Question about Refrigerators
My daewoo fridge freezer is leaking water every few days its allways at the bottom of fridge
Some days it a lot of water some days i dont get any but it seams to becoming more freqent, am hoping it not on its way out, can anyone help as to what it will be ??
    New Friend:
  • 169 Answers
There should be a drain in the bottom of the unit. Check to make sure this drain is not clogged. If it is clean it out and keep an eye on it.
Posted on Jan 21, 2013
SOURCE: FF200EP Fridge Freezer - water
I had the same problem, the fridge would leak overnight (usually) I found with some more searching the answer..... try it at you own risk!
Here are 2 detailed answers depending on your circumstances/technical ability....Turn off fridge....
1. Defrost fridge...catch all the water
or
2. Work quickly....
Remove drawers, at the back of the fridge there is a panel with 5 phillips screws (note that there are long and short screws). Remove the screws and the panel. (if you chose the second option then this will be "frozen in place" so you will get crunching noise when you peel it away - so be careful when removing it). At the top of the panel is a connector that powers the fan, squeeze the 2 sides in to remove. This will allow the panel/ducting to be removed from the fridge. (If you chose option 2 you will now probably see a large lump of ice over the drain hole).
Remove ice or debris from drain hole, re-asssmble not forgetting to connect the fan again!!!) then repower the fridge following the instructions as you will get the alarms... the fridge cools and the warning lights dissapear.......24 hours on mine is OK!
Mal Function
Posted on Dec 28, 2008
HVACRH20
  • 237 Answers
SOURCE: water dripping from freezer to fridge
Sounds like the drain for the defrost cycle water may be plugged and you eventually overflow water. See if you can find the little drain hole for the coil defrost water and check for dirty/plugged. Try to pour hot water in the drain area and see if it runs out the drain fast (if real slow it's a problem). Make sure the water is also going down to the holding pan near the bottom area/compressor area (that's where it evaporates later). Let me know what you find.
Posted on Nov 30, 2006
  • 72 Answers
SOURCE: Viking freezer leaking
you have a clogged drain, it is either clogged with ice or some kind of debris, thaw the freezer out and push a length of weed trimmer line down the drain. The drain is accessible by removing the back wall of the inside of the freezer. If there is no clog then the drain may be freezing up, if that is the case, take a piece of 14 gauge romex wire and loop it several times around the heating element at the bottom of the evaporator and push a few inches of it into the drain, this will get hot and transfer heat when it goes into a defrost cycle which is where the water is coming from in the first place
Posted on Jun 17, 2009
SOURCE: leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Posted on Jul 03, 2009
Richie_asg1
  • 1036 Answers
SOURCE: bosch fridge freezer - ice build up and water leak from freezer
This is most likely a blocked drain pipe - blocked with ice that is.
Remove all the drawers in the freezer - and stack them up.
With the unit switched off and unplugged, undo the fixings on the rear pannel in the freezer (behind the drawers)
Remove it to see the evaporator coils etc.
At the base there should be a channel - and a hole leading to the drain pipe. This needs unblocking wih a thin flexible cable. -net curtain support wire is ideal, and cheap. or use a short length of insulated cable.
Check it comes out at the rear of the unit onto the evaporator container - situated on top ofthe compressor.
Replace everything and switch on.
Posted on Sep 08, 2009
My Daewoo FR-291 fridge with freezer at topleaks 1/2 cup or so a day & onto floor sometimes. Hired one for $150 as told to turn ours off for 2 days. Leaked nxt day again. Thxs NZ
a thorough inspection of the tubes, filter, solenoid, ice maker and water dispenser should reveal the leaking component
also a thorough inspection of the defrost drain, drain tube, and dryer pan
Apr 08, 2017 | Daewoo Refrigerators
My daewoo fridge freezer is freezing food I the fridge on every shelf
Turn down the cold control there can be 1 or 2 if 2 one is main electronic the other just a baffle that controls how much cold air in freezer is allowed into fridge that is be pushed by the fan located in freezer. Cold is only made in freezer then does a circular tour as it leaves cold in freezer moves top 2 bottom then as its warmed it enters freezer to do it all over again . Adjust baffle and or control in this unit it may show 0 or off but there seems to be a lot of movement available before it does turn fridge off. Ive had on a few occasions had how the shelf's are arranged deflect the or mess with the cold airs intended route.
Mar 16, 2017 | Daewoo Refrigerators
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
Why does my daewoo fridge freezer works intermittently ?
You either have a faulty thermostat, a loose connection or most likely a build up of ice inside the freezer. I had the same problem. Almost replaced fridge. Took all the food out one day, took out the racks and disassembled bottom and rear and found a two foot log block of ice inside air return. Removed ice everything works perfectly.
Jul 22, 2014 | Daewoo Freezers
Ice forming at bottom of Daewoo freezer. How do I fix this
Look on the back of the unit for a plastic hose coming out the bottom to a drain pan usually sat on top of the compressor. Bend a straw and push up inside. If it won;t go, there is a blockage, usually ice in the drain. Fully defrost the freezer and blow through the straw until clear.
Apr 28, 2012 | Daewoo Freezers
The fridge and the bottom freezer are working fine. However there is a lot of ice developing at the bottom of the (bottom) freezer. Although we recently de-frosted the freezer and removed the ice (water),...
there is only 2 things if you dont have an ice maker inside your door is not sealing all the way around or the drain is cloged with ice and everytime the ref goes into defrost the water leak into the fzr unplug for 2 days that shoud fix it
May 30, 2010 | Liebherr KGBN 3846 Premium BioFresh Bottom...
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
My Daewoo Fridge Freezer has a pool of water in the bottom of the freezer compartment - mostly turning to ice - the rest dribbling out on to the carpet - this happens every few days - any ideas?
very common.. the drain for the condsate water is pluged. with algi . force hot water down the drain to clear. use a turkey baster . should correct problem . every 8 hrs of compressor run time the defrost cycle runs abour 1 cup of water down the drain . if it can't go down the drain tube . then to the bottom of freezer and out on floor .. hope this helped **** .. feed back pls .
Dec 23, 2009 | Refrigerators
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
184 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
