Question about Proform XP 580 Trainer Treadmill
Proform xp 580 trips the breaker as soon as you turn it on
    Problem Solver:
  • 9 Answers
Treadmills have up to a 15 amp power draw. They are like space heaters, Proform often recommends having a dedicated 15-20 amp circuit for a treadmill. Ellipticals have less power draw.
I repair most Icon products, is this a new problem with an old treadmill? If it is a new treadmill, call the number in the front of the manual, if they can't fix it over the phone, there is a good warranty on it. At least for a little while. ;-)
Posted on Feb 06, 2013
  • 64 Answers
SOURCE: Proform 450 X treadmill powers on, but trips current when started
There could be a combination of problems. I would first start with disconecting the motor leads and see if it trips the breaker. Then elevation motor would be next if no change from disconecting motor. More than likely it's a motor issue.
Posted on Jun 08, 2009
maxtreadmill
  • 832 Answers
SOURCE: I have a proform xp 580. when I turn it on,
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
After completing calibration of incline, press the Stop key and then remove the safety key.
Posted on Jun 14, 2010
  • 1751 Answers
SOURCE: I have the proform 785 ss treadmill and it shus
Unlpug it for 30 minutes to reset it
Posted on Nov 26, 2010
ercupa190
  • 12223 Answers
SOURCE: my proform xp 580 powers
Watch this videos tips:
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
http://www.youtube.com/watch?v=23ZgWaVEQjA
Of course check every connections loose, corroded, bad contact, tight, and clean every contact with special spray ( cleaner contact)
Posted on Nov 15, 2011
sureshreddy8
SOURCE: can't get my proform xp 580 trainer treadmill out the door
sony ericession text pro ck 15i i want incoming sound incrise (or)...how to sending blooth with video
Posted on Nov 20, 2012
Proform crosswalk 395 keeps tripping circuit breakers
If it's happening as soon as you press start then you need a controller and a walking belt. If it's doing it after a few minutes of use then you need to replace your walking belt.
Jun 27, 2017 | Proform Exercise & Fitness
I have a proform xp 580. When you plug it in and hit the reset key at the bottom by the cord it starts and then blows the breaker in the switch. It does it with or without the safety key in place.
The Motor control board or the motor is faulty this why the because of overload the circuit breaker goes off. Normally it would be the motor control board. On rear cases motor an be short.
If you wish to get some more details then check the following link
http://electro-medical.blogspot.com/
Aug 12, 2016 | Proform Exercise & Fitness
I have a proform xp trainer 580 . The display works but the actual walking belt doesnt move.
please see the video and fix it according.God bless youThis happen because the lack of maintenance schedule .
Apr 04, 2013 | Proform XP 580 Trainer Treadmill
Proform xp 580 - Occassionally, any button i push simply beeps, and nothing else happens, no response from the panel.
Step 1:
please replace the old batteries with a new ones, with the same mark+same polarity+full charge.
Step 2:
adjust the REED switch, see the diagram attached, test for open or faulty, clean it, and tight the connector very well .
Step 3:
tight all connector a) ribbon cable inside for keypads b) upper connectors board display vs lower connector main board.
God bless you
Jan 04, 2013 | Proform XP 580 Trainer Treadmill
Can't get my proform xp 580 trainer treadmill out the door
Nov 20, 2012 | Proform XP 580 Trainer Treadmill
I have a proform xp 580 and my treadmill makes a clicking noise as if it is trying to incline what should i do?
1)Please lube the gear and shaft, very well from elevation motor
2) Test the motor, and replace if necessary.,see for ball bearing and lube
3) Lube the deck belt, and guide for instruction manuals.
4) Test the main switch, and reset button with VOM, for open, test and replace see the diagram how to do it.
God bless you
Jun 08, 2012 | Proform XP 580 Trainer Treadmill
New console on proform 580 doesn't work right
Dear Sir:
Please 1)adjust the reed switch see the diagram below 2) Change the baterries by new ones 3) Tigh the flexible cable from keypad 4) Tigh the connector from display board vs lower board.
Run inmediately after you did the step before software calibration for easy diagnose and troubleshooting.
If you can nor RUN your software calibration please see my personal TIPS, for easy diagnose and Trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 29, 2012 | Proform XP 580 Trainer Treadmill
My treadmill kick our breaker when i hit the go button
Check and make sure that the voltage for the treadmill are the same being put out from the wall socket. Or try using the treadmill on a single circuit with a larger breaker. Your owners Manuel should have that information in it.
Feb 19, 2012 | Proform XP 580 Trainer Treadmill
Jun 12, 2010 | Proform XP 580 Trainer Treadmill
Jun 06, 2009 | Proform CrossTrainer Treadmill
Proform XP 580 Trainer Treadmill Logo
162 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
