Question about Kenmore 52642 / 52644 / 52649 Side by Side Refrigerator
Schematic Need hard start relay or three in one. Want schematic for proper diagnosis. Can't find model number. Side by side unit with Ice maker/dispenser. Have compressor hard starting several times without running then eventual start and run. Cannot find schematic on unit to hook up relay or other.
    Problem Solver:
  • 6 Answers
Most 3 in 1s come with a diagram. as for the factory style you can order a new relay and capacitor from Sears or on the web.
Posted on Jan 22, 2013
duby1990
  • 367 Answers
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
  • 306 Answers
SOURCE: Compressor will not run
mostly the relay called a PTC relay. If you have a ohm meter you can ohm out the compressor just to make sure but pretty sure the relay. ken
Posted on Jan 11, 2009
SOURCE: Door Handle
Yep, if the engineer had worked for me, I would have fired him/her. I have gone through 3 of them of the past 3-1/2 years until I got tired of it.
That said, it likely brakes at the same corner/corner. You will likely find a cavity inside each broken half. Using superglue and a small flat piece of metal (cut from a metal washer) sized/formed to fit inside cavities when the broken half are pieced together. Trial piecing the pieces together first before glueing them together.
If there are no cavities (solid), try creating one (you may be able to drill/carve out) in each broken half then follow the steps above.
Guaranty better than new and last a whale of a lot longr.
Good luck.
Posted on Jul 04, 2009
SOURCE: Ice Dispenser clogged with frozen ice
I have the same problem. Found this posting:
http://www.applianceblog.com/mainforums/sears-kenmore/10491-kenmore-ice-maker-dispenser-door-shute-clogging-missing-heating-element.html
Maybe our heater is not working?
Posted on Oct 27, 2009
heatman101
  • 43501 Answers
SOURCE: refrigerator ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
mnnmbnm
Posted on Sep 30, 2010
Need to replace Ice & Water Dispenser for msd2354 side by side refriderator, how to get the unit?
use your model number to order it from marcone.com, they will give you a parts breakdown and you can get any part you want
Oct 12, 2012 | GE GSS22JF Side by Side Refrigerator
My GE refrigerator has a through the door water, crushed ice and cube ice dispensor. There is a selector button for each on the front panel and when you press the lever with your glass, one of the three...
there is a small switch that is attached to the lever on the door most likely the lever or the switch is sticking you would have to remove the front panel to assure which is sticking on you Im leaning more towards the switch sticking in my own personal opinion if you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks again I await your reply if you have any further questions Rick
also if you need a schematic message me back the model number of your unit and I will look for your schematic
Jun 01, 2011 | Refrigerators
Fan coil freezes
Hello, the coil can freeze due to a dirty air filter, dirty evap coil or a low refrigerant charge. First, check the filter make sure it is clean, if not wash the filter. Next check the evaporator coil and and clean if dirty, the coil can be cleaned with a can of coil cleaner which you can buy at a hvac supply store. If that checks out ok then the unit has a low refrigerant charge and must be recharged by a hvac technician.
Apr 25, 2011 | GE AJCQ12DCD Air Conditioner
I have an Intertherm split unit A/C and electric heat I need a ladder diagram for the indoor fan relay and I also need to know which part number it is my intertherm model number is e2ebo15hb any help would...
Hi, the schematic would be in the indoor unit, but I am assuming its gone since you are looking for the ladder schematic for the heat strips and fan control. You might try this number for a schematic, 1-888-441-6942, Route A/C and they may be able to help you on this diagram. The number you are showing does not look like any model number at all. For both the indoor and outdoor units on the Intertherm, would look something like this...., P3RA-024k for the model number, and the serial number would be right below it. Both should be very easy for you to locate. It is very hard to find schematics for units once they are gone, as some tech's like to take them off units to go home and try and study them!!, unreal! Makes it hard to troubleshoot when you need it. Try to find numbers like I have noted, and call this number as they will answer questions you may have concerning yours. I hope the best for you and would like for you to rate me, as I know you will be kind. Please keep me posted on this as maybe I can help you solve this fan relay problem you have?
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Sep 18, 2010 | Intertherm Heating & Cooling
There is no schematic or number on air handler .outside unit is Goodman # CPE48-1FB.How can i get a schematic for Air handler.
I need more info than just the outdoor unit number. The air handler will be a specific number. If you pull the access panel off the heater, there will be a faceplate inside with the unit name and model number as well as a schematic on the back side of the door.
May 12, 2010 | Goodman CKL60AR60 Air Conditioner
Diagram or proper schematic of fuel pump relay
The Owners Manual under Relays will tell you the location of it. If for some reason it doesnt emial me and I will find it for you. seans46@yahoo.com
May 24, 2009 | 1999 Ford Taurus
MY Maytag Wide by Side freezes in the produce drawers.
When a unit freezes in the lower drawers this is usually due to a thermistor which is not functioning properly. If you can provide your model number I can try to locate your schematic to your unit showing the thermistor that you would replace to alleviate this issue. I will await your reply as to the complete model number of your unit.
p.s if you had ice up the top of the unit as well then you would look at the damper door otherwise known as the diffuser door in some units or the control for the door as the problem area in your unit.
Thank you,
Rick
Jan 21, 2009 | Maytag 26 cu. ft. Wide-By-Side...
Fridge won't dispense ice through door.
First take the hopper out and let it de-ice completely making sure that it is dry before re-installing it. Make sure that the auger moves when re installed with no ice in it.
Dec 26, 2008 | Whirlpool GD5SHAX Side by Side...
Need schematic for refrig repair
i need to know how much pressure gauge on low and high for two side whirlpool refrige
Nov 26, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore 52642 / 52644 / 52649 Side by Side Refrigerator Logo
107 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
