Machine will not fill with water - Washing Machines
  • Washing Mach... Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Posted on Jan 22, 2013
Water keeps filling even when not in use
hi Jeremy.
Why does my washing machine keep filling up with water when not in use? Ensure that the waste pipe of the washing machine is higher at one point than the drum of the machine, this will prevent water running back into the machine. Normally this would fill the machine with dirty water. Or it could be a faulty water inlet valve, which will fill the machine with clean water.22 Sep 2007
why is my washing machine filling up with water when off ...
forums.moneysavingexpert.com/showthread.php?t=558300 Search for: Why does my washing machine keep filling up with water when not in use?
if you want to read up more then go to this link.
Washing Machines keeps filling even when not in use Google Search
Nov 18, 2017 | Washing Machines
My washing machine wont fill up with water, what would the problem be, ive cleaned the hose at both ends so its not blocked?
usually the hot and cold water solenoid fail stopping water to flow
replaceable part
location
in where the hoses attach to the washing machine
May 09, 2016 | Washing Machines
I have dwf-170 mp washing machine, the machine does not fill with water.
that is not the water pump but the inlet valves are you sure the water is turned on behind the machine
Mar 28, 2016 | Washing Machines
Fills, goes 4 minutes and fills, pauses, then fills, pauses then fills, over and over
Sounds like its syphoning out the water. If it was overfilling, you would have water everywhere, the machine would eventually flood. Check the drain hose. Make sure the end is higher than the water level in the machine and that there are no extensions running outside which have an end lower than the water level in the machine, it will start syphoning, usually after the first pump out.
Jan 01, 2015 | Washing Machines
COLD WATER WILL NOT FILL; NO COLD WATER RINSE. MODEL NUMBER 110 26452502
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 08, 2010 | Kenmore Washing Machines
The water is on but the water doesnt fill the washer. the spin cycle works how do i get the water to fill the washer?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Sep 03, 2010 | Maytag MAV8557 Top Load Washer
My sanyo washing machine does not fill in water, its director drain out. model asw 40sit.
If the washer is not filling with water then the water inlet valve needs to be checked.The water inlet valve is also called water fill valve.If the fill valve is faulty then it will not the water to get filled in the machine. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Washing Machines
Not filling with water. everything else works. it will agitate without the water in the tub. it thinks there is water in it
heatman101
Aug 30, 2010 | Maytag Dependable Care LAT9706
Washing maching not filling with water
The problem is most likely the water fill sensor switch. If it is telling the machine that it is full, it will go right to agitate.
Apr 25, 2009 | Roper RAB2121KW Top Load Washer
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
