Question about Zenith P42W34P 42 in. EDTV-Ready Plasma Television
Zenith flat screen stand cant mount it on back
    Problem Solver:
  • 5 Answers
What exactly are you trying to mount it to? if you are trying to wall mount it make sure the mounting kit lists your television as cooperating. Some universal kits only use certain configurations as there is no standard between televisions as to where the screw mounts are on the box, this may cause you to need a specific kit.
Posted on Jan 21, 2013
What is screw hole size in a 50 inch zenith tv to mount to tv stand
It will be a 4 to 6mm screw. Exact model is going to be needed to know exact size.
Feb 08, 2015 | Zenith Televison & Video
Where can I find the piece that holds the tv for vs91350-01
Walmart and others have the universal "jimmy stand" for about 90 bucks. This will mount to the TV (on the back like a wall mount) but also includes a base so you can simply set it on a table.
http://www.walmart.com/ip/ShopJimmy-sj-Stand-3755BB-Universal-TV-Stand-Base-Plus-Wall-Mount-for-37-inch-55-inch-Flat-Screen/36774428
or search
sj-Stand-3755BB
Oct 26, 2014 | Televison & Video
I need the stand for a 32" insignia flat screen
You can buy an assortment of universal support bracket or universal stands at stores like walmart, Best Buy etc.... Check the back of your insignia and you will see the threaded holes made for this kind of bracket. I bought a 42 inch flat screen and bought a combination table/mounting bracket. It's great. Make sure you get a bracket that matches or exceeds the weight of the TV though. Good luck and feed back if u can.
Apr 18, 2013 | Insignia IS-LCDTV32 32 in. Television
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
Flat screen stand for 16" Flat Screen Zenith
fit it to the wall or go on ebay serch "table top stand zenith"
Nov 04, 2009 | Televison & Video
LN37A550 FLAT SCREEN TV
To remove the base stand, place the TV face down on a smooth surface. Place a cloth underneath it to protect the screen. Remove the 4 phillip screws from the stand. The stand can now be removed. The set can with a cover plate you can use to cover the opening.
See page #86 in the User Manual.
Mar 15, 2009 | Samsung LN37A530 37 in. LCD HDTV
Mounting to TV Stand
there are two types of stands, some are wall type which needs to be mounted using rawl bolts, nuts are suppose to hold a stand, some are ground stands which are suppose to be put on a flat surface in order to balance.
Jul 29, 2008 | Panasonic TH-50PZ77U 50" Class Plasma HDTV
How do i attach a Wall Mount to the TV?
I have the same TV, and I bought a mount with 4 connector holes. I was able to connect 3 of the 4 and it has been fine as the TV does not weigh too much. The TV was not designed with the current mode of either wall or stand mount. It was just intended for stand. I have had it on the wall for over 2 years.
Apr 23, 2008 | Televison & Video
How to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Feb 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
What size bolts for mounting bracket??
I don't know the size but, I can bet it will be a metric bolt.
Apr 17, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Zenith P42W34P 42 in. EDTV-Ready Plasma Television Logo
32 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
