Question about Garden
I have a troybilt 7000 gas generator that trips the main output breaker when under a load after 5 minutes
Generator runs great.120volt power output main breaker trips after 5 minutes
    Master:
  • 427 Answers
1. Make sure that the generator limit is not being exceeded.
2. Try checking and raising the rpm. If the engine can not sustain the load from the generator, it can/will trip the breaker.
3. If the carb is dirty or the engine runs poorly it can trip the breaker. Tune up the engine, clean the carb, make carb adjustments to correct substandard running conditions.
Posted on Jan 22, 2013
Why would my generator engine runs great but it will not power any of my tools. what could be the problem?
With no load on the generator, take a voltage reading at the output plug of the generator, if there is no voltage, check to make sure that no breakers are tripped or fuses blown.
Sep 21, 2014 | NEC Mitsubishi MGE 4000 Generator ROU...
Gentron gg3502d outlets have no power
First verify that the breaker for the outlets is not tripped and make sure that the generator is running at full operating speed. let it run for 5-10 minutes and check for output power. If there is nothing, there are two possible problems. One could be that the automatic voltage regulator is bad. The other is that the field needs to be flashed - a high possibility if the generator has not been run in a long time. There are many videos on the internet that show you how to solve both of these problems. Just do a search for No output from a portable power generator.
May 24, 2014 | Gentron 10,000W Generator with Electric...
Engine speeddoes not raise when put under load but produces power
Mar 26, 2014 | Electrical Supplies
No power
Mar 19, 2014 | Hyundai HY1000si 1000W Portable Inverter...
Onan 7000 generator runs but does not produce electric to rv
Mar 19, 2014 | Watts Onan Portable Generator - 4000 ,...
Will not generate electricity
Mar 09, 2014 | Coleman Powermate Subaru 5000W Portable...
Breaker keep triping on screen light shows P-06
Is it tripping under load? or not under load. If it is under load have breaker checked and unit tested on a load bank. If it trips under no load check for wiring shorts on the main AC lines to the plugs
Oct 02, 2013 | Kipor Electrical Supplies
Generator circuit breaker keeps tripping
wet plugs,exceeding max load of circut,whatever it is running has a short in it.
Dec 21, 2012 | Buffalo Tools Pro-series 7000 Watt Silent...
Breaker installed on generator. Keeps tripping under no load after approx. 1 minute of generator running
A tripping circuit breaker is an indication of an overload. You say there is no load on the breaker - how are you making this determination? Are you using an amprobe or some other meter?
A circuit breaker with NO load shouldn't ever trip. Likewise a circuit breaker carrying up to 80% of of the current it is rated for shouldn't trip either. Circuit breakers that carry more than 80% of their load will trip - if the load remains connected long enough. This is called "duty factor" or "service factor" The greater the load is in excess of 80%, the less time that the breaker will carry it before tripping.
An example of a 100 amp breaker with different loads on it (this 100 amp value was chosen for ease of doing the math):
80 amps - never trips
85 amps - trips after 48 hours
90 amps - trips after 16 hours
95 amps - trips after 8 hours
100 amps - trips after 4 hours
105 amps - trips after a few minutes
120 amps - trips after a few seconds
150 amps - trips instantly
This is only an example to show how a certain circuit breaker might trip under a load less than the rating stamped on the body or handle.
A circuit breaker that trips with no load or a load equal to or less than 80% of its rating is most likely defective. You need an amprobe or ammeter for amp readings. If the load is found to be 80% or less, there may be an issue of harmonics that is causing the tripping. You'll need to have special equipment and qualified persons to check harmonic problems. Most harmonic problems occur when the loads are not linear device (transformers). Examples of non-linear devices are "switching" (or solid state) power supplies like those in computers.
I hope this helps and good luck. Please rate my reply. Thank you.
Apr 07, 2011 | GE Tjk436f000 3pole 400a 600vac Circuit...
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
