Question about Canon iR 2016i Black and White Copier
My photo comp magnetic part did not functional and it prints with out any image on the paper
I change my fuser film and when i made a copy of my document my copy did not fuctional when i see the magnetic part which is on the drum unit it have not any ink and i change new drum but there is no change still now
    New Friend:
  • 18 Answers
Check is dp rod move
Posted on Mar 14, 2013
Nitrotrike
  • 589 Answers
SOURCE: canon clc-700 stops copying when paper sticks to drum
Could be one of two things.
Either the transfer / separation corona wire is dirty / broken, or the separation current is set wrong.
or
The drum separation claws aren't moving. Possibly a stuck solenoid.
Posted on Jan 15, 2008
  • 990 Answers
SOURCE: remove a paper jam under the fuser unit on a canon
Hello sir; I believe You have to detacth finisher unit then open the side door to reach the fusing unit see is there have jamming paper over there ,the paper under the fusing unit just open front door turn the knob clockwise on the fusing unit paper will coming out.
Posted on Aug 18, 2009
canontech
  • 1219 Answers
SOURCE: printing colour quality problem on canon irc2620n laser printer
Are you service technician?
You can try to clean the laser unit, try to clear dc-con like on clc3200, but first try gradation adjustment.
If you not an technician do not try to clean laser by your self
Posted on Feb 15, 2010
SOURCE: My old Canon NP1215 Copier: -First copy is
change drum unit still making lines
Posted on Mar 03, 2010
  • 61 Answers
SOURCE: image runner C51851 is printing color copies with
It could be a couple of things , from transfer belt slipping to bad fuser assy. How many copies on the machine?
Posted on Mar 26, 2010
Hp laser jet 3015, 7 horizontal lines, with ghost images printing/copying.
Hi:
Ghost images or repetitive image defects can be caused by one of two things. Either your toner cartridge is defective or your fuser is bad. The fuser is the component that heats up and fuses the toner to the paper. To determine which one it is do this. Start to print or copy something and shut off the printer just as the paper is going under the image drum but before it enters the fuser. If the problem you described is evident on the paper at this point then the problem is related to the drum. If the problem is not showing up on the paper at this point then the fuser is the culprit and it most likely would cost more then the unit is worth to repair.
Andrew
Nov 12, 2013 | HP LaserJet 3015 All-In-One Printer
Error code e000007 canon 2420
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
Dec 06, 2012 | Canon Office Equipment & Supplies
Fuser problems
Fuser not cause light copy.If fuser problem the fuser unit not fixing the toner to paper (not fixing image).Light copies :dirty optical parts,Organic Photo Conductor drum,charge roller or charge corona wires or charge corona grid dirty,transfer/separator corona wires dirty.
Aug 13, 2012 | Office Equipment & Supplies
Double images and dirty copies on left side of paper
This is caused by one of 2 things. It is either the toner cartridge or the fuser film is going bad. If you have a spare toner, even an empty one you can shake a little and try it to see if the double image goes away. If a different toner does the same thing then it is the fuser film. Now you can change you own fuser if you wish. Just don't let a service guy come out and tell you that you have to replace the whole fuser. You can have them replace just the fuser film because the rest of the fusing unit is usually just fine. I do fuser films all the time. $50 to $80 for a film vs. $200 and up for a fuser.
Good Luck and Thank You for using Fixya.
Apr 20, 2010 | HP LaserJet 2420 Printer
I'm getting ghost images on multi prints to the point it is unreadable, is this the drum or fuser?
The only way to tell is to start a print and power off when print is still inside. If you see the ghost before the fuser it's the drum, if clean before the fuser, it's the fuser. You can also open the back door and look at the fuser roller with a light, the fuser roller should be clean but if the roller has images it's time for a fuser.
Feb 19, 2010 | Brother DCP-7020 All-In-One Laser Printer
Copy prints with image from previous page (lighter) as well. This is an older copier (Gestetner 2302Z)--is the fuser roller the issue/ Can I repair/replace myself?
To check if it is the fuser rollers turn off the copier before the paper reaches the fuser.Remove the 'jammed paper' carefully as the image will rub off and see if the double image is present.If it not then it sounds like the fuser.If it is there then will more than likely be the drum that is not cleaning.I do not suggest that you change this yourself.
Nov 01, 2009 | Office Equipment & Supplies
Double printing
HP do not use fuser oil. The upper roller is made of a non stick coating. When this begins to waer the toner sticks to the roller along with excess paper dust off the paper.This is what will cause a repeat image on a page. You need to swop the fuser unit to cure this fault
Oct 01, 2009 | HP LaserJet 4250n Printer
4250tn print black spot
You either have a bad spot on the drum or a bad spot on the fuser rollers. Replace the cartridge first. If spot continues, take cartridge out and get inside with a flashlight. You'll probably find a piece of paper stuck to a roller.
Apr 04, 2009 | HP LaserJet 4250n Printer
Canon iR 2016i Black and White Copier Logo
21 people viewed this question
old marine
old marine
