Question about Lexmark X2600 InkJet Printer
I have Ubuntu 8.04. This X2600 Doesn't give me any options (Purge)etc. I'm not sure that all my functions are working properly, But I cant priht from most websites.
I contacted Lexmark, directly. Removed the driver and Installed a driver of a different series.
Works fine now.
Posted on Jan 27, 2009
How do i install a operating system on a sony old sony viao 600hep with no dos and no operating system and a broken cd rom drive. only have usb.
Check out this:
http://www.ubuntu.com/download/desktop/create-a-usb-stick-on-windows
This gives instructions on how to download, and create a ubuntu bootable USB stick.
http://www.ubuntu.com/download/desktop/try-ubuntu-before-you-install
This will give instructiosn on how to load and install from said USB.
You will need:
A working computer with Windows
A 2GB or larger USB stick
Internet connection
After you've made your USB stick, when booting up the computer you wish to install ubuntu on be sure you have the USB stick inserted when powering it on. When the start screen comes up press ESC to enter the BIOS or boot order. Select the USB stick from within the BIOS boot order menu, or the USB stick from the boot options menu.
Load ubuntu, install, enjoy.
Mar 13, 2015 | Sony Computers & Internet
My 99 expedition shuts off when I put it in reverse and shuts down when I have to stop fast at a red light. I have codes p0443 and p0441 on. Someone please help
P0443 code, EVAP system control purge control valve circuit failure, p0441 is related to p0443. if you fix it, both codes should be gone! to fix p0443-- Using a scan tool, command the purge solenoid to activate. Listen or feel for a clicking coming from the purge solenoid, If it doesn't click with scan tool activation, unplug the connector and examing the solenoid and connector for damage, water, etc. Then check for battery voltage on the feed wire with the key on. If you have battery voltage, then ground the control side manually using a jumper wire and see if the valve clicks. If it does, then you know the solenoid is working properly but there is a problem with the control circuit. If it doesn't click when you manually ground it, replace the purge solenoid.
Mar 22, 2012 | 1999 Ford Expedition
How do i get X P up on my computer after puting Ubuntu along side my X P home
when you install ubuntu, (or practically any linux) it will give you an option to shrink the windows partition - it then sets up a dual boot for you. Windows doesn't see linux partions at all - so the set up has to be down from the linux partion.
Dec 07, 2011 | ubuntu.com
Lexmark x2600 driver for ubuntu 11.0 please help
Please visit the Lexmark website to download and install the Lexmark X2600 Printer Driver for Ubuntu 11.0. Select your operating system, download and execute the file.
Aug 24, 2011 | Lexmark X2600 InkJet Printer
I would like to install my LexmarkX2600 on my computer an i am running Ubuntu on my computer now
There are some drivers listed under the Linux tab. I recommend clicking the "Learn more" link to find out if they are correct for your system:
Lexmark X2600 Downloads
Jan 14, 2010 | Lexmark X2600 InkJet Printer
Install Ubuntu
Make sure the computer starts from the cd drive.
see this page for instructions on changing the boot order
http://www.whitecanyon.com/how-to-change-boot-order.php
ones the boot order is set properly insert the cd in the drive and restart the computer.
ubuntu cd/dvd will load and give you some options on the screen, follow the prompts to install ubuntu.
if you need more help read the ubuntu documentation
https://help.ubuntu.com/community/Installation
if the above link is broken try
http://help.ubuntu.com/community/Installation
Aug 09, 2009 | PC Mall Ubuntu 8.10 for Linux
I need a driver for a lexmark x2600 printer that works with Ubuntu 64 bit
No driver exist, so I switched back to Xp Pro x64. I don't like windows but I cannot afford to replace all of my hardware.
Apr 08, 2009 | Lexmark X2600 InkJet Printer
X2600 has no driver for Ubuntu 8.04
You can download the driver from the Lexmark website here: http://downloads.lexmark.com/perl/downloads/downloads.cgi
Feb 10, 2009 | Lexmark X2600 InkJet Printer
Wireless problem
I'm Guessing your using Ubuntu 7.04... Due to a bug in the native driver shipped with Ubuntu, the wireless card on this laptop is detected and installed but you cannot find any wireless networks. Here’s how to fix it.
* Let’s disable the native Ubuntu driver. Type this in a terminal:
gksu gedit /etc/modprobe.d/blacklist
and insert at the very end of the file:
# buggy broadcom wireless driver
blacklist bcm43xx
* Next, do this in a terminal:
sudo rmmod bcm43xx
* Now, let’s download and install the windows driver for the wireless card. You have to download it from the Dell support website. Click here to download it.
Or you can use the direct link to the executable:
http://ftp.us.dell.com/network/R140747.EXE
Since it’s a windows self-extracting executable, you need wine to use it:
sudo apt-get install wine
then:
wine <path_to_R140747.EXE>
Replace <path_to_R140747.EXE> with the actual physical path to the file you downloaded from the Dell support website. Follow the instructions and extract the files to a folder of your choice. Alternatively, you could extract the files on a windows machine and copy them over to your ubuntu system.
* Now, let’s install ndiswrapper. We need it to load the windows driver.
sudo aptitude install ndisgtk ndiswrapper-common ndiswrapper-utils-1.9
* Let’s install the windows driver:
sudo ndiswrapper -i <location_of_bcmwl5.inf_file>
Replace <location_of_bcmwl5.inf_file> with the path to the bcmwl5.inf file you extracted earlier.
* Let’s make sure the driver is installed:
sudo ndiswrapper -l
You should get something like this:
bcmwl5 : driver installed
device (14E4:4311) present (alternate driver: bcm43xx)
* Now we need to set up ndiswrapper to load our new driver automatically:
sudo gedit /etc/modules
and add a new line that says:
ndiswrapper
That’s it, restart your laptop. During the restart, the wiFI LED should light up. If it doesn’t, try the Fn + F2 key combination. After the reboot, configure your network settings:
System -> Administration -> Networking
Enable the wireless connection and tinker with the connection settings if you need to. You may have to disable the wired connection because wireless and wired connections may not work simultaneously - your mileage may vary in this regard.
Note:
It seems Network Manager prevents the card from connecting to detected wireless networks. I advise you to remove it if you can detect wireless networks but cannot connect to them. To do this, type the following in a terminal:
sudo apt-get –purge remove network-manager network-manager-gnome
Alternatively, you can open Synaptic and remove these two packages.
* Summary:
1.) Install ndiswrapper
sudo apt-get install ndisgtk ndiswrapper-common ndiswrapper-utils-1.9
2.) Install the windows wireless driver
Remember to replace <location_of_bcmwl5.inf_file> with the actual path to the location of the bcmwl5.inf file
3,) Make sure the card has been detected and installed
ndiswrapper -l
4.) Disable the native ubuntu wireless driver
Insert at the very end of the file:
blacklist bcm43xx
5.) Remove Network Manager if it gives you problems
Reboot
You wireless card should be working flawlessly now.
I Hope this helps :)
Cheers
Jasonjohn89
Jan 31, 2009 | Computers & Internet
Configuring Webcam andPrinter in Ubuntu
Normal 0 Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Jul 23, 2008 | Computers & Internet
Lexmark X2600 InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
