the pause button repeatedly for 5 seconds. You say push the pause button for 5 seconds. Do you mean push and hold the pause button for 5 minutes? I am so dumb when it comes to reading instructions. Please help. The VCR is at home and I can not wait to try your suggestion. Thank you so much.
-   Forced progressive (dumb, I know) and it stayed there. I concur with previous post: There is no pause button on the DVD side of the recorder. Because the screen is solid black, I cannot get the System Menu to display. Just before the progressive LED indicator comes on the digital readout in the from displays "LINE 2" and then everything goes black. Serious engineering flaw (me and the machine both). Since there is only one button that says pause, I'll give that a shot. <BRB> Ah-HA! The pause button works for both DVD and VCR mechanisms and activating the DVD button sets the operation for that side. Good point about turning off the power after holding the Pause button. I hel Pause for 30 seconds and waited 30 seconds after turning off the power to ensure full discharge inside the equipment. Thanks folks. I'm out of the doghouse!
-   Guest
Sep 02, 2008
-   SOLUTION: I had the same problem after forcing progressive setting when I shouldn't.
Manual's solution on hint, page 102, works IIF you THEN turn off the unit, wait 10 seconds, and then turn on the unit.-   Guest
Jun 29, 2008
-   My RDR-VX530 is also stuck in progressive mode. The tv display is now blank and this recorder is now a brick. I tried unplugging the unit for 3 hours, holding down the power button for a minute, holding down both the channel up/down buttons and holding down the pause button. Nothing resets the unit so I can get back into setup. How can I reset this box to the factory default settings?-   kd4vbp
Hi I have the same issue. What do you mean by pause button on the RECORDER? There is not pause button on the Recorder, I tried use remotes pause button, but no luck. Please help.
I had a very similar problem but mine got stuck on DVD 1 and I could not get the System Menu to come on. I read the whole manual from front to back. Holding the Pause button and the DVD button did not work. Neither did unplugging the unit. But I discovered (pg. 26 of manual) that there is a COMMAND MODE switch which can get you out of the Progessive Mode or DVD 1 mode. If you look at your remote, on the bottom there is a panel that you can slide down. Look at the very bottom right - there is a tiny little switch and you should have the factory label over it that says Do Not Remove. Gently peel back the label, being careful not to remove it entirely and move that switch to the LEFT. Voila! Everything works. You may have to go back and re-set everything the way it was before manually but now you have access to the System Menu to do that! Now if I can only get this to work with my digital converter I'll be in good shape. GL.
I am trying to find a replacement gear for the Sony RDR-VX530. It is the gear that contacts the worm...
(More)
I am trying to find a replacement gear for the Sony RDR-VX530. It is the gear that contacts the worm rear on the loading assembly motor for the VCR. Sony says they do not have that part nor can they give me a part number. Thanks for any assistance finding this gear.
My Sony RDR-VX530 is stuck in Progressive Mode and the new Samsung 540 TV now say I have no signal....
(More)
My Sony RDR-VX530 is stuck in Progressive Mode and the new Samsung 540 TV now say I have no signal. I was experimenting with the DVD setup and made the mistake of selecting Progressive. Without a signal I can not get the DVD back in Easy Setup. The Line Output is connected to TV Side Panel input called AV IN 2. Before my experimenting I could get the DVD to play on TV and do some setup. I've tried to reset the DVD by unplugging the unit and removing the batteries from the remote but I still don't get AV IN 2 to respond with a signal. Your suggestions appreciated.
I need to know the orientation of the Gear Worm Wheel in a RDR-VX530. The illustration in...
(More)
I need to know the orientation of the Gear Worm Wheel in a RDR-VX530. The illustration in "Broken Cam Gear" posted Feb 06, 2009 is not clear enough to tell. The wheel spokes are offset from the center and since it has fallen apart and I did not take note, I am no longer sure of the orientation. I am going to Bondo this ****** back together!! Are the spokes closer to the sheet metal?
when I try to record, the vcr gives a message to use a tape without the tab removed. The tab is in...
(More)
when I try to record, the vcr gives a message to use a tape without the tab removed. The tab is in place. I've tried numerous different tapes. The vcr won't record because it thinks the tab is removed, Sony RDR-VX530
Sony RDR-VX530 - almost exclusively used for copying video VHS tapes to blank DVD -R Had this...
(More)
Sony RDR-VX530 - almost exclusively used for copying video VHS tapes to blank DVD -R Had this problem before - when changing brands of blank DVD discs the unit will record for limited time - sometimes just 20 minutes, others 35 minutes - last night I got an hour of a two hour VHS - rec mode is set correctly - just seems to reject record process somewhere along the way - last time I took it in and got charged $150 for a thorough cleaning
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
