Question about Craftsman 7.8 Generac Generator Engine Muffler Exhaust 4200 Watt Part No. 83071
I have a craftsman generator model 3580.327140 it will start and run for a minute then dies it doesn't seem to be a fuel problem I just changed the oil could it be the autamatic shut off from the
  • 202 Answers
SOURCE: craftsman garden tractor stalls after running for about 20 minute
do you have the right fuel filter? some are for pressure and some are for gravity feed, the pressure type (fuel pump) wont flow the gas correctly. another possibility would be the coil.
Posted on Jul 07, 2009
SOURCE: Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
Posted on Aug 28, 2009
  • 138 Answers
SOURCE: Craftsman LT1000 ridign mower engine dies after 15 min-deadman on
There are several things that could be going on, but what you said in your description about the dead man switch in the seat may need your attention first. The switch it self could also be bad. After you rule this out the next thing I would check is the fuel shut off solenoid located on the carb when you turn the key on to run you should hear a click and feel it in the solenoid. After this you may have a fuel pump issue or a coil issue. but from what you I have described I believethe first 2 itmes I mentioned should fix your problem
Posted on Oct 09, 2009
  • 1584 Answers
SOURCE: my Model 91915294 5hp 25gal Craftsman sir
Sounds like a leaking valve to me thats why no shut off.
Posted on Mar 05, 2010
daneinwv
  • 124 Answers
SOURCE: I have a Craftsman 625
My name is Dane and I am going to try to help you solve your problem.
I believe that you have clogged jets/passages inside of your carburetor. This can happen when an engine gets little use, allowing the fuel in the system to get old and begin breaking down. If fuel is left in a Carb for more than a year, it can eventually turn into a jelly like consistency, and clog the fuel system. What I believe is happening in your case is that the float needle inside the Carb is not allowing gas to enter the carb fast enough to keep up with demand. That's why it will run for 10 minutes and then shut down. After it sits for a while, the float bowl slowly fills back up and it will run for 10 more minutes.
Now for the bad news. This is an extremely difficult carb to work on. It is all I can do to get these Carbs off an engine and back on again to clean them. They are tough because you have a big air filter housing and 2 long bolts with gaskets and then the carb itself and spacers, that you have to hold together as a unit and start the bolts holding the carb to the engine. If you are a good enough mechanic to do this, you will already know how to do it. If not, I honestly suggest you take it to a shop and let them clean it for you. A new Carb isn't all that expensive, so you may want to consider just letting them replace it instead of cleaning.
I hope I've helped. If you found this information useful, please leave feedback as deserved. Thank you! Dane
Posted on Dec 04, 2010
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
What to do? I have a craftsman GT 5000 with a 25 HP Kohler and it will run for about 10 minutes and then start cutting out and die. I have changed the fuel filter with no resolve. What should I look at...
Make sure the choke is coming off. Check the compression.Many times the head gasket may leak when the engine heats up. Also check for spark sometimes the magneto can heat up and quit after running a while. See if it will run if you prime with a little fuel, if so ,some of the Kohler engines this size have a fuel pump that could be failing. Check for vapor lock. It takes air and fuel properly mixed, spark and compression any of these missing the engine dies.
Aug 06, 2014 | Kohler Command Pro OHV Horizontal Engine...
Engine won't start, doesn't seen to be getting gas.
Potential 'air lock' - try running with out fuel tank cap on
Cap should have a fine breather hole in it
May 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine will not turn over
A FUEL PROBLEM. It doesn't over or doesn't keep running when gas is gone. Doesn't turn over, remove spark plug to let fuel out.
Nov 12, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My 7-year old 25cc Craftsman line trimmer began surging during use, would bog down when given throttle, then would completely die, became hard-starting, and now doesn't start and run at all. Acts like...
A new fuel filter with new fuel lines and a rebuild kit for the carburetor should do it. You may even be able to get away with just the gasket and diaphragm kit for the carburetor. It is cheaper than the complete rebuild kit if you choose. Run synthetic oil and these things will last a good long while.
May 14, 2011 | Craftsman 25cc Gas Line Trimmer
I have a Craftsman 2.5 Turbo 18" chainsaw. Yesterday it would start and run briefly and the die. I changed the sparkplug and cleaned the air filter and now the saw will not start. The plug is...
Seeing a lot of fuel line problems due to ethanol. Make sure your fuel lines and primer lines are in tact. If the fuel line has broken, you may also need to clean out the inlet screen in the carburetor which can also become clogged.
Feb 12, 2011 | Craftsman sears 18" Chain Saw Chain (...
Craftsman garden tractor stalls after running for about 20 minute
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 7.8 Generac Generator Engine Muffler Exhaust 4200 Watt Part No. 83071 Logo
26 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
