Question about Tektronix TPS2024 200MHz 4 Channel Digital Oscilloscope
WHAT SHOULD THE VOLTAGE BE ON TPS ON 1996 CHEVY BLAZER
    Genius:
  • 1,669 Answers
Please read this:
http://www.automedia.com/Throttle_Position_Sensor_Adjustment/ccr20040701ts/1
Posted on Jan 21, 2013
On, this may sound crazy but my Chevy blazer doesn't want to engage the transmission sometimes unless you pump the gas pedal while in gear. Then works good
No that doesn't sound crazy at all . Given the electronics on vehicles today . What year is your blazer ? For the transmission to shift or engage gears the PCM/TCM which ever controls the trans in your blazer ,inputs from various sensors are needed. One being the TPS - throttle position sensor . Stepping on the gas pedal changes voltage signals to the PCM - engine computer . If you hooked up a volt meter on the signal wire to the PCM from the TPS at idle you would see around one volt an gas pedal on the floor around 4 1/2 - 5 volts . Check the connectors at the transmission an the PCM for being tight . Having a scan tool that reads sensor data hooked up to look at sensor parameters could be a big help .
Sep 20, 2016 | Chevrolet Blazer Cars & Trucks
Schematic for 1996 chevy blazer fuel tank
Get a Haynes or Chiltons Manual for diagrams and instructions for your vehicle.
Sep 13, 2014 | 1996 Chevrolet Blazer
I have a 93 s10 blazer it is saying high voltage to tps i put a new tps in still no change
you probably have a short in the wiring to the tps somewhere, trace the wiring
Jan 17, 2013 | 1993 Chevrolet S-10 Blazer
My 1996 Chevy Blazer blower isn't blowing air. Fuse is ok. What next?
Faulty blower motor resistor or blower motor resistor connector faulty.Wiggle blower motor resistor connector with the ignition and fan switches on.
Jun 17, 2012 | 1996 Chevrolet Blazer
1996 Blazer: How do install a 1996 chevy blazer serpentine belt...
It will have a diagram right above the fan blades to show you how it needs to be ran. Just need to release some pressure off the belt tensioner to make it all fit
May 16, 2010 | 1996 Chevrolet Blazer
1996 chevy blazer will turn over but not start no voltage to coil, tested pink wire it is not hot when key turned on
I would check the ignition fuses. Also, have the igniton control module tested. Could be the camshaft or crankshaft sensor too.
Apr 20, 2010 | 1996 Chevrolet Blazer
Tps Sensor low input p-0227
P0227 also indicates the throttle PEDAL position switch control Circuit.Not only the throttle position sensor at the engine.
Jan 13, 2009 | 1996 Chevrolet Blazer
Tektronix TPS2024 200MHz 4 Channel Digital Oscilloscope Logo
43 people viewed this question
Top Tektronix Home Security Experts
Lawrence Oravetz
Are you a Tektronix Home Security Expert? Answer questions, earn points and help others
