Question about Sony Playstation 3 (PS3) Console
PS3 Screen is blank
The other day the system went blank. I tried resetting it and the same things always shows up - a blank screen with no options. Even idf I put a cd, game or movie in nothing. I tried the av cables as well as several HDMI cables. Is this a hard drive issue?
  • klekampcd May 11, 2010
    Did you just do a normal reset, power off power on?
  • 4 Answers
No i think your ps3 froze or your settings r 4 hmdi and not snail cables next time reset your tv sometimes the hdmi freezes
Posted on Jan 27, 2009
When I'm told the system was not turned off correctly press ok then the screen stays blank
You corrupted your settings. Turn on the Ps3 let it power cycle, once you get to the blank screen hold down the power button until it beeps 3 times (about 25 secs) Your ps3 will shut off( note: if you have HDMI only, plug in your RCA connections as this will reset your ps3 display to analog) once you are back at xmb, plug in your HDMI and go to display settings and select HDMI. Always let your PS3 do its thing before shutting it down, its equivalent to unplugging your computer instead of logging off correctly.
Jul 06, 2012 | Sony Playstation 3 (PS3) Console
I hooked my PS3 to my HDMI cable to get a better visual screen display for my HD movies and games, but display screen went blank and I cant get the commands menu screen, how can I get the menu commands...
You must reset your PS3 in order to accept the new TV configuration.
  • If the video output settings on the PLAYSTATION3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • Hope this helps please remember to rate my response, thanks!
    OpenSource13
    Jun 16, 2012 | Video Game Consoles & Games
    Can't get system to come back on to tv screen after unplugging and now plugging back into tv. Worked just fine for over a year. Unplugged system and disconnected audio/video cables from front of TV to...
    how was it connected at this other residence? was it via HDMI cable by any chance? if so try this, with the PS3 in stand by mode Press and hold the power button for 5 secs.. (until you hear the second beep) this causes the PS3 to reset the display properties back to 480i..follow the onscreen instructions to set it back up to 1080i
    Feb 17, 2010 | Sony Playstation 3 (PS3) Console
    I have a PS3. When I went to switch it on, the screen went to the initial Sony Communicatons screen and then went blank. The only thing on the screen is the swirly line, there is no menu and does not read...
    have you tried to restore the file system or database?
    there is a "secret" menu that you can enter by holding the power button down. cant remember for how long, so i advise you to go to yourtube and find the vid where they show how to. ill cross my fingers that it will help ya with your problem.
    and just so you know it... i also got read disk problems after the 3.00 update, and it truely messed it up after the 3.01 update, now it wont read anything unless i eject and insert the game a zillion times...
    Oct 01, 2009 | Sony Playstation 3 (PS3) Console
    Ps3 when i turn it on has a yellow screen and wont load games
    Try this:
    Turn the console to stand by, you can do this by pressing the power button for 10 seconds.
    When it is on stand by (a solid red light shows) hold the power button for 3 beeps, remove your fingers on the third beep which should be a double beep.
    This should take you to reset your console. You should see 6 options. Select option 2 then the system will go blank. Repeat the above but this time select option 3.
    Your PS3 should work after. Good Luck!
    Sep 29, 2009 | Sony Playstation 3 (PS3) Console
    Ps3 from wavy screen to blank screen at start up.
    Quick call and its fixed.... Whilst the PS3 is in stand by (red light on) press and hold the on button. Wait until it peeps slowly three times then take the finger off the button. This opens up a factory reset. Work from the top down and see which one fixes your PS3. For me it was a full reset, but at least it keeps your updgrades. :o(
    Mar 14, 2009 | Sony Playstation 3 (PS3) Console
    Some games won't instal
    I'd start with a System Restore.
    Go to SETTINGS, System Restore.
    This will set your PS3 back to factory default.
    If you have game saves copy them to an external usb drive or flash drive.
    Check out my common PS3 problem and repair guide for tips and suggestions for more details.
    http://rescuetechla.blogspot.com/
    Please feel free to email me any other questions and please don't forget to rate!
    Thanks!
    RescueTechLA
    Feb 24, 2009 | Sony Playstation 3 (PS3) Console
    PS3 won't show the system screen unless a game is running... HELP
    put in cables ps3 came with with system on standby hold power button on system down for 10sec
    Jan 06, 2009 | Sony Playstation 3 (PS3) Console
    Ps3 80 gig
    Try getting a new AV Option, well actually first startup your PS3, startup your controller, and hit the center PS3 button, because those 2 options are only in the Main PS3 Option, which is accesed and closed through hitting the middle button on your controller. Hope this helped.
    Jul 11, 2008 | Sony Playstation 3 (PS3) Console
    Ps3 startup software won't load correctly
    turn on ps3 leave on stand by (red light), hold eject button and power button until you hear beeps and a message appears. connect controller and press ps button. system restore screen should appear, select restart system and from there it should restore everything back to normal. This worked for me, for clear instruction go to http://blogallalong.com/2008/12/05/ps3-green-light-on-and-system-wont-start/#comment-31058
    Dec 07, 2007 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    81 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
