Question about Locks & Locksmithing
Weiser front door lock GA9771A wont open from outside
The thumb pad on the outside of the door is hard to depress and will not open the door. If I jiggle the inside handle then is will work. But once I have used the inside handle the outside thumb pad will not work.
  • 123 Answers
SOURCE: i have deadbolt segal lock that was working for 2
Sounds like the tumbling mechanism for the handle may be off......check to make sure that the screws are tight that lock the front and back of the deadbolt together. Make sure that the door is fully closed and check to see where the deadbolt is hitting the striker. It mat be as simple as the door and frame have expanded a bit and the door is not fully seated when you close the door from the inside. See if these help if not please contact me as I wish to find a solution to your problem.
Thx
Deathstalker
Posted on Aug 21, 2009
  • 12104 Answers
SOURCE: the kids locked the bathroom door and closed it... my
if not a key hole stick small screwdriver or any small flat devise into handle and turn will unlock passive door handle
Posted on Oct 19, 2009
  • 15 Answers
SOURCE: how do i change my code on my weiser front door
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
page 6ish
Posted on Nov 06, 2009
  • 5 Answers
SOURCE: I just installed a new
it will not work without the original key.
Posted on Oct 15, 2010
  • 17 Answers
SOURCE: I have a keyless weiser deadbolt. Can't find any
Very common for the keypad to stop working.
check that the keypad is not defective. You can disconnect the batteries and then unplug the keypad. Now put the batteries in without the keypad connected. If the beeping stopped, your keypad may need replacing.
You can get a replacement at the store where you bought it for free or call the Weiser support line and they will mail you one for free.
Posted on Dec 26, 2010
Why wont my lock move/? I can hear the motor moving but lock doesn't move
Try with your door open. Also be sure that you can operate it by hand. If not, the motor can't move it either.
Facing the outside of the door, if the hinges are on the right, it's a right-hand door.
Sep 03, 2014 | Weiser Lock Powerbolt 1000 Lock
Doors in the back wont open from the outside?and the front passenger door wont open from the inside?
It appears you have a situation with electric door locks.When the locks are open,so will the doors.I'd check fuses first,if good,then the electric door locls need repositioned or replaced.
Apr 20, 2014 | 2009 Pontiac Torrent
Left front door wont open from the inside
the spring in latch has broken and it wont open door try put key in lock outside and lock unlock while opening the door sometimes unjams to be able to open door without taking panel off inside with door closed if dosnt work you have to remove the panel inside replace door latch assembly
Apr 04, 2014 | 2007 Kia Sportage 4x4 V6
Weiser door knob GA9771A-S. Loose interior door knob. How do I tighten?
Remove the knob by pushing in the small pin on the edge of the knob shaft. Then use a screwdriver in the small inset on the edge of the handle cover to pop the cover off. Tighten the 2 screws under the cover, replace parts.
Mar 25, 2014 | Hardware & Accessories
Why wont the rear door open on my 2009 gmc acadia
from inside or outside ? if won't open from inside your child safety lock is probably tripped. if won't open from outside you probably have a lock rod that popped off inside the door, in which I would have the dealer fix it, it involves taking door pad off and when you can't open door to take pad off ,most of the time it damages it.
Mar 19, 2012 | 2009 GMC Acadia
My Weiser Lock unlock fine using the touch pad but will not lock using the touch pad lock button
For your unusual problem I suggest that you call Weiser Lock during business hours at one of these numbers:
For assistance call
1-800-343-9652 USA
1-800-501-9471 CANADA
or visit www.powerbolt.com
Sep 12, 2011 | Weiser Lock GED1460X GED1460X11P Venetian...
I have a weiser lock powerbolt 1000 and i just installed it and progammed it except the bolt wont lock unless the keys are in the door, if i type in the code with the keys in it works fine but when i...
The deadbolt may very free inside the deadbolt hole... This system is low torque and a over torque clutch may slip if the dead bolt it's not completely free inside the deadbolt hole... Also, if you try to open the door before to unlock it, you may block the deadbolt... take care to unlock the door before open it. to be sure that the dead lock is ok, you can turn the manual knob and be sure is turning very very easily.
Also are you no that POWERBOLT is a 3 codes memory? go to that link to see more info about that : http://www.fixya.com/support/t8006865-not_overwrite_old_codes_just_keeps
Have a good lock
Have a good unlock
Sep 11, 2010 | Weiser Lock Powerbolt 1000 Lock
The kids locked the bathroom door and closed it... my
Oct 19, 2009 | Weiser Lock Locks & Locksmithing
1992 chevy lumina door wont open at all
will it open from inside? If it will then you didn't hook up the linkage right on the outside handle
Apr 27, 2009 | Chevrolet Lumina Cars & Trucks
Locks & Locksmithing Logo
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
