Question about Schwinn 250 Recumbent Bike
Schwinn 250 recumbent bike is stuck cycling from easy to hardest setting every 20 seconds. None of the pre-programmed workouts work. It only cycles from easiest to highest difficulty and back every 20 seconds. It is brand new and came out of the box stuck in this cycle. I have unplugged and plugged multiple times to reset but it only repeats the cycle. I have also checked all connections and wires and everything is solid. What do I do to get it out of this cycle it is stuck in?
4 Suggested Answers
  • 832 Answers
SOURCE: Error 3 (E3) on Schwinn 240 recumbent bike. How
No speed/RPM reading, Console displays "E3" error code
Check data cable integrity All wires in cable should be intact. If any are cut or crimped, replace cable.
Check data cable connections/orientation, insure cable is connected securely and oriented properly. Small latch on connector should line up and snap into place.
Check magnet position (requires shroud removal) Magnet should be in place on flywheel. If no magnet is present, replace the flywheel or the entire base unit (if unable to replace flywheel).
Check RPM Sensor (requires shroud removal) RPM sensor should be aligned with magnet and connected to data cable. Realign sensor if necessary ( 1/8" clearance between sensor and flywheel) if still error 3 then check the sensor with a multi meter unplug sensor leads attach meter to sensor connectors. Have someone by hand rotate the pedal while you observe the multi meter opening and closing the internal sensor circuit if no change in meter readings then replace the sensor.
Posted on Jun 01, 2010
  • 297 Answers
SOURCE: my schwinn 240 recumbent bike shows E-3 on
Hello, do you have a manual or electric resistance control? The manual one has a return spring, the electric on has a resistance motor that could be bad.
Posted on Feb 06, 2011
  • 12223 Answers
SOURCE: schwinn 220P no resistance
see this steps and fix it. God bless you
  • 1
    Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
  • 2
    Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
  • 3
    Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine.
  • 4
    Check the hand bars. While not all people use them, as they can elevate your heart rate by up to 20 percent, they can become worn, too. While loose hand bars typically need a simple tightening of the bolt, be sure not to overtighten as the bolts can break.
  • 5
    Know that if the axis is bent, it's likely you need a new machine. The axis is the central alignment of the elliptical. If the machine was used by a person who is over the maximum weight limit, it can be bent or damaged. It's not an easy fix and a better idea is to upgrade to a sturdier machine.
  • Posted on Nov 23, 2012
    I've had a Schwinn 270 recumbent bike for 4 years. The resistance is completely gone. Suggestions?
    I suggest you check the troubleshooting guide in the manual, as there are several causes for the resistance not changing. I would suspect that no resistance at all might have to do with a failure of the servo motor, which appears to control resistance through interaction with magnets on the wheel.
    Secondly, you can try contacting Schwinn Fitness: Customer Service
    If you still can't figure out the problem you may need in-person help. Find a place that sells Schwinn exercise bikes or see if someone at a local gym that has recumbents can help you. The bike is apparently made by Nautilus.
    Dec 06, 2017 | Schwinn Cycling
    How to replace the left crank on a schwinn 250 recumbent bike
    Yes, special tools are required. Suggest you take to local bike shop for correct repairs.
    Jun 25, 2014 | Schwinn Meridian Adult 26-Inch 3-Wheel...
    Schwinn 250 Units setting
    replace the batteries by new ones. and clean the contacts batteries very well.
    2) adjust the Reed switch, see the diagram, test for open or fulty, clean it, and tight the conector v. well.
    However you must to back to the display are small orifice, Use the point o eraser pens, and click the small switch for to change. the Km or miles or vice. versa.
    Jan 20, 2013 | Schwinn 250 Recumbent Bike
    The tension does not increase on my schwinn 220
    adjust the magnet very well, tigh the bolts if there loose the tension will be not o.k
    Apr 24, 2012 | Schwinn 220 Recumbent Exercise Bike - 2012...
    I'm looking for a manual for a recumbent bike,
    Hi lcbir5319...
    Go to the following websites for your user manual and parts list for your Schwinn 203.
    Please take time to rate me thumbs up
    User Manual:
    Parts list:
    Schwinn website/customer support:
    Sep 12, 2011 | Cycling
    Schwinn 250 Recumbent Bike Logo
    88 people viewed this question
    Top Schwinn Exercise & Fitness Experts
    David Payne
    David Payne
    Matt Olenzek
    Matt Olenzek
    Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
