Question about Sharp MX-2700N Color Copier
Reset code fk3 mx-4501n
5 Suggested Answers
tehnik_bdg
  • 91 Answers
SOURCE: Sharp printer copier MX 4501N, how to remove the
Pull the paper tray to the front, after it is stuck pull it up ward and front
Posted on Apr 16, 2009
  • 143 Answers
SOURCE: Sharp MX-4501N Error L4-11
L4-11 is a Shift motor trouble in the finisher. First you must repair the problem then Use SIM6-1 to check the operation of the shift motor. Then use SIM30-1 to check the shifter home position
sensor. Check the harness and the connector
between the PCU PWB and the shift motor.
You can clear the code by using SIM 14.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key ON → CLEAR key ON → Asterisk (*) key ON → Ready for
input of a main code of simulation
2) Entering a main code with the 10-key → START key ON
3) Entering a sub code with the 10-key → START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected
item.
Press START key or EXECUTE key to start the simulation
operation.
To cancel the current simulation mode or to change the main
code and the sub code, press the user setup key.
* Canceling the simulation mode to return to the normal mode
1) Press CA key.
Posted on Sep 01, 2009
  • 33 Answers
SOURCE: can you bypass or delete the admin on the sharp mx
this is easy to do but it comes down to a security problem....cant be sure you are the owner of the copier best to contact local sharp repair
Posted on Jul 20, 2010
dwylie76
  • 80 Answers
SOURCE: our church have MX-4501N and the display says service H5-01 , what does it mean?
It means you have had 5 consecutive jams in the fuser. If you have removed all the paper out of the fuser you can reset it. You have to push : # * C * to get into the simulation mode. Once your in that push 14 and the start button. You might have to then push a button on the LCD screen that says execute. After that push the CA button and the machine will restart.
Posted on Nov 20, 2011
MAINTENANCE CODE FX3
Should be FK3 ,this is only fusing maintenance display no worry
Mar 18, 2014 | Sharp MX-2700N Color Copier
Sharp MX-4501n firmware
The firmware is only available from Sharp's service site. Call a local Sharp dealer to upgrade the firmware for you.
If you're in Houston we would be glad to help you out. We have the best copier service in Houston.
Skelton Business Equipment Houston Copiers
Sep 05, 2013 | Sharp Mx-4501n Color Laser - Printer /...
What is error code FK3 on Sharp MX3501N
FK3 is the code for the cleaning web in the Fusing Unit.
Jul 30, 2012 | Sharp MX-2300N Color Copier
I have a MX6200N with a Maintainence code of -FK3. What does it mean?
FK3 means that the fuser web cleaning counter has reached the specified limit. Replace the web and reset the counter.
If you are getting the FK3 message, get ready to do a PM. Those messages will be popping up soon.
Mar 10, 2010 | Sharp Office Equipment & Supplies
Add user codes to a sharp mx-4501n mpf
Try exploring the device's web management interface.
Use your wenb browser to connect to the device's IP address.
the default credentials for the unit are user: admin pasword: admin
if that does not work, try password: Sharp (note that the S is capital and the rest are lower case)
Apr 24, 2009 | Office Equipment & Supplies
Sharp MX-4501N Mac drivers 1.1 will not hold black and white colour setting in printing profile (save as)
You are using Bonjour to print to the MX-4501N which uses a generic post script driver. To fix this, you must install the printer using the proper driver from Sharp. For a first time install, download the drivers, install the drivers, restart, and install the printer as an IP printer, specify the IP address, it should be using the LDP (Line Direct Printing) protocol, and specify any additional optonal accessories you have on your MX-4501N. Hope this helps :)
Oct 09, 2008 | Sharp Office Equipment & Supplies
Sharp MX-2700N Color Copier Logo
155 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
