Question about Refrigerators
Kinetico reverse osmosis water flowing very slow
Our Kinetico reverse osmosis water runs VERY slow out of the faucet at the sink. The system is in the basement just below the sink. I replaced both the sediment filter and the post filter at the beginning of decemeber, it ran o.k., but not great for about a month, then started going very slowly again, so I replaced the prefilter AGAIN, but it still hasn't gotten any better. We don't have a Kinetico store or service person anywhere close anymore, so I need to know what I can look at to address the problem myself. Thanks!!
  • andyman96513
    andyman96513 Feb 10, 2014
    It sounds like the most likely solution is that the storage tank lost its precharge. When this happens there is no pressure to discharge the water that is stored in the tank.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
I am guessing you have checked to make sure the water flow into the osmosis system to make sure it is at proper pressure? If so is this a whole house system or just for the kitchen? If it is a whole house do you have the same problems in other parts of the house?
Posted on Jan 22, 2013
  • 351 Answers
SOURCE: Fridge water filter replaced now flows very, very slow
Hi .. first I would try and eliminate the filter as the problem. Remove the filter and try the water again. If the water flows strong, then the filter is the problem. If the water stills sputters and is low flow, then there is a partial blockage in the internal tubing , or a problem with the supply. If you roll the fridge out to get at the suppl. you could shut it off and disconnect the supply tube from the fridge, then turn the water on slowly to check the flow at the supply. If the flow is good there , then the blockage is internal.
Posted on May 03, 2010
Noggin
  • 944 Answers
SOURCE: GE Refigerator filter problem
First thing to try is to cut open one of the old filters (ideally straight down the middle)and see if you can tell what is blocking it. Wear gloves and keep away from the stuff inside in case there is a chemical component - it should say on the packet of the filter if this is the case. You could also install another, coarser and cheaper filter in the water hose just outside the fridge - you usually can get a housing with a hose fitting on each end and a filter inside at most hardware stores. If you turn off the water pressure, cut the hose to the washer half way from the wall, then you can install the new filter with a couple of hose-clamps(Jubilee-clips). These sort of primary filters will remove any sandy or silty material in the water (you might not notice it usually from the tap) and also there is the possibility of algae/weed growth that is clogging the filter. It also might be worth calling your local water supply authority/utility and discussing the problem with them - they may want to come and check, or ask you to send a sample in for analysis. Some of what they can do, you can achieve yourself by putting a closed container of the water somewhere where it can get no vibration and waiting a week or so to see how much solids settle out. A tall thin container works best, as long as you can keep it dead still. Just possibly the filters are a defective batch, and it is coincidence that you got more than one - perhaps you bought them from the same small store? Also possible is that there is something in the pipe near the filter that is disturbed when you change one for a few days, then settles back into place blocking the hose - check there is not a small piece of mesh inside the water inlet hose connection at the back of the fridge - sometimes there is and these strainers can get blocked by something that behaves erratically. Hope this helps - please post again if not :)
Posted on Mar 29, 2007
aborcass
  • 2651 Answers
SOURCE: kenmore side by side dirty water
the problem might be linked ot your reverse osmosis system itself, something about filtering and storing previously filtered water, which if i remember correctly creates a "harmless" bio film the consistency of what appears to be brine shrimp sized particles floating in water. so i would remove the filter from the refig and flush out again.
Posted on Mar 25, 2008
  • 3 Answers
SOURCE: slow water flow on Whirlpool Gold 25.6 cubic
The water line tap may be screwed back into the water line or you did not sufficiently poke a hole into the water line with the tap. We had the same problem. Shut off the water supply, remove the tap from the line and check the size of the hole. my bet is the hole is very small. Either drill out the hole with a drill and replace the tap (with a new rubber grommet) or add a tee into the line with the proper size compression fitting (that is what we did) and the water will flow freely..
Posted on Jun 21, 2008
Greg20
  • 149 Answers
SOURCE: Whirlpool ED22PE refrigerator in-door water dispenser very slow
remove the saddle clamp that some idiot put on the supply line under your sink and splice in a real "T" with a real cutoff. hopefully the saddle clamp is past your main valve and not before it or you'll have to turn off all your water first.
Posted on Jun 11, 2009
We just changed out filters in out K5 unit and turned on the water and the faucet and the water is running very slowly. What can we do to get it running strong again
Your manual is here:
https://www.kinetico.com/media/2329/13034j_manual_owners_k5_1216.pdf
Did you follow the filter change procedures completely and correctly including depressurization? Did you change the pre-filter - probably clogged? Did you open up the faucet fully?
OK. Now be patient! Wait for the tank to fill. With a maximum filtration rate of 3 gal per hour, it will take 5 min to produce the first quart.
Aug 23, 2017 | Plumbing
MY KINETICO QUAD 50 QUIT MAKING SOFT WATER. LOOKING ON HOW TO CHANGE OUT AND OBTAIN TO REPLACE
Hi Dale,
I worked at a Kinetico dealership for 6 years. I am very familiar with the quad 50. Unfortunately, Kinetico can only be serviced by a kinetico dealership, or someone who has the parts and the know how. They can be difficult to diagnose and fix if you are not familiar with them. You say you want to change it out and replace it ? You might be better taking it in to a kinetico dealership and having it serviced. They are worth it. If not, you can go on the internet and shop for a water softener. www.ohiopurewater.com or www.discountwatersofteners.com
May 04, 2011 | Plumbing
How do i unhook the spigot from my undersink reverse osmosis system i cant get the hose connections to release so that i can take the spigot off the sink. i am putting in a new sink
If they are quick connect fittings make sure all the water pressure is off the lines. Turn off the RO tank and valve feeding system, open the faucet and try taking lines off again. If no luck, mark the lines with masking tape and cut them a couple inches below faucet to remove.
RJ
Oct 24, 2010 | Culligan Under Sink Water Filter
Kinetico water filter leak
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} What you are describing sounds like a quick connect fitting. I have included a link below to a video that explains how this type of fitting works. If you are using plastic tubing with these fittings you may be able to remove the tubing from the fitting and cut back about ½” from the end of the tubing and reinsert it into the fitting. Do not cut the tubing with scissors, use a tubing cutter or razor blade knife (see video). If that doesn’t solve the leak and you find that you need to replace any fittings we have a complete selection located here: http://www.freshwatersystems.com/c-276-fittings-valves-tubing.aspx
Geoff D., CWS-I - WQA Certified Water Specialist
Fresh Water Systems, Inc - http://www.freshwatersystems.com 1.877.335.3339
Mar 16, 2010 | General Electric Profile Smartwater Ultra...
I own the Wher25 Reverse Osmosis system. I
There is a blue cap on the body of the white pressurized water tank. Twisting off the blue cap, you will see a air nozzle - similar as those on the tire. You need to pressurized the tank to 60 PSI. I spend hours to figure out this solution on my own system.
Mar 14, 2010 | Home
Kinetico Water Softening Unit has brine tank drainage problem
This sounds like the resin cylinder is perforated or connections at the top are leaking. The brine tank should only have a little water in the bottom - if it is full of water (maybe even up to the overflow?) then you will need to replace the resin cylinder or fix a leaky connection to it.
Is the water in the brine tank 'rusty'?
Feb 11, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Is it possible to contaminate the membrane and filters by placing drain under pressure in order to clear and forcing water out the overflow on the side of the faucet of the whre 25 Reverse osmosis system
OK, now I understand. First, on the Reverse Osmosis Membrane Housing Outlet Ports there is only a Check Valve attached to the Permeate (Pure Water) Port, not the Concentrate Port (Drain Water). The Permeate line is what fills the storage tank, so you don't want back pressure from the tank reversing into the membrane filter which could severely damage it. So, there is a high Risk for Sewer Water to Back-flow into the Membrane Filter and Contaminate it as it is discharging water to the sewer drain if there is any noticeable pressure restriction in the drain distribution manifold. Second, this is why "Air-Gap" Faucets are supposed to be used when installing Reverse Osmosis Systems. With an Air-Gap Faucet, there are three (3) attachments for tubing at the base of the faucet, and a small hole drilled out underneath the lever or handle of the faucet. The 1/4" pressurized drain line tube from the RO System attaches to the 1/4" barbed fitting under the faucet base, then a 3/8" drain line tube attaches to the 3/8" barbed fitting. So when the drain water is pumped up to the faucet under pressure, it returns to the sewer line under Gravity, or No Back Pressure. Then, if the plumbing becomes restricted in any way that the RO Unit can't drain into the sewer under gravity feed, the hole drilled in the base of the faucet allows the back pressure to be escaped to the atmosphere, and if necessary drain water out of the hole until the plumbing pressure restriction can be resolved. This eliminates the possibility of a reverse flow pressure situation from occurring. Hope this helps, and you can always visit us online at www.puresafe.com We have filter cartridges for all makes and models of RO Systems, and 1/2 micron filters that no one else in the trade is using at this time. Thanks, Victor
Aug 05, 2009 | Whirlpool WED6400S Electric Dryer
Water filter system leaks at tap
The line from the faucet to the drain was plugged. I cleared the line and the system is working well.
Apr 14, 2009 | Plumbing
Replacing charcoal in my kinetico water softner
On the top of the unti there is a plastic site glass it also will have a phillips screwdriver slot when you insert the screw driver you have to push down and then turn it clockwise until you hear it kick in the let off let it run the entire cycle then run a faucet to make sure everything is clear and clean
Nov 11, 2008 | Plumbing
Refrigerators Logo
955 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
