Question about Sony PS3 PlayStation 3 80GB Blu-Ray Game Console
My PS3 only has a green light when it is powered on
It started overheating some months ago so when I opened in and cleaned some dust out of it, it stopped working. When it is powered on now, there is only a green light,there is no connection of the controllers, the blue ray light doesn't start even if there is a disk inserted into it and the HDD access light and Wi-Fi lights don't come on or even blink.
    Prodigy:
    An expert who has answered 500 questions.
  • Sony Expert
  • 537 Answers
Your system needs to be serviced.
Posted on Nov 06, 2013
  • 105 Answers
SOURCE: having problem with my ps3
Sounds like the PS3 is bricked. Try using the recovery menu, Directions here: http://www.xtremeps3.com/2009/01/28/how-do-i-access-the-playstation-3-recovery-menu/
Posted on Aug 03, 2009
  • 105 Answers
SOURCE: ps3 won't hook up to fair field suites wi fi
The ports for connecting the PS3 onto the internet might be blocked. Double check with the staff and see if they can help.
Posted on Aug 17, 2009
  • 3 Answers
SOURCE: My PS3 won't turn on to the menu.
right if its the same thing as ive had it basically your LED light has gone bust and you'll need to repair that, if thats wat it is...
Posted on Feb 18, 2010
upbeatjunk
  • 231 Answers
SOURCE: What's wrong with the ps3 when you turn it on it
Sounds like an overheating issue to me. Make sure to keep it in a well ventilated area. Also, the next time you turn it on, put your hand near the vents to see if any hot air is being expelled through them. If there is NO air being expelled, you have a bad fan. It may also be that the heatsinks aren't conducting enough heat from the processors...this could be due to bad thermal paste. You may need to send it in for repair for this you can call 1800mysony.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Posted on Jul 03, 2011
franza1
SOURCE: My ps3 turned off during game play and the light
I'm afraid you have gotten the Yellow Light of Death ( YLOD ) you will need to have your PS3 repaired by a technician or you can Google YLOD and you will find a repair guide.
Posted on May 03, 2012
My ps3 keeps freezing but I ha ent played with it
Freezing is a sign of overheating. Try cleaning your PS3 with your vacuum. If it keeps freezing you might need to open it and replace your thermal paste.
Cheers,
Tom
Aug 29, 2014 | Video Game Consoles & Games
Toshiba 62hm84 dlp
Sounds as though the system may have overheated. Do you regularly check the filters and clean them? An airduster can also help to blow dust out of hard to reach places.
Apr 14, 2014 | Office Equipment & Supplies
A few days ago my Playstation began freezing midgame while playing NBA 2k11. Now when I turn it on, all of the icons such as game, network, playstation network, friends, music, etc are on the home screen...
Hi mttwlsn16,
If you noticed that system recently freezes up, it migth be overheating or full of dust. There are several ways on how to check the issue, either you clean the system or place it in a cool area. Here are some ways to troubleshoot the problem.
1. Turn off the system completely then disconnect it from the power outlet. Press and hold down the power button for 15-20 seconds. Try to restart the system now. If still has the same problem proceed to step 2.
2 .Try to Unplug and replug all the cables.
3 .Take out the hard-drive, and put it back in after your console has been started up.
4. Make sure that you have at least 60% of the hard drive space free.
5. Clean your game discs with a micro-fiber cloth.
6. Clean the ps3 from dust. You can Use a micro-fiber cloth and use vacuum accessories to clean the dust from the grills and fans.
Alternative solution to remove the dust:
--> turn off the system by switching it off from the back. Please make sure that there's no inserted disc on the system.
--> Now hold the eject button and while holding it try to switch it back on. Fan will run for about 20-30 seconds and it will clean up the dust.
Hope it helps.
Thank you for using FixYa.
Feb 22, 2011 | Sony Playstation 3 (PS3) Console
Cut off and light is red; quickly you see green;yellow then flashing red.
The PS3 YLoD can be caused by a number of things. Most commonly, it's a result of a hardware failure, overheating, dust build-up inside the system, and occasionally just due to loose cables.
Let's start with the easy stuff first to narrow down the cause. Follow the steps below:
1. Assuming you were playing your PS3 when the YLoD happened, move your PS3 into an open area with a lot of ventilation and let it cool down for 20-30 minutes. Once it's cool, try to turn it back on and see if that helped. If not, go to Step 2.
2. Unplug all of your cables from the PS3 including the A/V and the power cord. Also unplug the power cable from the wall. Now try to plug them all back in and make sure they are all secure. Turn the PS3 back on and check if it's working. If not, go to step 3.
How to Fix PS3 Yellow Light on Your Own
3. Get a vacuum with a hose attachment and vacuum out the vents on the system. Sometimes dust build-up alone can cause your PS3 to stop working properly. You might also want to take one of those cans of air and blow it in there to get some of the stubborn pieces of dust out.
If none of those solutions worked, the problem lies within the PS3 and you will probably need to take it apart to fix it. The most likely scenario is that your heat-shield overheated, the chipsets got shifted due to heat, and your solder could be cracked.
the causes of the yellow light of death
Sep 22, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on. when the power button is pressed ,it turns green for 2 seconds then yellow followed by a rapid beeping with a blinking red light occurs
Here are some of the top causes of the PS3 Yellow Light of Death:
* Overheating - The unit gets too hot. Sometimes caused by too much dust buildup in the vents.
* Blu-Ray drive failure.
* Bad power supply.
* Hard-drive critical errors.
* Hardware malfunction on the motherboard - The solder starts to crack due to excessive heating and cooling.
if you have warranty then take it back if you dont then you can either try the repair yourself how ever this is not very easy to do and can cause more harm than good you will need special tools to take it apart and its not easy you also need an understanding of heat seal paste and heat sinks due to this being the part you need to remove and put back
i do the repair for about 25pound plus parts so if you are paying someone to do it then your looking at least that price, i only charge if the problem is fixed so try and get the best price you can.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 18, 2010 | Sony Playstation 3 (PS3) Console
My system and games are running really choppy. Overheating was an issue, but i bought a cooling fan about 2 months ago. Recently the fan has started to sound really bad and loud, and the whole running...
Time for a new fan, also you should try and get as much air flow underneath as possible.. have you tried those laptop coolers that the laptop sits into.. Clean any opening out of dust too.
Feb 16, 2010 | Sony Playstation 3 (PS3) Console
Red lights flash when i power it on and wont let the disc enter
im sorry to tell you but it has probalbly died, it happened to me 3 months ago while playing cod5. sony still havent gave it back. i suggest to leave it and if it does boot up, clean away any dust and it should stay well, but if it doesent, you are going to have to ring up sony and tell them EXCACTLY what has happened and will get a new one within 2 eeeks or longer, and the game, it depends as i havent got it back for 2 months. So if you get a new PS3 , clean it regurley or get a engine cooler so it doesent overheat.
Mar 28, 2009 | Sony Playstation 3 (PS3) Console
How to fix blinking red light on my ps3?
You should open up the PS3 and use compressed air to dust it off. Take a look at the thermal paste to make sure it isn't dried up! PS3 Flashing Red Light The Ultimate Solution
Jan 20, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony PS3 PlayStation 3 80GB Blu-Ray Game Console Logo
66 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
