Question about Microwave Ovens
Is there any way I might be able to fix my microwave's lack of power problem?
I've checked by plugging in to another power source, but still not power.
    New Friend:
  • 10 Answers
If there's no power at all then check the door switch first, it's the LEAST expensive part to replace that causes no power. If it's anything else buy a new one for about $40.00 to $100.00.
Posted on Jan 21, 2013
2 Suggested Answers
najah
  • 180 Answers
SOURCE: Microwave won't heat for first minute - starts working normally after that.
The magnetron may be defective. You can replace the magnetron, there is no other possibility.
Posted on Jan 17, 2013
Light bulb
follow this steps and fix it. God bless you
If your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • Jul 29, 2013 | GE JES1384SF Microwave Oven
    Sharp Carousel Microwave Mdl 1875 for our RV is dead
    >> We also tried plugging our toaster into the microwave plug outlet, and the toaster wouldn't work in that outlet, but worked just fine in a different outlet in the RV.
    This means the outlet you plug your microwave into needs to be fixed in addition to fixing the oven. Breaker? Fuse?
    >> I understand from another RV forum that microwave ovens for RVs have "special circuitry and cooling features" not found in regular countertop ovens for household use.
    Not really in my experience. Any microwave supplied with clean AC power and proper venting space will be fine.
    But I'd bet your microwave can be fixed affordably.
    The main internal things which can result in this model being dead (no display, no light when you open the door, no beep when you press a pad on the keypad) would be the 20A fuse and the magnetron temperature fuse. There could also be bad connections on the noise filter board.
    Also, sometimes a power surge can cause the power to be interrupted to the low voltage transformer on the board, and I regularly repair those boards. I can also write a technical statement to your insurance company or to an RV park as needed.
    At my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
    The relevant service manuals for this model are here and here.
    You can order Sharp parts from Sears or Encompass.
    Contact me directly if you need more help.
    - William E. Miller, AS-EET
    pupista@gmail.com
    http://www.MicrowaveControl.com
    Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
    Mar 08, 2017 | Sharp R1875: Over the Range Convection...
    Jan 16, 2013 | KitchenAid KHMC1857WSS Microwave Oven
    Jenn Air Built In Microwave JMC8127DDS - no power to the unit. I've removed all the screws I can see, but can't get the microwave to slide out to see if it is plugged in.
    Be advised that they are heavy. You may need 2 people to check this. The bracket may have a lip on the wall section that you have to take the weight off of to move it.
    Dec 16, 2017 | Jenn-Air JMC8127DD Microwave Oven
    WHEN PLUGGED IN THERE IS NO POWER, TOOK IT APART AND REPLACED THE 30 AMP FUSE BUT NO FIX, THE OUTLET IS LIVE
    Assuming you have a voltmeter (or multimeter) at your disposal, you will have to trace the power from the plug to the timer / control board. If the thermal cutout has activated/failed, you will also get a 'dead' appliance. It's mounted directly on the magnetron.
    Jun 08, 2011 | Amana AMV6167BDS Microwave Oven
    Loud popping noise after being plugged into 50 amp power source possible power surge unit in rv unit light still works but no power to make unit work.
    What happens a lot in these RV microwaves is that a surge will damage the circuit board and sometimes also blow the low voltage transformer.
    These are problems we can usually take care of for $39.95 and $54.95 respectively.
    You can get more information here.
    May 25, 2011 | Sharp R-1850A Convection/Microwave Oven
    I have a built-in AEG Microwave code MC166(0E?) My son unfortunately used the microwave as a timer so it was on for 30mins without anything in it. It now won't turn "on"; no light/clock...
    What fuse did you change? The fuse on the wiring that leads to the microwave needs to be intact, then the fuse in the Microwave itself needs to be checked. Usually there is a plug where the microwave is plugged in, in the cabinet above the microwave, you can take another small appliance or a power tester to make sure power is available in the outlet where the microwave is plugged in. If the power is on at the outlet then you'll know that it is the microwave itself that has turned itself off for some reason. You can get manuals for these ovens at this website
    May 11, 2011 | Microwave Ovens
    Problem with electrical source
    Does your manuel also tell you to use a DEDICATED 20amp circuit to plug your Microwave in to? More that likely you used a 15 amp circuit that other appliances were also plugged into. A refrigerator or other cooling item needs its own 15 amp circuit but can tolerate small amp draw items like a clock. The new, higher wattage microwaves need a 20 amp circuit for itself. Have your line checked , have your microwave fixed. Start new
    Aug 26, 2008 | Microwave Ovens
    Microwave Ovens Logo
    13 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
