Question about Toshiba Satellite A105-S4334 Notebook
I am having problems with my sd card reader working. I put my camera memory stick in and the computer won't open the file.
    Problem Solver:
  • 3 Answers
You might need to download the driver for your card reader. You have to go the the manufactures web site and click on support and downloads, enter your type of computer and then download the driver for your sd card reader. Is it a laptop or a desktop?
Posted on Jan 27, 2009
2 Suggested Answers
  • 8 Answers
SOURCE: memory card reader
this happens due to some restirction on the memory card i faced the same problem all you have to do is just copy the pic on to the laptop or on any other laptop and then you can format this card however before u format copy the pic as it will delete the data from the card .
i did the same as did not work on my hp laptop and worked on lenovo laptop for my phone memory it is also called as registry problem of the memory card .
thanks try it out and please let me know
thanks alson
Posted on Jun 23, 2008
Can I import camera pics to a Dobly Home Theater laptop, by Acer?
First a nitpick: your memory card is Memory Stick Pro Duo, it's not an SD card. Secure Digital is one specific type of memory card, distinct from xD, CF, Memory Sticks, and other memory card types.
Okay, not that I've got that off my chest, yes you can import pics to your laptop. Just connect a card reader to the USB port and then put your Memory Stick into the reader. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files.
Card readers should be available at just about any department, electronics, or office-supply store. One important point to remember is to make sure you get a card reader that can read Memory Stick Pro Duos. If you get, for example, an SD card reader, it won't do you any good.
Jun 11, 2012 | Sony Cybershot DSC-T200 Digital Camera
Camera locks up with SD card
Put the SD memory card into an USB card reader and plug the card reader into the USB port of a working computer to check if the memory card is working.
If the computer cannot detect the memory card as an external storage device and cannot open the files or folders and it cannot be formatted in FAT32 then the SD memory card is faulty and needs to be replaced..
Mar 24, 2012 | Sanyo Xacti VPC-S770 Digital Camera
SD card not transfering raw files to computer completely
Please remove the SD card from the camera. Connect the SD card to the computer using the external memory card reader and then transfer all the images in the computer or laptop. Then try to open all the images.
Feb 20, 2012 | Nikon D80 Digital Camera
My memory stick of 1gb has full memory filled and now i m unable to see the photos loaded in it through the camera or the card reader
That means the memory card was corrupted. You need a memory card recovery to recover photos before seeing it. I recommend you use Card Data Recovery, i can recover data from corrupted or damaged memory card.
Aug 28, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
How do I download my pictures from my Sony camera to the computer?
Here is one instructional video tutorial from Sony Support; also could try this procedure:
- Take off your memory stick from your camera and insert it into your memory stick adapter. Open your camera's battery case and gently push the memory stick until you hear a faint "click," then remove it from the camera. Place the memory stick inside the adapter that comes with your camera.
- Insert the adapter into your computer's memory card reader, if you have one. The adapter, which is larger than the memory stick itself, is approximately the same size as an ordinary SD memory card.
- Connect your Sony digital camera to your computer using its USB cable if you can't find or don't have a memory stick adapter. Insert the small end of the USB cable into the camera. Insert the wider, flatter end into one of your computer's USB ports.
- Click "Open Device to View Files" to open your memory stick or camera. Search for the DCIM folder and click on it. Navigate through any photo subdirectories you've created and highlight photos you want to transfer to your computer. Right-click anywhere in a given folder, then click "Copy." Go to the location where you want to store your images, then right-click within that folder. Click "Paste" to transfer your images.
Hope this helps (remember to rate and comment this answer).
Jul 03, 2011 | Cameras
Cannot copy out photos from nikon s3000 camera. I'm using 8GB SD. Nikon transfer won't work
Hi if you have a memory card reader just take the card out of the camera and put the card in the memory card reader your computer will then open them up with no problems, if it dont open up the files on its own you just press the start button then click on my computer then click on the memory card that will then open all the files up on the memory card and it will then let you transfer them to where ever you like.
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Dec 08, 2010 | Nikon Coolpix S3000 Digital Camera
I recently deleted my photos. How can I retreive them? digital camera sony cybershot dsc-w120 7.2 mega prix.
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download this digital camera recovery software
Install and open the photo recovery software, select the memory card, and click 'Start' button.
Oct 09, 2009 | Sony Cyber-shot® DSC-W120 Digital Camera
I cannot get my konica minolta dimage g600 to accept sd card
Hi
the following memory types are supported byt your camera
SD (Secure Digital) Memory Card / MultiMediaCard (MMC) / Memory Stick / Memory Stick Pro
Do you have a card reader on your computer? We could format the card on the computer and then see if it works with the camera.
Can you tell me the size of the sdcard?
To format the card on your computer plug it into the reader, open my computer and find the card from there, ones you have found the right one from my computer right click and select format, Try formating the memory card to fat 12 or 16 and then when the format is complete insert it into your camera again.
(turn off the camera, insert the card, turn the camera on)
If the memory card still doesn't work plug it to the computer again and this time format it to fat32.
If this ia new sd card with alot of storage do you have a smaller card that already works on the camera?
Apr 13, 2009 | Konica Cameras
I have lumix dmc-lz7. Tonight I put a 2 gig sd card into my built in card reader , Dell pc and it didn't work and did not even show the drive on computer. Then, to check it out, I connected camera to usb...
maybe the card reader is not SD/SD HC compatible, the same problem occurs wiith the Memory Stick Pro/Duo of sizes 2GB or above in my Desktop Computer (Compaq) and not in my Notebook (Compaq) the card reader and the machine are newest and are compatible
Jan 30, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Memory card lg kc550
omg... put your memory card with the bigger card witch you get when buying a memory card into the computer. i do everything with usb but if you cant then do it this way
Nov 13, 2008 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Toshiba Satellite A105-S4334 Notebook Logo
85 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
