Question about Brother LS-2125 Mechanical Sewing Machine
Birdnesting when sewing
Birdnesting
Hold onto both top and bottom threads when starting your seem. bobbin thread may not be wound correctly. hope this helps.
Posted on Jan 22, 2013
Fixing the problem of birdnesting
Birdnesting is a common but very frustrating problem that can be resolved easily once you know where the problem originates. Remember, if the birdnesting occurs on the underside of the fabric, the problem originates with the upper thread. If it shows on the top of the fabric, the problem is the bobbin.
Very often, the machine is not threaded correctly. Remove all the thread from the machine. Check there are no loose threads or lint stuck anywhere in the machine. Oil as instructed in the manual.
Install a brand new needle! The needle should be suitable for the thread and fabric you are using. All About Needles
ALWAYS RAISE the presser foot and rethread the upper thread. Verify the path is correct.
Check that the bobbin is installed and threaded properly.
Pull the bobbin thread to the top of the fabric.
How and Why to Bring up the Bobbin Thread
Set the upper tension to the midway point.
While holding both thread tails lightly in your left hand, begin sewing slowly.
sewing machine birdnesting Google Search
Oct 27, 2016 | Sewing Machines
The thread gets caught up in bobbin area
This mess is commonly referred to as a bird's nest or 'birdnesting' and it's usually caused by incorrect top tension and that's often caused by the top thread not in the correct path. (For me, I occasionally forget to thread through the take-up lever.) A damaged needle can also cause birdnesting.
Aug 02, 2014 | Husqvarna Huskystar 207 Sewing Machine
New home model 4018 birdnesting problem help
try changing the needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
check to make sure the thread has not come off the thread take
up lever
Aug 05, 2012 | New Home Sewing Machines
How to thread Singer merritt#9608? Probledm with birdnesting
what size bobbin and do you have pictures to show how to thread 9608 singer machine
Mar 10, 2012 | Singer Sewing Machines
My machine is making "birdnests" after sewing a
Sorry, but it is in your threading. If, it is underneath birdnesting, it is the top threading. If, on top, it is the bobbin threading. Do this test, with presser foot up, pull thread, it should pull smoothly, now lower presser foot, the thread should barely move. This should seat your thread in the tension discs. Also, a needle wouldn't hurt when you rethread.
Feb 26, 2011 | Euro-Pro 416 Mechanical Sewing Machine
Keeps "birdnesting", besides rethreading, how do I fix?
when you have bunching on the bottom, you have a problem with the top thread: no tension. (and visa versa) Make sure the thread runs through the tension discs, these discs are activated when you put the presser foot down, so you want to thread the machine with the foot up, also feel if there no burrs, hooks, or whatever, so your top thread comes smooth off the spool, no jerking.
May 24, 2009 | Singer Sewing Machines
Birdnesting under the plate
almost always the thread isnt "tight" enough on top. also if the thread comes out of the take up lever it will "nest" also bad thread, try a different spool.
Mar 18, 2009 | Singer CE-200 Quantum Futura Computerized...
I have a singer-inspiration machine and it appears that the thread keeps getting caught up in the bobbin area so my thread birdnests. I am new to sewing and this is a new machine.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Aug 23, 2008 | Singer 7462 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
49 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
