Question about Scholastic Teaching Resources Sc-9780545234542 Motivating Math Homework
I dont know how to make 1 a fraction - Scholastic Teaching Resources Sc-9780545234542 Motivating Math Homework
    New Friend:
  • 3 Answers
1 can be expressed as 1/1, 2/2, 3/3.......n/n
Posted on Jan 21, 2013
On TI-84 plus calculator i know how do do fractions but i dont not know how to change the settings so when i type it in it actually looks like a fraction
I will assume that your calculator is equipped with one of the later Operationg systems. (2.53 MP and later).
To be able to use the Math Print templates you must set the IO display to MATH.
To do so turn calculator ON, press the MODE key to display the configuration pages. Scroll down to reach Page 2. At the top of the page you have Math and Classic. Use left arrow key to highlight MATH and press ENTER to validate.
Afterwards, when you want to type in a fraction or a loagb function, etc. press the ALPHA key. You will see TABS at the bottom of the screen. Activate a TAB by pressing the Fx key that is below it (F1, F2, or F3). You can move from one TAB to the next by pressing the Left/Right navigational keys.
Assuming that you pressed the improper fraction key, you will see a template of a stacked fraction. Enter the numerator in the upper square and the denominator in the lower square. Press the enter key.
In the MODE configuration you can force the display to be mixed fraction or improper fraction. You can also force a decimal representation of fractions (as results of calculations).
Dec 12, 2011 | Texas Instruments TI-84 Plus Calculator
Why cant anyone tell me how to do fractions on my calculator i dont have the / button
Yes, you do have the division key. It is the division key. However, if you want the fraction to remain a fraction, enter the numerator, press the division key, type in the denominator then Press [MATH] [1:>Frac] then press ENTER. The fraction that will be displayed will be the reduced form.
Sep 19, 2011 | Texas Instruments TI-82 Calculator
I need help...i dont know how to put in exponents, negative exponents and i dont know how to put in fractions
For negative numbers (not just exponents), make sure you use the (-) key just to the right of the decimal point key, not the - key for subtraction.
For what follows I'm going to assume you have at least version 2.53 of the operating system for the 84Plus. If you have an older version, I STRONGLY recommend you update it:
http://education.ti.com/educationportal/sites/US/productDetail/us_os_84plus.html
You can use the "n/d" command in the MATH/NUM menu to enter the division bar. For example, to enter 1/2, press 1 MATH right-arrow ALPHA [D] 2 ENTER. If you just want the number, you can also enter it as 1 / 2.
You can convert a decimal number to a fraction using the >Frac command in the MATH menu. For example, to convert 0.2 to a fraction, press . 2 MATH 1 ENTER.
Mar 16, 2011 | Texas Instruments TI-84 Plus Silver...
When i type in a decimal and then hit math and try to convert into a fraction, my calculator still shows the decimal as the answer. im pretty sure im doing it right but i dont know what is wrong. is there...
Yes, there is a feature or, setting in the mode that will stop you from converting fractions. Go to the mode screen by pressing the [MODE] key. [Down arrow] 9 times and, highlight and select the n/d by pressing the [ENTER] key. Next, [Down arrow] 1 time and, highlight and select Frac by pressing [ENTER] key. Just escape or, quit out of the mode screen and, the calculator should now be set up to convert your fractions. Just remember to go back and, change the last setting you made when you go back to dealing with decimal numbers.
Jan 04, 2011 | Texas Instruments TI-84 Plus Calculator
I try to write a fraction down on my TI-83 calc. But i dont know how to find that function. When i go to MATH and choose FRAC it doesnt do anything even if i type a number down next to it.
To keep a fraction in fraction format (though reduced) you must enter the numerator, press the Division key, followed by a number (denominator).
If you press ENTER, the fraction will be displayed as a decimal number.
However if you use the sequence [MATH][1:ToFrac] peior to pressing [ENTER] the result will be the irreducible form pf the fraction you entered.
Obviously, if you enter an interger number there will not be any fraction display.
Also, if your "number down next to it" means after the [ToFrac], then it is clear that nothing will happen.
Try what I suggest and see if that works.
Apr 16, 2010 | Texas Instruments TI-84 Plus Silver...
How do i do fractions with this calculator? there are so many keys i dont know what to push.
The primary key to enter something that resembles a fraction is the division key, the one above the multiplication key.
However, any division you enter yields a decimal number, unless the result is an integer.
To keep the result of a division as a (reduced) fraction use the [|=>Frac] or [ToFrac] command. It is accessible by the following key sequence
[MATH][1:ToFrac].
Insert it after the fraction, before pressing the [ENTER] key to get the result.
By pressing [MATH][2:ToDec] you convert a fraction in to a decimal number.
Apr 10, 2010 | Texas Instruments TI-83 Plus Calculator
Fractions
  1. Enter a numerator
  2. Press [/] for division
  3. Enter the denomoinator
  4. Press [MATH]
  5. Press [1:|=>Frac]
  6. Press [ENTER]
Keep in mind that the fraction that will be displayed will be a fraction reduced to its simplest form.
To convert a fraction into a decimal number Press [Math][2:|=>Dec].
Jan 27, 2010 | Texas Instruments TI-84 Plus Calculator
I don't know how to use fractions
Enter any fraction as a division problem and your TI 83 will evaluate it as a fraction.
For instance, 3/4 = three fourths.
Nov 13, 2009 | Texas Instruments TI-84 Plus Calculator
How to us a fraction on the ti-83 calculator? I have home work due on this tues. and i dont know how to put a fraction in on this calculator .
Ther e is no dedicated key to do that but ther is a command ToFrac noted as ->Frac. To access it use [MATH[1:->Frac].
Two ways of using the command.
1. You want to reduce a fraction to its simplest expression
27/48 [MATH][1:->Frac] [ENTER] gives the reduced fraction 9/16
2 You do not want your results converted to decimal numbers
(27/48) [x] (5/7) [MATH][1:->Frac][ENTER] multiplies the two fractions and gives a fraction as a result. 45/112
3. Your result is in decimal form and you want to cast it into a fraction. The conversion will be exact only for certain numbers. Results kept in fraction forms are more accurate than those represented as decimals.
Hope it answers your question.
Oct 10, 2009 | Texas Instruments TI-83 Plus Calculator
Scholastic Teaching Resources Sc-9780545234542 Motivating Math Homework Logo
77 people viewed this question
Top Scholastic Toys Experts
ray gallant
Terry Hair
ptpumpman
Are you a Scholastic Toy Expert? Answer questions, earn points and help others
