Question about Panasonic TOUGHBOOK CF-18 Tablet PC
Cf-18 is running slow - Panasonic TOUGHBOOK CF-18 Tablet PC
My wireless is slow
cnet has free programs ccleaner,ncleaner,fcleaner,and go to major geeks for glary slim utilities.i use all in any order when mines slow.also if u know what speed ur paying 4 do a speed test.sometimes u can change adapter setting from default channel 8 to 6 or 11.hope that helps-good luck
Jan 05, 2013 | Panasonic TOUGHBOOK CF-18 Tablet PC
My cf-18 tough book has worn out usb ports
If the USB board is still functioning, you can get a PCIMCIA to USB adaptor (or similar) which will allow you to run usb devices from the card
Jan 14, 2011 | Panasonic TOUGHBOOK CF-18 Tablet PC
Where can I download a Toughbook CF-18 Tablet PC Recovery Disk, mine disappeared. rc
Finding a complete recovery disc is prooving difficult. i have found a couple of alternatives to getting a complete install on disc, but they do take a little bit more time.
if you have a copy of the windows which you wish to run your system on. which nowadays arent hard to comeby, then you can use this link as a driver and compac software restore disk
http://www.user-guides.co.uk/cddownload/Panasonic/PanasonicToughbook/Panasonic-Toughbook-CF-18-XP-Driver-CD-Recovery-Restore-Disk-108878.html
however these downloads / cd'a have to be purchased. i really wouldnt bother with it. drivers and apps for compac arent a must have and usually just do things to make the GUI fancey or easy to use. most drivers will be picked up on windows install and the rest wont be hard to track down. a standard windows install is surfice for most things and runs quicker than an install full of tosh little programs.
Aug 14, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Trouble booting!
You could attempt to boot to safe mode, and run the Start> System Recovery > PC Recovery Application.
Otherwise, I'd boot to safe mode, select start, run, type: msconfig, select the startup tab, remove any unwanted startup items that may be causing the system crash.
Hope this helps.
Jan 08, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Touch screen
Send me your email address. I have all of the drivers. I ran into this problem, be cause the tablet drivers from panasonic would not work. I downloaded a driver direct from WACOM and it solved the problem.
Dec 01, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Cf-18 toughbook
The BIOS may not support the larger drive at all; I suggest you look for a Toughbook forum and repost there and check Panasonic's site for a manual download and possibly a BIOS upgrade if the unit is equipped with a flash BIOS.
Aug 27, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Tablet PC Logo
48 people viewed this question
Top Panasonic Tablets & eReaders Experts
Paul Wang
Mike
Are you a Panasonic Tablet and eReader Expert? Answer questions, earn points and help others
