Magellan Excursion 6 Swiftrise Family Tent Logo
Posted on Jan 21, 2013
Correct take down and storage of the Magellan Excursion 6 Swiftrise tent.
I know that the extension poles must be lowered but then what? The poles stay attached to the tent but how do you put them together and fold it up?
How do I set up the Alpine hicker biker tent 925-204 SKU
I do not have access to specific instructions for setting up the Alpine Hicker Biker Tent 925-204 SKU. However, I can provide some general tips for setting up a typical backpacking tent:
  1. Find a level and flat spot to pitch your tent. Avoid areas with sharp rocks or roots that could damage your tent.
  2. Lay out the tent body on the ground and attach the poles according to the manufacturer's instructions. Most tents come with color-coded poles and sleeves to make setup easier.
  3. Assemble the poles and insert them into the pole sleeves. Make sure the poles are properly aligned and the tent is taut.
  4. Stake down the tent at each corner using the included stakes. This will help secure the tent to the ground and prevent it from moving or tipping over in windy conditions.
  5. Attach the rainfly to the tent body, making sure that it covers the entire tent and is properly tensioned.
  6. If your tent has a vestibule or gear storage area, set it up according to the manufacturer's instructions.
  7. Once the tent is set up, test it for stability and make any necessary adjustments.
It's important to read the specific instructions that came with your Alpine Hicker Biker Tent 925-204 SKU before attempting to set it up. Different tents may have unique setup procedures or additional features that require specific instructions. If you have any questions or concerns about setting up your tent, it's best to contact the manufacturer for assistance or consult with a professional camping equipment retailer.
1helpful
Needing to know how to set tent up it has metal poles I think it's a 6 or 10 man tent could be a 8 man not sure
They seem to make a few models. There are videos and text articles, but the best thing is to lay out the tent base, make up the poles and work it out. Peg the 4 corners of the tent, then it depends on the type of tent, but ridge pole in next, then the apex poles at the end, and then lift up on the legs. The peg in all the guy ropes and tighten.
https://www.google.com/search?q=academy+broadway+tent+instructions
Instuctions for 13×9 cabin tent sleeps 6 wmt-1390 (not instant)
OWNER'S MANUAL WARNING: KEEP ALL FLAME AND HEAT
SOURCES AWAY FROM THIS TENT FABRIC.
This tent meets the flammability require-
ments of CPAI-84. The fabric may burn if left
in continuous contact with any flame source.
The application of any foreign substance to
the tent fabric may render the flame-resis-
tant properties ineffective.
DO NOT...
1. Do not pitch tent near an open flame.
2. Do not leave campfires unattended.
3. Do not allow CHILDREN or ADULTS
to use lighted candles, matches or
other flame sources in or near tents.
4. Do not use heating, lighting or
cooking equipment with open
flames in or near tents.
5. Do not use fuel burning/oxygen
consuming devices (i.e. heaters,
lanterns, or other flame sources)
inside your tent at any time.
6. Do not use other than recommended
water repellent compounds on your
tent.(See:"Seal the Seams")
7. Do not spray the tent with insecticide.
8. EXTREME CAUTION: Never use any
fuel burning/oxygen consuming
device, or any device that produces
fumes (including stoves, lanterns,
candles, hibachis, or heaters) in or
around your tent. Inhalation of fumes
may result in carbon monoxide
poisoning, injury and/or *****.
DO...
1. Always extinguish campfire before
leaving area.
2. Exercise care when using electricity
and lighting in and near tents.
3. Disassemble and store tent properly
after camping to ensure the tent's
longevity.
4. Always use a hammer/mallet when
driving stakes into the ground. CARE This recreational item is not intended for
use as a permanent structure, as fabric
will quickly degrade if exposed to UV
light. No (sun shelter, screenhouse, tent)
can withstand prolonged exposure to
sunlight. UV damage is not covered under
the limited 90 day warranty.
Structural Integrity
Although our tents and screenhouses are
constructed to rigid specifications, periods
of wind or rain soaking the ground may
loosen the stakes and cause the uprights to
sink into the ground. This will weaken the
rigidity of the overall structure. Water pock-
ets may also form in the roof if the unit is
not assembled taut, the weight of which
may cause broken frames and torn fabric
Storage
Tents/screenhouses must never be rolled
up or packed while damp, as mildew will
form within a few days. Allow tent to dry
completely before rolling and storing.
REPLACEMENT PARTS Always mention the Model number in all correspondence regarding your tent and when ordering
replacement parts. ASSEMBLY INSTRUCTIONS Lay Out the Screenhouse and Poles
Select a smooth, level site and spread out your
screenhouse.
Sort the poles by number and connect the
sections together. See diagrams below for
numbering
tep 2 - Install the Poles
Insert the ends of each of the three roof poles
into the 3-way hubs
Insert the four side roof poles into the 3-way
hubs. See Diagram 2 Insert the leg poles into the hubs to raise the
screenhouse frame. Make sure that the pole
end with the holes in the sides (
down. See Diagram 3
Secure the Screenhouse
Drape the screenhouse body over the frames.
Hook the S-Hooks
located at the bottom of the leg poles.
L
Wrap the velcro tape
screenhouse, around the poles to secure them.
When the screenhouse is in its proper location,
stake it down by driving stakes through the
four D-rings
Step 4 - Install the Guy Lines
Tie the loose end of a guy line through D-ring
Repeat for the other three guy lines.
1B
Make a loop at the end of the guy line with the
L
slider. Stake the looped end of the line out
about 3' from the base of the pole. Adjust the
slider until the line is taut
C
How do I assembly the tent
Step 1 Remove the tent, poles, stakes and tent rope of the dome tent from the Northwest Territory sack. Locate a large flat area and remove any sticks and rocks from the ground. Step 2 Lay the tent fabric on the ground with the bathtub style floor face down. Pull the corners of the fabric tight and rotate the tent so the door is facing in the direction you want. Use a hammer to stake the corners in the ground. Step 3 Assemble the two long poles to their full length. The pole segments are connected by chords and will easily snap into place. Slide one pole through the diagonal sleeve on the top of the tent. Slide the other pole through the other diagonal sleeve to form an "X" with the poles. Step 4 Place the end of each pole in the corresponding grommet. The poles will bend and the shelter will be erected. Step 5 Assemble the two small poles. Slide one pole in the doorway sleeve and the other in the back window sleeve. The poles will bend slightly to create a rain peak on the door and window. Step 6 Pull the doormat tight and pound stakes through the loops on each corner. Pull the tent rope tight on the back of the tent and pound a stake through the rope loop to anchor the tent to the ground.
1helpful
How do you properly set up and disassemble the temt?
There should be instructions sewn into your carrying casr.
I have a magellan yukon (23-010) 20'x9' that has some broken poles. Where can I replace the poles
You can replace tent poles. I've never used them, but you can try http://tentpoletechnologies.com/. Otherwise I would suggest buying replacement poles from Academy (who makes the Magellan Outdoor line) or trying to find generic poles and an sporting goods store. Best of Luck!
5helpful
Replacement tent poles Magellan pinecrest
Hi, replacement tent poles can be found easily on amazon, take a look here: Amazon com Replacement tent poles. Have a nice day.
David
Instruction for setup of American Camper tent 8x11
Finally figured it out through trial and error. This right here is the only correct explanation given anywhere on the net.
First, make sure you have all of your poles. There will be 4 straight green ones, 4 straight blue, 4 straight burgundy with plastic feet, 4 curved yellow, 2 small orange arches, a straight pink and a straight white.
Before you start putting the poles together, stake the tent down at every loop point around the base of the tent. There should be 10 of them. Make sure they're fairly tight and the floor of the tent is taught and flat but not so tight that you tear the tent at the seam. Stake 1 corner first. Then put the second stake through the second loop in order and using a firm pressure, pull away from the first stake, along the line of the tent base, make taught and push the second stake into the ground. Repeat until finished.
The first pole assembly uses in this order, going out from the yellow arch, which is in the center. From one side of that arch, add one green, then a curved yellow, then another green and a burgundy at the bottom. Do the same from the other side of the center arch piece.
This arch outlines the door and goes through the 3 loops on the front of the tent, around the door, so the poles hold the tent up. the loops at the bottom are not for the poles. Every loop around the bottom are where the stakes go to hold it down. For now point the feet towards the back of the tent wherever they will stand on their own. You can fine tune it and firm it up once you get the second arch in place.
All green ones should now be used up.
For the second arch, do the same thing but use the blue instead of the green. So from the one side of the yellow arch, 1 blue, 1 curved yellow, one blue and one burgundy. Same order from the other side of the arch.
Now all the poles should be used up except for the straight pink one and the straight white one. These two go together to make a straight pole that goes through the metal loops attached to the yellow arch pieces and locks the two arch assemblies apart at the top.
Now this takes some maneuvering and some word smithery to describe but what you want to do is make sure the feet of the front arch assembly, are pointed towards the back of the tent and stop at the side. The back arch feet will point towards the front of the tent. They both stop about 6 inches BEFORE the center tie down loop on the SIDES of the tent, on either side of the center loop. The front arch will actually lean forward, with the feet pointed behind it and wedged into the ground, right up against the tent at the bottom, move it around until you have a nice firm feel to it. Same with the back arch but this one will lean away from the back of the tent and the feet pointed towards the front. Once you get the back arch into place, it will really firm up and won't budge.
Another way to describe it would be that the two arch assemblies feet will point towards each other at the side of the tent, about 6 inches before they reach the center loop on either side.
Hope this helped. =)
Posted on Jul 04, 2015
Top Magellan Camping, Backpacking & Hiking Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Magellan Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
