Question about HP Pavilion TX2000Z Notebook
I check bios battery work correct. memory sticks cleaning not help.
Its doesn't look like a software problem. Its a hardware problem maybe with a MAIN LOGIC BOARD. Try to get it repaired.
Posted on Jan 21, 2013
SOURCE: Laptop fails to boot up. Caps lock & Num lock
The problem may be your display LCD is not working - check that hard disk is running - when you touch you may feel a running sensation -
There are many problems It can be motherboard problem or any of the devices is not working ie.. hard disk PCMCIA Cards i suggest you should an expertize check.................
Posted on Jan 20, 2010
SOURCE: My laptop does no more boot up. As soon as i start
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue.
LED
Component
Error Condition
Blinking battery power LED
Battery
Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock
CPU
CPU not functional
Blink: 2 - Caps Lock/Num Lock
BIOS
BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock
Memory
Module error not functional
Blink: 4 - Caps Lock/Num Lock
Graphics
Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock
System board
General system board failure
Blink: 6 - Caps Lock/Num Lock
BIOS
BIOS authentication failure
Posted on May 02, 2010
SOURCE: have a hp dv7-1240us laptop. the screen will not
this sounds like the inverter in the screen. I would start by subbing the lcd screen. Then try and external monitor. video problems are difficult. don't get frustrated
Posted on Jun 18, 2010
SOURCE: I have a HP Pavilion dv7-1232nr Laptop. As soon as
bad hard drive or memory card is loose more likely bad hard drive...have it tested...
Posted on Apr 15, 2011
SOURCE: On My Dv5-1125nr both the caps lock and num lock
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
LEDs near Caps Lock and Number Lock keys blink when starting notebook
The
LED lights near the Caps Lock and Num Lock keys will blink if an error
is detected during the start up process. The LEDs will blink a number of
times in a sequence and then stop. The number of blinks in the
sequence indicates what component caused an error when it was being
tested during start up.
If the LEDs stop blinking and the
computer does not start, you can press the power button again to repeat
the tests. Count the number of blinks, and use the chart to identify the
error condition.
Knowing the number of blinks is helpful when you contact an HP support agent for technical help.
Caps Lock/Num Lock LED
Component Tested
Error Condition
LEDs blink 1 time
CPU
CPU not functional
LEDs blink 2 times
BIOS
LEDs blink 3 times
Memory
LEDs blink 4 times
Graphics
LEDs blink 5 times
System board
LEDs blink 6 times
BIOS
Posted on Aug 03, 2011
Nov 01, 2012 | Compaq Computers & Internet
on Mar 21, 2011 | Computers & Internet
Jun 30, 2011 | Compaq Presario Notebook
May 27, 2010 | Computers & Internet
May 24, 2010 | HP Compaq 6735s Notebook
May 24, 2010 | Compaq Presario Notebook
May 21, 2010 | HP Pavilion dv6000z Notebook
May 12, 2010 | HP Pavilion dv9000z Notebook
Apr 19, 2010 | HP Pavilion dv5-1000us Notebook PC
Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
Feb 05, 2009 | HP Pavilion TX2000Z Notebook
51 people viewed this question
