Question about Canon MP-11DX Calculator
I HAVE A CANON MP11DX CALCULATOR. IT WILL NOT ADVANCE PAPER TAPE AFTER IT JAMMED AND TORE TAPE. I HAVE REMOVED THE JAM BUT STILL WILL NOT FEED PROPERLY/ADVANCE TAPE AND NUMBERS ARE ILLEGIABLE
SOURCE: canon pixma mp460
hi, did you have a solution for the above problem as i have the same?
email is copipwllheli@aol.com
thanks
Posted on Dec 29, 2007
  • 24 Answers
SOURCE: canon ip90 printer
The printer should be on,remove the paper from the printer(if there is any),press and hold the down arrow/cancel button, release the button when the power light blinks 3 times ... The printer will rollers will automatically revolce and clear all the jams.. When the power light is green then repeat the same step 3-4 times.. To confirm the paper jam is cleared then feed 8 1/2 * 11 paper in the printer and again press the down arrow button and release the button once the power light bliks for 3 times and then release the button. If the printer feeds properly it confirms the hardware of the printer is fine.
Software issue: Go to printer and faxes in computer and check the icon. If it says.. 0 paper jam then, delete the icon and chcek in the device manager if there is an entry of usb printing support under Universal Serial Bus controller .. if the entry is there then delete it. Insert the printer cd in the computer and unplug and replug the usb cable from the printer. If the setup screen comes up then exit out of it and the printer drivers will get updated. After that tried to print another tets page from the computer. It will definately print. Thank you.
Posted on Jan 22, 2008
  • 168 Answers
SOURCE: Staples SPL-P100 calculator feed
There could be something stuck inside the unit. Try taking a business card and pushing it into the silver slot at the same time pushing the advance button.
Worst case senerio, bring it back to Staples and ask someone there, IM sure that someone there can get the paper to feed in seconds if there is nothing else wrong with it.
Sorry I couldnt be more help.
Good luck.
Mac
Posted on Feb 10, 2008
I tried that and it's works : ))))
THANK YOU
Posted on May 09, 2008
SOURCE: CANNOT SET TAX RATE ON MY CANON MP11DX
To change the tax rate on the Canon MP11DX (and most others):
Slide the "GT" button to "RATE", enter your tax rate and hit the "TAX+" button. Once changed, slide the "GT" button back to the "ON" position.
Posted on Feb 11, 2009
Clear paper jam
1. Turn ON calculator and set the slide switch P/NP/IP switch to P position.
2. Remove the paper roll from printer.
3. Use a business card and insert into the printer slot
4. press the feed key to feed the business card to clear the paper jam
Jan 19, 2015 | Victor 1260-3 Calculator
How can I prevent paper jam 0207 on canon 2230
Although paper jams occur because of dirty pickup rollers I have found that jams occur frequently because of solenoids in the paper feed mechanism (the assembly that the paper trays fit into). There are two of them and over time the damping foam on the levers get sticky causing the lever to operate late which causes the jam. As a fix I remove the damping foam and put insulation tape on the lever making sure the solenoid works by using a 12v bench psu before reassembling. You will need service manual because Paper Feed mechanism removal is a little complex.
Paper feed problems in Canon Laser Jet Printers are caused by these solenoids mainly in Duplex mode. P3005dn's etc.
Hope this helps solve yr problem.
Jul 29, 2014 | Canon Office Equipment & Supplies
How do I clear a paper jam in my Sharp EL-2630PIII adding machine?
My paper is stuck and jammed in the feeder. I cant add new paper because of the jam. The new paper crinkles up as it feeds. Is there a way to remove the jam of paper that's stuck inside ?
Jun 13, 2014 | Sharp EL-2630P Calculator
My printer says I have paper jam, please remove. but i have only been able to remove partial pieces. How do I get at the rest left in a spot I can not reach
Here's a link from which you should be able to download the online manual with a troubleshooting section that includes specific instructions on clearing a paper jam. See also this page, as I have no great confidence in the links I get from canon, their website is so backwards. If you choose the service and support option, then ask "how do I clear a paper jam" you'll see the instructions they offer.
Issue: Paper is jammed inside the printer
Solution: Remove foreign object from paper feed area (MP130)
Remove foreign object from paper feed path If error message
  • [PLEASE CLEAR PAPER JAM AND PRESS [OK]] or
  • [CHECK PRINTER]
is displayed, follow this procedure to remove paper or obstructions from the machine. Clearing Jams In The Paper Output Tray:
  1. Gently pull any jammed paper out of the Paper Output Tray.
  2. Press .
  3. If you cannot see any jammed paper in the Paper Output Tray, remove it from the machine's interior.
    1. Press to power off the machine.
    2. Lift up the Scan Unit until it locks into place.
    3. Open the Paper Output Tray.
    4. Look in the print area for an obstruction (such as a paper clip, staple, tape, etc.) and then remove it.
  4. If you are printing from an application software, follow the instructions displayed on your computer.
Clearing Jams From The Auto Sheet Feeder:
  1. Gently pull out any jammed paper from the Auto Sheet Feeder.
  2. Press .
  3. If you are printing from an application software, follow the instructions displayed on your computer.
Sorry I can't offer you much more, but just try to get all the bits out. Sometimes a pointy tool on a vacuum will help. Otherwise, maybe you can wrap and tape a post-it note around a popsicle stick or something to reach the paper and try to coax it out, or maybe a bit of folded tape on the end of a ruler or something like that. Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 02, 2011 | Canon PIXMA MP130 All-In-One InkJet...
I do not know how to put the tape into the calculator. There is a place in the back that it looks like it should go - I put it in there, press the advance paper key and nothing happens.
Push the roll of paper in until it will go in no further. On mine, it goes a bit more than a quarter of an inch. Once the paper is in all the way, press the Feed button until it shows at the top.
If it is still not feeding through, you may have a jam somewhere. Take the top of the paper area off and manually inspect the area to make sure nothing is out of place.
If you are still having problems, try feeding the paper in without the cover on. You can watch to see what is stopping it.
May 21, 2010 | Canon P170-DH Calculator
Paper jam. paper tore at the exit roller. I
FUSER ASSEMBLY NEEDS TO BE REMOVER/REPLACED, THE COST AND LABOR MAY NOT BE WORTH THE REPAIR
Jan 22, 2010 | Canon ImageClass D660 Copier
How to remove the scanner unit on Canon PC1060
you sould not have to remove the scanner unit to clear a jam in the fuser
open all doors and remove anything marked green
remove the the cartridge assembly if it will come out
open the fuser section (usually a release that takes pressure off of the fuser rollers
remove the paper feed cartridge
you now should be able to follow the paper feed path from the time paper goes i until it comes out
if you are not sure of path take a piece of card stock and simulate it goig through feed ara
there are small microswitches/ poto eyes that sense paper lok for an small pieces also clean thes poto eyes with q tip and rubbign alcohol
reassemble
unlug from the wall then plug back in and turn on p roblem sould be solved
Jan 05, 2009 | Canon PC1061 Copier
Canon PC 1060 has a paper jam that we can't get to
It sounds like the paper jam is in the fixing assembly, and you can not access it unless you take it to a service center for canon products.
Nov 10, 2008 | Canon imageRUNNER 5570 Copier
MP390 paper Jam
check the bottom part see if you can open.
Jul 08, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Canon MP-11DX Calculator Logo
542 people viewed this question
old marine
old marine
