Question about Kenmore 98702 Stacked Washer/Dryer
Heating but doesn't dry clothes
I just moved into an apartment and have found that my clothes do not get dry. There was no problem while we live in a house so , can think of what may be the problem. The dryer heat and the clothes are warm just not dry. should I have the complex check the dryer vent? Coulds it be the thermostat? I just know I use alot of $$ on electric bill and still don't have dry clothes.
Thank you for any help you can provide.
Becky
  • 334 Answers
Yes, that would be a venting issue.
Make sure that the filter and filter compartment are clear/clean, and then locate where the pipe exits the wall. They usually clog right at the vent exit, especially when they have the mesh covering and not a louver.
It is possible that the pipe itself is clogged as well.
This not only prevents proper drying, but is a fire hazzard and can cause problems with the dryer.
It "should" be a problem that the apartment maintenance crew will take care of free of charge.
Posted on Jan 27, 2009
Frigidaire gleq442ces0
I had this same problem 3 weeks ago, and here is what I found.
The dryer was so clogged with lint it could not dry the clothes. I had to take the whole machine apart and clean all the lint out. I found the felt around the drum was worn out, and that was allowing the lint to go everywhere it shouldn't. With the felt replaced and the lint gone, it worked well.
Be blessed.
Jun 23, 2013 | Dryers
Dryer was running longer than we thought it should. Now timer will not move and it does not dry the clothes. Could this be a switch problem or a heating element problem
Check your vent outside of your home or apartment. If you are not feeling anything heat or air, then it is clogged. Clean the vent and it should be alright. If you had on the sensor dry that could be the reason why your timer wasn't moving.
Apr 30, 2011 | Roper Dryers
Not drying properly, no heat
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 06, 2009 | Dryers
My dryer takes 2 to 3 cycles to dry my clothes.
Check the following areas to combat this issue. in most cases, this will be a Venting issue.
1. Venting
2. Thermostat
3. Heating element
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Dryer won't heat up to dry the clothes the heating element works
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
3. Heating element
Jun 03, 2009 | Kenmore Dryers
Not heating properly, many cycles to dry loads
1. Venting
2. Thermostat
3. Heating element
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Clothes won't dry
Check the following to address this issue.
1. Venting
2. Thermostat
3. Heating element
Jun 01, 2009 | Whirlpool ET8CHEXSQ Dryer
FRIDGIDAIRE GAS DRYER MODEL # GLGR642AS2 IS NOT DRYING CLOTHES BUT GAS IS IGNITING. THANK YOU. DON
Hi Don,
So let me get this straight, you are getting heat from the gas burner and the drum rotates but your clothes remain wet? You can check a few basic things to identify where the problem lies.. First off, have you checked the lint trap and cleaned it? Secondly, have you checked your vent system ( meaning : are you sure it is not clogged anywhere in the duct or at the end where it exits outside? If that's OK.. when your system is drying clothes.. do you get hot air flow at the end of that duct? If not, your blower may not be working ..You need to move that hot air out of the tub for the system to dry. Heat, Motion to move clothes, air flow from the blower and an unimpeded path via the vent duct to outside.. Hope one of these things to check gets you going. Regards...
Sep 03, 2008 | Dryers
Kenmore 98702 Stacked Washer/Dryer Logo
Sal De
fordexpert
 Brian Main
Brian Main
