Question about Nordic Track Nordictrack Elite Xt Console Insert Panel
Speed is off
Speeds are way off, will show 4.5 and doing about 2.0
    Genius:
  • 1,669 Answers
1) Run the calibration software for easy diagnostic and fix it. go to owner manual, and go under the hood for following the steps.2) Exchange the batteries by new ones, cleanup contact from the batteries for oxide, and see if there are Not SOME WIRES BROKEN OR LOOSE.3) Tight the keypanel from flexible cable vs display board, 4) tigh the display board vs lower board. 5) attached the sensor reed switch by 1/8" or 3 mms adjusted according. 6) Test the main motor controller board for 115 Vca, and then +5 vdc for output coming to display board very important.
7) Test the transformer for primaRY VOLTATE see the tip adjust how to do it. 8)
Posted on Jan 21, 2013
Why does my 96 honda shadow 1100 have a four speed trans
Hi, Kieth the first 2 years of the VT1100's had 5 speeds then in 1987 they came with 4 speeds something about 2nd gear was a complaint from riders, in the mid 90's Honda went back to the 5 speed your Honda Dealer can give you a better breakdown some riders with 5 speeds wish they had 4 speeds go figure for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.hondashadow.net/forum/72-technical-discussion/68969-vt1100c-4-5-speed.html
HONDA MotorcycleShadow 1100 VT1100
1985 1998 Honda Shadow VT1100 Service Manual Moto Data Project
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual
Jul 17, 2016 | Honda Motorcycles
The heater to my 2000 Nissan Altima does not function on speeds 1 and 2, but does work on speeds 3 and 4.
Your blower motor resister could be bad,here's a link to where it's located,easy to remove yourself,2 screws hold it on,first remove electrical connector from it,then remove screws.This part controls blower speed.When going out,all speeds don't work.Here are the resistors,remove yours and compare to these.
Dec 22, 2012 | 2000 Nissan Altima
The orange lights are flashing, is there something wrong?
Try:
1 Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
2 PPM print speeds are based on the highest speed printer driver mode. Photo print speeds are based on the default mode driver setting using Canon Photo Paper Plus Glossy paper. Print speeds will vary depending on system configuration, interface, software, document complexity, print mode, types of paper used and page coverage. CPM copy speeds based on fast mode setting using plain paper. Copy speeds may vary based on document complexity, copy mode, page coverage and number of copies.
3 USB 2.0 Hi-Speed requires Windows XP, 2000 or Mac OS X operating systems. For Windows 98, Me and Mac OS X v.10.2 to 10.2.6 operating systems, the printer will operate at USB 1.1 specifications.
Oct 22, 2010 | Canon PIXMA MP150 All-In-One InkJet...
A/C has quit working on fan speeds 2 thru 4.....it will only work on speed 1 but the fan itself still works on all speeds...it just seems to kick the a/c off on speeds 2 thru 4 and blow hot air ....2001...
You probably have a bad fan switch. I had the same issue and had it diagnosed and replaced. It fixed the problem, but it seems to be coming back less than 2 years later.
Jul 08, 2010 | 2001 Mazda Protege
Just got H 2 2005 4 buttons 4 the 4 wheel drive
Use 2 wheels, the other 4wd low ,for climbing at slow speeds: 4wd high, for driving on low traction roads,like mud or snow,at medium speeds: 4wd auto full time all wheel drive, for highway speeds on slippery surfaces, like rain or light snow.
Jan 12, 2010 | 2005 Hummer H2
My Jeep 2003 Sport, heater only works on #2 &
You heater only works on speeds #2 & 4 because the blower motor resistor pack is defective. Replace it.
Jan 02, 2010 | 2003 Jeep Liberty
Heater blower only works on the 2 highest speeds ? Ranger is 2003 4 dr. with factory air
it could be the blower motor resistor, this is what gives the motor different speeds, they are very common to burn out 1 or 2 speeds. They are not very expensive, I would look into that first
Nov 18, 2009 | 1999 Ford Ranger SuperCab
What do the different fan speeds indicate
The different fan speeds are different airflows across the coil and blows out into the room..
For instance speed
#1 is usually high speed
#2 is medium high
#3 medium low and
#4 low speed
Aug 17, 2009 | Heating & Cooling
2000 Pontiac Grand Prix interior fan speeds 1-4 not working
Check the ground, the resistors are accully resisnting the Negitive Current.
Jul 28, 2008 | 2002 Pontiac Grand Prix
Nordic Track Nordictrack Elite Xt Console Insert Panel Logo
59 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
