Question about Microsoft Windows XP Professional
Some thing about good project...? - Microsoft Windows XP Professional
    New Friend:
  • 36 Answers
I think it would be better if you will make a contact with experts whom you can get from Project Management course providers like "ExcelR Solutions".
Posted on Feb 14, 2017
  • 156 Answers
  1. Project managers must focus on three dimensions of project success. time, within budget, and to a level of quality that is acceptable to sponsors and stakeholders.
  2. Planning is everything -- and ongoing.
  3. Project managers must feel, and transmit to their team members, a sense of urgency.
  4. Successful projects use a time-tested, proven project life cycle.
  5. All project deliverables and all project activities must be visualized and communicated in vivid detail.
  6. Deliverables must evolve gradually, in successive approximations.
  7. Projects require clear approvals and sign-off by sponsors.
  8. Project success is correlated with thorough analyses of the need for project deliverables.
  9. Project managers must fight for time to do things right. Project manager responsibility must be matched by equivalent authority.
  10. Project sponsors and stakeholders must be active participants, not passive customers.
  11. Projects typically must be sold, and resold.
  12. Project managers should acquire the best people they can and then do whatever it takes to keep the garbage out of their way.
  13. Top management must actively set priorities.
Posted on Jan 27, 2009
Rear projection tv blinks from good picture to not so good picture. Verizon has changed the box and says its the tv Model 51H83
the best thing would be to unplug then unit and then unscrew the back panel and the light box should slide out clean it with a duster or a air hose be careful if this doesnt work your lights are going out
Feb 25, 2010 | Toshiba 57H81 57" Rear Projection...
No picture, good sound
The Deflection Board is probably causing the problem. Sometimes it will be loose solder connections or a major hard failure of the board. The key thing here is the age of it. Parts are going to be difficult to fine and if they are available, probably expensive. I am not sure if it would be worthwhile investing money into it. It was a good set. I have one still working by the grace of "GOD".
Hope this helps,
Skyassoc
Jul 17, 2009 | Philips Magnavox 51MP392H Rear Projection...
No video sound is good.... how can i fix it
Check some few things about your unit.
The Video cable and plug in's to the projection outlets. Be certain that the cables plug in are in the correct input, output or both, so you may need to change or move around the cable into each outlet.
You will need or have good operating cables, because this could be one that stopping and not allowing the unit to display any type of picture.
The other thing to check, would be to see if the projection unit is in the TV,Video or Aux mode and change it into the most suitable,desired mode.You would do this by going into the projection's menu and searching for a buttom to switch to the different modes.
You may need to check your projection's lamp unit, and see if it is working properly of at all and there should be light coming from the lamp and if not then replace it with the same tye of lamp.
I hope this helps.
Jul 08, 2009 | Philips Magnavox 51MP392H Rear Projection...
50UX18B Hitachi Projection TV
Good Day, monarchdr272;
Sounds like you may have a bad comb filter. Yes things can be repaired. Good Luck, big IRISH.
Aug 29, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Someone please help
Good Day;
Two things normally happens after a L storm:1.) One must unplug TV for 5 minutes, then plug back in. 2.) Main glass fuse out, will be near a/c cord. 3.( Power regulator IC may be out. Try these first.
Good Luck!
Jun 13, 2008 | Panasonic PT-52LCX66 Projection Television
53UWX10BA
Good Day, securestuden;
The first thing to do is to figure out what the TV is doing OR not doing.
May 06, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Mitsubishi projection 55 inch
A couple of things come to mind I've seen a leaky capacitor on the regulated 9 volt line cause this and also leaky capacitors on the PIP module but I think the latter was on an older model than yours. If you don't know what these things are you should probably let a pro do it but it should be a fairly reasonable repair. Good Luck.
Mar 27, 2008 | Mitsubishi VS-55705 55" Rear Projection...
Hitachi 60fx32b rear projection
When you turn on the TV do you hear 3 clicking noises then the TV turns off?
Jan 12, 2008 | Hitachi 60FX32B 60" Rear Projection...
Philips 34" rear projection
try unpluging and wait an hour plug back in.
Dec 04, 2007 | RCA P46924 46" Rear Projection Television
Zenith rear projection television
no there are many diffent things. for your set has about 480 viewing lines or resolution where as hdtv has twice that. impossible to match it but you can take a hdtv signal and convert it work on your older set. good luck
Aug 15, 2007 | Toshiba 57H81 57" Rear Projection...
Microsoft Windows XP Professional Logo
236 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
